worthless gps
Discussion in 'Gen 2 Prius Main Forum' started by ernie1, Oct 11, 2011.
  1. ernie1
    ernie1 Junior Member
    67
    Sacto,Ca.
    I have a 2008 Prius with a gps that is almost useless to me because it contains very little useful information. When I try to locate an address, a lot of times the response from it is that "no such street " or "no such address exists" even though these locations have been there upwards of 25+ years. Much of any info I can get is very limited and I'm sure Toyota wants me to pay big $$$ for an update but I feel that the information that should have been available like 25 years ago should not have to be obtained through a costly update.
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Make sure you have the correct Region set when looking for an address,
  3. jelloslug
    jelloslug It buffed right out!
    813
    Greenville, SC
    Rtfm
  4. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    ^no need to be brutal. The OEM gps does suck, even when they are newer versions.
    I searched for the US Post Office in an unfamilar part of town and it directed me 2 miles to an old apartment complex. No post office in sight. It's always a POS when I need it to be helpful.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    First, make sure you have the proper region selected. Once that is set, make sure to enter addresses in a reverse order: from general to specific. Never give the GPS more information than necessary, as you may accidentally filter out your desired destination. For example, say you are looking for an address on South Lovers Lane. In the database it may be listed as South Lovers Lane, South Lovers Ln, S. Lovers Lane, or S. Lovers Ln. Enter it as "Lovers" without any of the supplemental information; that way you can pick the correct version from a list.
    Let's look at an example. Suppose we want to find the following address:
    116 S. Lovers Lane
    Kalamazoo, Michigan
    We start by going to the second address screen and entering a few letters in the state field to select Michigan. This will now limit the list of cities to only those found in Michigan, so the list will not be cluttered by cities in other states.
    Now we go to the city field. We can enter letters until Kalamazoo pops up, or enter just the first few letters and then select Kalamazoo from the list. Either way works.
    Once the city is selected the list of streets is limited to only those found in Kalamazoo. This makes it much easier to find the correct street. Enter the street as "Lovers" - don't use the "South" or "Lane", as the database may use another form. "Lovers" can entered in its entirety, or once again we can use just the first few letters. Pop up the list and look for S. Lovers Lane. It may be abbreviated differently. It may even appear more than once, using differing abbreviations. Pick the one you want. You may have to try more than one.
    Finally, move to the street address field. This field will now be limited to only street numbers found on S. Lovers Lane. Key in 116.
    The process is easier than it sounds, and it makes a big difference when entering destinations. There are areas of the country where the database is poor, in which case no amount of technique helps.
    Tom
    3 people like this.
  6. ernie1
    67
    Sacto,Ca.
    qb42 and others, thanks for the replies but I've used the very same approach as you've suggested which I find cumbersome, however, out of desperation I try it anyway but get minimal to no results. In my cases, the addresses are much simpler and do not include any north-south designations and the street names are one word only. Let me clarify that I DO occasionally get the info I need but very rarely. Do you get satisfactory results? My 2003 Honda Odyssey's gps was great at giving me info. My sister-in-law's Lexus RX300's gps has no issues like mine nor does our friend's 2008 Toyota Highlander. Because we have ONLY a Prius we get the cheapy limited version?
  7. firepa63
    1,761
    208
    The NAV system in the Prius is the same as in the Lexus...
  8. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    My Nav system gives me no issues. Once I took the time to configure it to match my driving style, it takes me where I want to go without fail.
    I do not think there is very much difference between your Nav and mine.
  9. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    I agree with JD here. The only time I had a problem was when it couldn't find Cedar Point Amusement Park the first time I took it there. I cursed and yelled at it....then realized I had to select the appropriate region. There have been a few times where the "dot" for the destination wasn't QUITE accurate, but it got me close enough to where my vision and alertness found the building.
  10. SpikeVFR
    SpikeVFR New Member
    221
    SF Bay area, CA
    the vast majority of the time, I have no problem finding the streets and I get the right location -- and mine is a 2004
    why don't you throw out some addresses you aren't finding and see if we can find them on ours?
  11. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Ditto. That holds true for me in CA and WA. I've also used mine w/o much issue in NV and OR but the Vancouver BC area wasn't good. Mine's the original disc that came w/my 06.
    To the OP, how about try finding these streets in San Jose, CA?
    Royalwood Way
    Camden Ave
    Almaden Expressway
  12. ernie1
    67
    Sacto,Ca.
    SpikeVFR: Okay, here you go: 710 Carolina Court, Modesto, CA 95356; 5314 Paso Del Rio Way, Concord, CA 94521. The best I could do was that the gps said those streets did not exist. I have, in the past, been able to locate some addresses but not with any regularity. Thanks for the help and looking forward to positive results.
  13. ernie1
    67
    Sacto,Ca.
    cwerdna: I just went out to the car and easily found all three streets.
  14. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Have you tried cleaning the DVD? It's free so it's worth a shot.
  15. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    results w/my 06 w/original DVD
    On my 06's original DVD:
    710 Carolina Court, Modesto, CA - house number does not exist. It can find the street. It has the address range as 7100-7199. Interestingly, Google Maps doesn't seem to be able to find that house number and ditto for NAVTEQ Maps and Traffic (sole provider of map data on my 06 DVD).
    5314 Paso Del Rio Way, Concord, CA - found it w/o issue
    Out of curiosity, does your map DVD include copyrights for Navteq and Teleatlas or just Navteq?
  16. ernie1
    67
    Sacto,Ca.
    cwerdna: Not sure but as far as I can tell, there is reference to "Maps of Denso", 2007 Denso Corp; 2006NAUTEQ; 2006 Teleatlas North America, Inc. Each of these references is preceded with a copyright symbol. As far as the address that you found on Paso Del Rio Way in Concord, CA, I tried yesterday and the gps told me there was "no such street". My wife's I Phone found it just like that. I haven't bothered to try cleaning the dvd because the gps was like this from day one when I received the car brand new.
  17. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Since you were able to find the streets I mentioned in San Jose, CA, it sounds like your region/search area is set right.
    Side note: I do recall a couple times (less than 5, I think) where my car's nav system was unable to provide turn by turn guidance for certain areas. Once was somewhere San Jose and Las Vegas, likely after having gotten off I-5. Another time was in my friend's area in El Dorado Hills, which isn't that far from you. I've only visited him once.
    I just checked the copyrights on my disc. Mine has data ver 05.1 and says U40 in the upper right and has these copyrights:
    2005 DENSO CORPORATION
    2004 NAVTEQ
    GDT, Geographic Data Technology, Inc.
    Data by infoUSA (c) 2004
    Earlier in the year, I was surprised to hear of Tele Atlas being at all on Toyota's nav DVDs (see http://priuschat.com/forums/gen-iii...tion-10-1-gen-6-update-dvd-2.html#post1244710 and one post further down.)
    There are only two major map data vendors: Navteq and Tele Atlas. Navteq is generally known to have better map quality in the US. I'd always heard that Navteq was used by most automotive OEMs. It's unclear what portions of Toyota's map data comes from each vendor and whether there's any merging.
    Denso is a MAJOR supplier to Toyota but also supplies many components (including nav systems) to other automakers, including GM (!).
    Confirmed that my iPhone 4 finds 5314 Paso Del Rio Way, Concord, CA w/o issue.
    I don't know what else to say (after trying to clean the disc) other than filing a complaint via phone at http://www.toyota.com/help/contactus.html. The links to posts by Prius Team at http://priuschat.com/forums/gen-iii...6-nav-system-worth-1800-a-11.html#post1316654 sort of elaborate as to why.
    Can someone with nav DVD 10.1 or 11.1 chime in on the OP's two addresses from post 12? (http://priuschat.com/forums/gen-iii...7956-nav-update-dvd-11-1-way.html#post1396953 has 11.1 already.)
  18. ernie1
    67
    Sacto,Ca.
    cwerdna: Thanks for your careful and informative help in trying to make my gps work properly. I'll try your suggestions in cleaning the dvd and contacting Toyota. Just really thinking that with the wife's iPhone and my lack of confidence in the Prius's gps, I'm getting to a point where I don't want to put a lot more effort into dealing with it. The iPhone response is immediate and accurate. The other issue is that with 81+k miles on the car, probably within the next year or so I'll get a new non gps equipped Prius and save myself about $2,000.
  19. wick1ert
    1,311
    183
    Delawhere
    I'll try to remember to look into it on my nav when I get done work at 7pm EST. Hopefully I'll remember to take the post-it note that I wrote them on with me when I leave :)
    I wish that the automakers would partner with Google somehow, to get their map data into the cars with street view. I'm sure this is A LOT of data, but it would be really helpful as I feel they have the best database of this information. Maybe one day I will have a use for a tablet afterall.
  20. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    Cleaning it is just a free suggestion that someone else threw out. It might not help at all. As for contacting Toyota, don't get your hopes up too high. At least your complaint will be officially logged in their system.
    The only reason for having people w/newer rev discs to check those addresses is to see if the map data on those is any better. If so, you could go that route but unfortunately Toyota charges so much for updates (thru legit sources), you could buy a dedicated PND for less than 1/2 that. :(
    Their map data appears to be a conglomeration of Tele Atlas data + others. See the lower right corner of Google Maps and Legal Notices for Google Maps/Google Earth and Google Maps/Google Earth APIs. In the past, I thought they used some Navteq data, but it seems no more.
