Computed Average Does Not Match Actual Average
Discussion in 'Gen 2 Prius Fuel Economy' started by khazouri, Dec 6, 2009.
  1. khazouri
    khazouri New Member
    Well, I really spent the time trying to see if anyone has had this issue and I couldn't find it, so please accept my apologies if this issue has already been posted and addressed.
    The car is an '03. The readout on the screen routinely displays in the 48-55 mpg range, however, when I gas up and divide the amount of miles traveled by the amount of gas put in, it works out to about 10 mpg less? I realize this is not the most accurate way to determine mileage, but it should not be off by this much.
    Is there some kind of firmware upgrade I'm missing? Could my vehicle be totaling mileage incorrectly? I hav noticed when I use my GPS that the GPS routninely says I'm going 3mph FASTER than the car does. Is that a clue?
  2. chuckknight
    chuckknight New Member
    194
    33
  3. qbee42
    3,079
    :pound:
    I'm sorry for laughing, but this question is one of the most commonly discussed issues on this forum. There must be hundreds of posts dealing with this exact issue.
    Anyway, back to the question. The Gen II North American Prius has a fuel bladder in the tank. There are many good reasons for the bladder, but the offshoot is that the usable tank capacity is highly variable. There is no way to accurately calculate mileage on a tank by tank basis. The fuel bladder introduces too much uncertainty.
    If you want to do manual mileage calculation, the only way to do them accurately is over a large number of tanks. The tank to tank error will average out over a large number of tanks.
  4. ETP
    2,802
    1,170
    Auburdale FL
    yep! Bladder problems again LOL. The GPS trick is probabbly the best way over a long distance to do a cross check. Or 32 fill ups and then do a running average. I have been 1.5 gallons off on fill ups.
  5. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    For example after 13 tanks my calculated and MFD's lifetime MPGs differ by 2%. For the first two tanks the difference was 4%. :)
  6. khazouri
    khazouri New Member
    Hmm, well, yes I did see a lot about the bladder but I did not make the connection between that and the discrepancy. So, I guess we're saying that when I fill up and put, say, seven gallons in, my assumption that we burned seven gallons since the last time we filled up is prone tho being incorrect?
    Got it -- thanx for the help!
  7. qbee42
    3,079
    Exactly, and incorrect by a large margin. You can easily see a two gallon variation on a fill up, which is a lot for a tank that only holds ten or eleven usable gallons.
  8. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Or a 4.5 gallon variation...the last tank in ours. The bladder/vent system refused to allow more into the tank in 20 F weather. Level was reading about right at 5 pips after the abortive fill.
    That's twice...when it gets to three I'm going to get medieval on it.
  9. chuckknight
    194
    33
    I've had calculated numbers, over the last 8 fill ups, that range from 40.1 to 62mpg. My displayed mpg was 44-48mpg.
    One of these two is wrong.
    Given the enormous variation in calculated mpg, I expect that it's an inconsistent fill level, resulting in an inconsistent calculated mpg.
    Chuck
  10. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    Inconsistent fill and the bladder problem will create a discrepancy on individual tanks, but not for the long-term average (sorry Tom). Generally I notice in the fall the bladder is shrinking and my computed values beat the screen MPG, whereas in the spring the bladder expands and now it takes a little more gas on each fillup. But overall it averages out pretty close (I have the spreadsheet to show this, being an engineer).
    One thing that should be asked - do you have the original tires on the car? If they are a different size, it could throw off your computed value since your miles traveled won't be correct. I'm assuming the value on the MFD uses the flow rate or time duration the fuel injectors are on for each piston fire. If that's how the Prius computes it, maybe old/dirty injectors could be the problem - burning richer/leaner than expected.
    One thing I do is always try to fill at the same station, even the same pump that provides reasonable numbers. You never know if a gas pump is delivering exactly what it says it delivers. By using the same pump at least I'll have trends I can follow even if the baseline (DC offset in electrical terms) is not correct, but like I say, for me the computed average and MFD average is pretty close over the long term.
  11. nerfer
    2,507
    237
    28
    I'd blame the shutoff trigger on the pump nozzle before the Prius bladder in this case.
  12. Celtic Blue
    2,224
    139
    Midwest
    I wouldn't. I've never had this happen on any other vehicle. It's definitely the car.
  13. qbee42
    3,079
    I've had it happen several times on two other cars, but the Prius is more prone to it.
