Washed Key Fob
Discussion in 'Gen 2 Prius Audio and Electronics' started by rocketdoctor, Aug 23, 2008.
  1. rocketdoctor
    rocketdoctor New Member
    lafayette,ca
    I left the electronic key in my jeans and washed it. Amazingly it appears to still work. My worries are that this will damage the electronics and it will stop working while Im in the middle of nowhere. Anyone else with this experience?
    I have heard recommendations that when you wash something electronic you can try to put it in the oven on a low temperature to dry get out the moisture out. I was thinking I could do this with my food dehydrator. Has anyone heard of this? thoughts?
  2. LurkAzusa
    LurkAzusa Member
    231
    67
    Azusa, CA
    I washed mine, as well as putting it through the dryer. Works fine. I opened it up to the battery and it looked fine. I wouldn't worry about it. The heat would probably hurt the battery and electronics more than just air drying.
  3. CCC712
    CCC712 New Member
    22
    Nashville, TN
    I don't think I would stick it in the oven but you can stick it in a big cup/bowl of uncooked rice and it will draw the moisture out. This is what you're supposed to do if you drop your cell phone in water so it shouldn't be any different for the key fob.
  4. bsd43
    bsd43 Member
    130
    San Francisco Bay Area
    The key fob has a waterproof gasket at the battery. Don't know its exact specs, so don't go scuba diving with it, but the washer don't seem to kill it.
  5. flareak
    flareak Fleet Captain
    1,016
    St Louis, MO
    =D I went swimming with mine. Totally died. disassembled it and had battery juice gushing out of it. I set it out for a day on top of the television and I put it a new battery and it works just fine.
  6. TonyRN's08Prius
    TonyRN's08Prius New Member
    Phoenix, Arizona
    Funny, I just washed mine night before last, works great. Took it apart however to check battery, seems to be just fine. Live in Arizona, always dry, probable benefitted from a little moisture. :)
  7. debbiev
    debbiev New Member
    Los Angeles
    Hello. I washed my 2008 key fob. It still works (meaning the doors lock and unlock and the car runs), but when I leave the car, the alarm sounds. The only way I could get it to stop was to put the key in the slot.
    When I used my second key fob (brand new), everything worked fine.
    Is the washed one ruined? I really don't want to have to pay for a new fob and reprogramming ($325, I was told by the dealership).
    What can I do?
    Thanks!
  8. Sandy
    Sandy Hippi Chick
    860
    53
    Ocala,Fl
    Buy one on ebay for 20 bucks and program it yourself it pretty easy
  9. Sandy
    Sandy Hippi Chick
    860
    53
    Ocala,Fl
    always stick it in a bag of rice for a day and it will dry out
  10. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    58
    Fullerton CA
    But, if you put it in a bag / jar / pot of uncooked rice, FOR THE LOVE OF GOD, DON'T ADD THE WATER!
  11. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    check the fob battery. It may be low.
  12. direstraits71
    direstraits71 Member
    367
    65
    Central Coast California
    If this is done the smart key and buttons can't be programmed. You end up with a "dumb" fob that only works in the slot in the dashboard. That's OK if its what you want. Works fine for a spare/emergency key.
    See this thread or search "key programming" for more information.
    http://priuschat.com/forums/newbie-forum/74539-what-exactly-sks.html#post1037530
  13. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Sounds like the red button on the key fob is stuck. Try pressing it a few times (away from the car). It should feel & click the same as the lock/unlock buttons. The red light on the fob should flash when you press a button.
    If the rubber membrane that supports the button is damaged (and maybe leaking), then you might consider replacing the case. You'll need a donor case, such as the cheapest eBay key fob you can find.
