Zune HD in 2010 prius with Nav + usb integration.
Discussion in 'Gen 3 Prius Audio and Electronics' started by radiohedwig, Dec 11, 2009.
  1. radiohedwig
    radiohedwig New Member
    Los Altos,CA
    Hi all,
    New to priuschat here.
    Just purchased a prius III with nav + usb input. I have a zune HD and found out promptly that it doesn't work. I know I can use the aux input, but I'd rather use the usb to get controls and charging.
    Has anyone here found a solution to this? I'd be willing to get an aftermarket accessory, I saw some audio box for $300ish that can be hooked up. However I am not willing to open anything up in the car in terms of installation. If I am missing something, I apologize I looked at common threads and none of them were about the zune HD.
  2. radiohedwig
    Los Altos,CA
    Wow, really no one else has a zune HD?
  3. equake
    equake Member
    155
    Los Angeles
    Maybe its time to trade it in for an Ipod :). JK. Does the Zune have Bluetooth, if so you can always use that.
    I don't know what type of USB connection is on the Zune side but it could be the cable.
    I had to struggle to get the new Moto Droid to work with USB which uses a microUSB connector on the device. Some cables would charge the phone others wouldn't. The key for the Droid was to set the SDCard as a USB Mass Storage device before connecting to the USB plug. Its probably very different on a Zune since the Droid essentially runs a Linux OS.
    After getting the USB to work I was disappointed with the limitations of the featureset. Once the Droid supports the advanced BT AV profile I'll stick with bluetooth.
  4. radiohedwig
    Los Altos,CA
    Hehe I'd get a ipod if I didn't have to use itunes:p Plus I love the OLED screen on the zune. It doesn't have bluetooth or I'd use that, and the cable is proprietary. So far I'm just using a flash drive, but I hate how it sorts it by the last folder (which is albums for me). I don't want to rearrange all my song titles to use it well (plus it's slow imo).
  5. john1701a
    john1701a Prius Guru
    12,793
    5,275
    57
    I do and love it. But my Prius doesn't have USB, being one of the earlier 2010 models. So, it's aux in for me.
