Won't run after a run in with a deer
Discussion in 'Prius c Technical Discussion' started by MWD, Mar 1, 2013.
  1. Help
    1 vote(s)
    50.0%
  2. Help
    1 vote(s)
    50.0%
  1. MWD
    MWD New Member
  2. fayyaz26dec
    fayyaz26dec New Member
    what is this orange light icon and its meaning ? if any one know plz tell me
  3. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    If you are referring to the one in your profile picture, it looks like the security light. It means your car is off.
  4. 2015Prius2
    2015Prius2 Member
    150
    67
    P2111 usually is throttle body related, check to make sure that the plug is still plugged in to the throttle body actuator and that the butterfly on the throttle body isn't blocked from moving somehow.
    P3190 is a reduced engine power code that could be related to your p2111 code. Check for secure connections at the throttle body, ECM, cam sensor, crank sensor and mass air flow sensor
