wiper/washer reserrvoir leak(?)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by timo27, Aug 21, 2009.
  1. timo27
    timo27 Member
    316
    52
    Baltimore, MD
    Hi All -
    When I add fluid to the w/w reservoir, bringing it up nearly to the top, it slowly recedes down to, apparently, approximately the top of the plastic reservoir tank istself. Before I raise it as an issue (among a couple others) with the dealer, is there anything I don't know about this? Some kind of bizarre-o reserve adjunct supplementary repetidundant reservoir that for whatever reason drains the fluid off into ethereal Priusland, or something, before coming to my eventual aid? There does not *appear* to be a leak (at least not under the vehicle) when I fill it, but if there is a leak, could it be captured by the plastic whatchamajinger that makes it more aerodynamic and adds a step to the oil change process?
    Anyone else notice this?
    Any advice, as always, is appreciated.
    Thanks,
    Tim
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Space is needed at the top of the reservoir for expansion...
  3. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    Keep pouring, it will obviously fill up or the leak will become apparent. Sorry it's all I know to tell you.
