Wire harness oil cooling pump
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by kromerok, Jul 9, 2021.
  1. kromerok
    kromerok Junior Member
    26
    Los Angeles
    2019 Prius Prime
    Does anyone know the part number for the oil cooling pump (3530047010) wire harness for a 2019 prius prime?
  2. Elektroingenieur
    2,515
    3,275
    Three Touring
    The Electrical Wiring Diagram (more info) shows the oil pump is attached to connector A30 on the Engine Room Main Wire harness, for which the part numbers are listed in catalog Figure 82-02, Wiring & Clamp: 82111-47P20 (list price $4,282.29) for “G” (Premium or Advanced) grades, or 82111-47V00 ($4,001.49) for “E” (Plus) grades.
    A complete wire harness wouldn’t usually be replaced, however, due to its high cost and the complexity of the installation: the harness has dozens of connectors, including some on the instrument panel side of the firewall. Indeed, wire harnesses are among the few parts for which the Repair Manual doesn’t provide removal and installation instructions.
    Rather, a damaged or defective harness would usually be repaired using the techniques and repair parts described in the Electrical Wiring Diagram. For example, an empty housing of the type used for connector A30 is available (part number 90980-12A29), as are repair wires (pigtails with terminals) (part numbers 82998-24420, 82998-12790, or for gold-plated, 82998-12780) and splices.
  3. kromerok
    26
    Los Angeles
    2019 Prius Prime
    Thank you, I went to a salvage yard and bought the connector and wiring for the cooling pump. Installed it and it works now i get the same error code just intermittently now
  4. kromerok
    26
    Los Angeles
    2019 Prius Prime
    Ended up being the fuse, it showed it being in a different area on the fuse guide
