Yet Another Prius In Snow Thread
Discussion in 'Gen 2 Prius Main Forum' started by josh2008, Jan 10, 2010.
  1. josh2008
    josh2008 Active Member
    365
    144
    Princeton, WV
    :D Just kidding.
    I drive the salsa red 05 with the moon caps, member toyotechwv drives the white prius. One of our service advisors (Perry), his son Justin drives the red Subaru WRX. Enjoy.
    Also, here is a few pic of my car from before we all met up, I like it.
    2 people like this.
  2. dogfriend
    7,512
    1,188
    Carmichael, CA
    Do either of the Prius have VSC?
  3. josh2008
    365
    144
    Princeton, WV
    Both cars have VSC. Snow drifting can be done in Prius with VSC it is jsut very limited and somewhat challenging. During the video recording both cars were operated in inspection which disables traction control and vsc.
  4. a_gray_prius
    2,927
    783
    IL
    Haha awesome!!
  5. Patrick Wong
    18,200
    6,490
    Nice video!
    At least when in inspection mode and P, engine RPM is limited to ~2,500. When in D, is that limitation still in effect?
  6. cpm
    cpm Junior Member
    23
    WV
    Ah, Cheaters!
    had my new old '04 out on sat in really big snow, went over to the nice freshly scraped down to icerink quality school parking lot.
    TRIED to toss it sideways a number of times, the VSC irritatingly just made
    the car behave like a normal car. Very frustrating. :)
    FWIW, I worked this car in the snow a lot this weekend. All the complaints I have heard viz prius's in the snow, seem completely unfounded to me.
  7. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    Maybe you can spin it using the parking brake while turning hard on an icy lot?
  8. patsparks
    10,664
    567
    Adelaide South Australia
    My son said, "That Prius isn't drifting, it's arse draggin'."
  9. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    True drifting would need rear-wheel drive, wouldn't it? Like
    the WRX obviously has.
    I was doing similar stuff in the prius a week or so ago -- had a
    large parking lot *all* to myself, as a car dealership had recently
    closed and had been storing its extra stock there. I *totally*
    tracked up its 4 - 5 inches of almost virgin snow over the course
    of about 20 minutes. Always good practice for feeling how skids
    work, without risking excess tire wear on pavement. And yes, the
    way to break a Prius rear loose *is* use the E-brake. If you push
    it down just far enough so it starts ratcheting but then let it up
    just to the point where the ratchet lets go but it doesn't reset
    for the down stroke, then you have complete up/down control over
    the E-brake [thus, rear end] until you let it all the way up again.
    _H*
  10. don_chuwish
    don_chuwish Well Seasoned Member
    816
    182
    Southern Oregon
    That looks like a ton of fun and is excellent practice. Unfortunately I won't be seeing that kind of snow unless I drive up into the mountains a bit.
    - D
  11. josh2008
    365
    144
    Princeton, WV
    Patrick,
    RPM is not limited in inspection mode while in D or B. It is, however, like you said limited to ~2500 in P.
  12. josh2008
    365
    144
    Princeton, WV
    Where at in WV do you live? In trying to get the Prius to break loose, the parking brake is your friend. ;)
  13. cpm
    cpm Junior Member
    23
    WV
    Davis, up in Tucker County.
    I was mostly just trying to see what it would do. There are better cars for parking lot fun :)
