would not start after first fill up
Discussion in 'Gen 2 Prius Technical Discussion' started by mistermugsy, Jul 6, 2007.
  1. mistermugsy
    mistermugsy New Member
    07 package 3 375 miles av mpg 43 mpg mostly city today after filling up the car would not start . When I pressed the start button all of the warning lights including the brake light came on . I called the dealer who said to try starting procedure over a few times . Car did start and is now performing normally . Should point out that car was running in park position for maybe 10-15 minutes while I was demonstrating the audio system to a friend . Any comments ??? thanks , Marty in Florida
  2. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    <div class='quotetop'>QUOTE(martino fl @ Jul 6 2007, 05:00 PM) [snapback]474273[/snapback]</div>
    Only thing I can think of is that, if the fuel cap isn't secured, it'll create all sorts of problems.
    Or...for some reason, you forgot to press on the brake when pushing the power button.
  3. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    If it happens again, check the color of the light on the Power button.
    Green or Amber indicates the Power button pushed without brake pedal depressed.
  4. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    <div class='quotetop'>QUOTE(martino fl @ Jul 6 2007, 06:00 PM) [snapback]474273[/snapback]</div>
    Sounds like the start button was pushed without the brake engaged. Without the brake the 1st push is the usual "ACC", the 2nd push is "ON", the 3rd is "OFF".
