Your Moment in the Sun: Post PIP EPA sticker guesses
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by SageBrush, Sep 26, 2011.
  1. SageBrush
    SageBrush Senior Member
    11,627
    2,532
    Southwest Colorado
    What we know: 87 MPG(e), 49 MPG in CS mode
    Unknown (guess!)
    Blended range:
    gallons/100 miles CD test:
    kwh/100 miles CD test:
    Kudos to the winner, and in the meantime a reminder to all that we are all guessing until the sticker comes out or Toyota publishes the numbers!
    I'll start --
    Blended range:19 miles
    gallons/100 miles in the blended CD test:0.5 gallons
    kwh/100 miles in the blended CD test:22 kwh
  2. gwmort
    gwmort Active Member
    985
    211
    Delaware
    Rcda = 15 miles
    AER = 0 miles
    0.75 gal/100 mi
    20 kwh/100 mi
  3. austingreen
    austingreen Senior Member
    13,623
    4,165
    Austin, TX, USA
    Wild guesses assuming toyota is slightly conservative in estimates
    Rcda = 15 miles blended range
    0.5 gal/100 mi
    22 kwh/100 mi
    CS gas mileage
    48 hw/50 city/ 49 combined
  4. Trollbait
    12,240
    AER = 13 miles, with 15 miles blended
    0.25 gal/100 mi
    40 Kwh/100 mi
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,000
    Fort Lee, NJ
    Blended Range = 20 miles
    AER = 9 miles
    0.75 gallon/100 miles
    15 kWh/100 miles
  6. DianneWhitmire
    DianneWhitmire High PRIUStess
    4,062
    1,123
    64
    Laguna Niguel, CA
    Blended Range = 16 miles
    AER = 12 miles
    0.65 gallon/111 miles
    38 kWh/100 miles
  7. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    mpg(e) = 90
    Blended Range = 18 miles
    0.55 gallon/100 miles
    18 kWh/100 miles
    AER: As defined by EPA - Irrelevant to me, car is designed to maximize efficiency.
  8. Roadburner440
    Roadburner440 Member
    316
    59
    Hampton, VA
    Correct me if I am wrong here, but you guys seem to be far underestimating the car? To the best of my knowledge the Li-Ion battery is 3.6kwh, and you still have the NiMh battery that is 1.6kwh as well.. I personally think the car will come clost or best Toyota's in house figures especially since it uses the ICE for heat generation and acceleration. Personally 15kwh/100mi is a really really low figure.. I drive my Volt pretty conservatively for the most part, and I myself am at 31kwh/100mi (it is EPA rated 35kwh/100mi). I think the PiP will most likely come in at:
    Blended Range = 30 miles
    AER = 17 miles
    1.8 gallon/111 miles
    30 kWh/100 miles
  9. evnow
    evnow Active Member
    816
    155
    Seattle, WA
    2013 Nissan LEAF
    Here is a hint. Looks like Dianne is winning this one.
    For Leaf :
    For Volt :
  10. usbseawolf2000
    14,487
    3,000
    Fort Lee, NJ
    With the Japanese PiP requiring 3kWh for a full charge with the charging loss, I was trying to calculate things backward.
    We know the blended MPGe is 87. That's 87 miles to a gallon equivalent energy (33.7 kWh).
    If you subtract 3kWh of electricity, you are left with 30.7kWh of gasoline. That's 0.91 gallon of gas.
    We know PiP is expected to get 49 MPG with gas only. So, that 0.91 gallon would go 44.6 miles.
    87 - 44.6 = 42.4 miles
    3kWh of plug electricity would stretch another 42.4 miles? That's too good to be true! Where am I going wrong?
  11. evfinder
    evfinder Member
    293
    72
    3KWh will take you about 9-12 miles not 42
  12. daniel
    14,487
    1,519
    Spokane, WA
    Pardon my ignorance, but what are AER and Rcda?
    And does "blended" refer to fleet average in the real world, or is there a standard blend used for the figure?
    And are there separate MPGe figures for EV mode, blended mode, and hybrid (CS) mode?
    I imagined that blended mode would mean the car starts with a full charge, and then is allowed to use both ICE and battery as the computer sees fit, as the Hymotion plug-in conversion does, so I'd have guessed the blended range to be twice the EV range, or around 30 miles, after which the car would go to hybrid (CS) mode. But with so many people guessing the blended range about equal to the EV range, maybe we're using different definitions.
  13. Allannde
    Allannde Just a Senior
    874
    138
    Washington State
    MPGe is supposed to be a way to express All Electric Range (AER) as the equivalent of miles per gallon because that is the way "most people" understand the range between "refill"s. It fails as a comparison because internal combustion engines are so different at energy efficiency than electric motors. There is more equivalency in "blended mode" but this is not easy to compare because it is so variable.
    If someone can make sense of this, they will fill me with awe!
  14. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Very funny. :D
    You're treating it as if the 87mpge means 87 miles traveled on
    3 kWh of electricity + 1 gallon of gas.
    It would actually be 3kWh + energy from G gallons of gas for B blended miles or more generally E kWh plus energy of G gallons of gas for B blended miles.
    Then, the ratio between blended miles and mpgE M is same as the ratio between energy consumed over the blended miles and the energy in a gallon of gas (33.7kWh). I.e:
    M/B = 33.7/(E+33.7G)
    Or:
    M = 33.7B/(E+33.7G)
    B, G and E are revealed by testing. E is relatively fixed but does actually vary slightly with temperature.
  15. ItsNotAboutTheMoney
    2,287
    460
    Maine
    All Electric Range
    Charge depleting actual range. It's R[subscript]cda[/subscript].
    http://www.arb.ca.gov/regact/2012/zev2012/zevappa3.pdf
    Blended means running in a combination of EV and HEV. If a PHEV cannot run all the tests (which are meant to represent all driving conditions) in pure EV mode it would have a blended mpgE, an Rcda and a CS mpg. If it can complete the tests in EV mode it could be treated as an ER-EV and be given EV mpgE an AER and a CS mpg.
    A BEV would obviously only have a EV mode mpgE.
    Blended mode mileage depends on the tests. The PiP would be able to perform most of the tests in EV, but longer tests or harsh acceleration would force the engine to run. I wouldn't expect the Rcda to be that high.
  16. ItsNotAboutTheMoney
    2,287
    460
    Maine
    The test mules kept the original NiMH pack and added two Li packs but the production version is all Lithium, with, I think, two subpacks.
    Rcda: 18 miles
    gal/100mi (CD test): 0.655
    kWh/100mi (CD test): 16.667
  17. daniel
    14,487
    1,519
    Spokane, WA
    Thanks for the explanations. Since the numbers are going to depend on tests whose details I am unfamiliar with, I have no guesses.
    However, I'll guess that the actual EV range will be around the 15 miles Toyota's been saying; that if the car is forced to use the ICE from the start it will use about half gas, half electricity while the grid charge lasts, halving its use of gas during the first 30 miles; and that in EV mode it will get the same 3 to 4 miles per kWh that most EVs seem to get.
    Very slow steady-speed driving is more efficient, but slow-speed driving is usually stop and go, which will cancel out the slow-speed advantage.
    Those are my guesses.
  18. SageBrush
    11,627
    2,532
    Southwest Colorado
    ^^ If the 3 - 4 miles/kwh is wall consumption I agree with you, although that is a huge range. One car using 33% more energy than the other is close to the hybrid advantage over conventional cars.
  19. evnow
    evnow Active Member
    816
    155
    Seattle, WA
    2013 Nissan LEAF
    It is much more easier to get a larger range in EV than in ICE - because of heating. My monthly mpkwh (wall to wheel) has ranged from 3.1 to 4.4.
  20. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    Reviewing the testing proceedures (see http://www.smidgeindustriesltd.com/leaf/EPA/EPA_test_procedure_for_EVs-PHEVs-1-13-2011.pdf and
    http://www.transportation.anl.gov/pdfs/HV/457.pdf
    I'm still confused on how they combine the final numbers across the 5 test cycles (PiP should do old UDDS in EV, but not the Hwy and definitely not US06, so some will require blending.. so maybe that means no AER at all, Or does one estiamte AER on each and average??)
    I'll go ahead and estimate
    AER = 11 miles (if reported at all, I think one gets AER or Blended, not both.)
    In Blended mode
    .64 gallon/100 miles
    34 kWh/100 miles
    (Edited gall/100m had forgotten to scale to 100m)
