Bad RCA cables or bad wire run??
Discussion in 'Gen 2 Prius Audio and Electronics' started by KCobby, Feb 5, 2010.
  1. KCobby
    KCobby Member
    229
    74
    NYC area
    Hi guys-
    As some of you may know, I've been hunting down a high pitch noise in my new system lately. It only happens when the car was fully on (not in ACC mode.) And just this morning I checked the RCAs and the good news is that when I put a new cable in, the sound is gone. So at least I found the problem!
    But do I assume that the cables are bad (there are two) or do I assume that how I ran the wire was at fault. Is there a way to check the cable with a multi-meter? My amp is in back but I ran the RCAs on an opposite side of the remote lead, for precaution. However, I did run them very close to the hybrid battery. Would that cause any interference?? When I tested the new RCA, it was a different cable running straight from the amp in the back to the HU. So no snaking around next to other wires or batteries.
    The RCAs I was using were Kicker Z-series which I thought were supposed to be pretty good. (You can see them here)
    So I guess that's what makes me think that somehow the way I ran the cable is at fault.
    Opinions?? I'm glad to have hunted down the problem, but the prospect of running new wire...ugh. I didn't have fun with that last time. For those who have rear amps, how/where did you run the RCA wire??
    Thanks!
  2. McKeeius
    McKeeius New Member
    56
    Redwood City, CA
    Hey,
    I am having a similar problem with my new system. A really high-pitch whine, that I hear when I accelerate and decel. It is pretty darn annoying, the audio shop said they would put in a noise filter but F8L said that was a no-no. I am pretty sure they used new RCA cables, but not sure if this is a grounding issue or what to do about it. Let me know how your issue progresses.
  3. don_chuwish
    don_chuwish Well Seasoned Member
    821
    189
    Southern Oregon
    The Kicker RCAs don't look too bad, but what is the new one you tried? I'm pretty sure it's a routing issue more than a wire issue but it'd be good to know what you replaced the Kicker RCA with.
    Which side of the car did you route the RCAs? Did you keep them on the door sills along with the stock cable bundle? I'd suggest going along the floor, just below the door sills on the passenger side. You could also go right up the middle but it's a big carpet removal job.
    Where did you ground the PDX-5?
    - D
  4. KCobby
    KCobby Member
    229
    74
    NYC area
    The new RCA was just a RadioShack brand - clearance cable. It looks fine, but I wouldn't say it's any better than the Kicker. But I just don't know this cable very well, just sort of went with a few online reviews.
    I ran them drivers side: along the same line as the factory cable bundle, yes. The other side (passenger side) is where the remote lead is, but perhaps there is something that is causing interference in the wire bundle?
    I will try to get a picture of where I grounded the PDX amp. I thought I had seen a pic of yours actually that lead me to ground it in the same place. I want to say it's on a bolt that also serves to bolt down the hybrid battery shield. I'll try to get a pic. Where did you ground yours?
    I also noticed two other things today - one, when I accelerate, it gets worse, or rather gets a bit louder. Also, when I unplugged the RCAs, just touching the RCA metal to the outside of the connector on the HU made the sound quite noticeable! Better when plugged in (when fully grounded I assume) so that made me think that perhaps it's a grounding issue. But then, why wouldn't I hear it when the car is on ACC mode?? Why would it only come on when the engine is on??
    ejmckee - sounds like we have a similar problem! (Sorry...) If you find out anything, let me know. Hopefully together we'll figure it out and save others the trouble. Does yours also not occur when in ACC mode??
  5. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    The fact that you picked up the "Whine" indicates the ground/shield portion of the cable is not shielding properly. I have noticed that while the center pins of a RCA type connector are usually consistant in diameter, the ground lug outer ring I.D is not always the same. Make sure the outer lugs make firm contact with the mating RCA jack. I usualy bend the outer lugs slightly inward assuring a good electrical connection.
    Shielding does no good if it's not connected propely!
  6. don_chuwish
    821
    189
    Southern Oregon
    I had to do the same thing with one of my amps, the RCA was pretty loose otherwise.
    KCobby, if the RadioShack cable is quiet then it may not be related to your amp ground. Pretty much narrows it down to either a bad Kicker cable or problematic routing. Obvious next step is to try either routing the RadioShack cable the same way or reroute the Kicker cable and see if it clears up.
    Driver's side is where you see the big fat orange power lines from the traction battery. Give the passenger side a try, along the floor as mentioned before. No fun tearing the car apart again I know!
    - D
  7. F8L
    19,011
    4,083
    Grass Valley, CA.
    One simple way to check for noise in a cable is to run a new cable OVER your interior (instead of under the carpet near the chassis) and see if the noise goes away. If it does, then uninstall your old cable and try that cable ran OVER you interior and see if you still have noise through that cable. If you do then that cable is bad. If the noise goes away then you have either a cheap cable with bad shielding or your routing needs to be changed.
    I use Stinger brand cables (about $30 for a 17') and have not had noise in most of my vehicles or the ones we installed at the shop. A cheap $10 RCA is just begging for noise. :) Keep in mind that even an expensive brand and model of cable can be DOA out of the box.
    I run my RCA's on the passenger side of the car.
    As for noise filters. They can work but they can also degrade your sound. Shops tend to use them because it is much cheaper than troubleshooting a noise problem. i.e. it's an easy fix for them and they get to sell you another part. :rolleyes:
  8. McKeeius
    McKeeius New Member
    56
    Redwood City, CA
    I brought'er in to the shop and the noise filter did not do the trick- which I am glad b/c it sounds like that is a crappy way to fix it anyway.
    I called them up this morning and they said it was fine now. I will repost later on and let you know what the problem was.
    I was NOT getting the noise when ACC was on.
  9. F8L
    19,011
    4,083
    Grass Valley, CA.
    Aye, you should only experience noise when the engine was running. :)
    Glad to hear it is fixed. Please update us when you find out what the problem was.
  10. McKeeius
    McKeeius New Member
    56
    Redwood City, CA
    Ok so problem not entirely solved.
    From what I can gather they tried a combination of new cables, upgraded cables, amp and head unit - and could not figure out the noise. They seemed to think it came up only during the transition between the ICE and Hybrid battery (essentialy during accel). Anyway the whine is less audible and more tolerable - cant hear when volume is up, but it came with 2 noise filters to dampen it? They at least replaced the amp with a new one fwiw.
  11. don_chuwish
    821
    189
    Southern Oregon
    Just curious, where's your amp ejmckee? Under a seat or in the back?
    - D
  12. KCobby
    KCobby Member
    229
    74
    NYC area
    Also curious, are the RCA cables run on the drivers side or passenger side?
  13. McKeeius
    McKeeius New Member
    56
    Redwood City, CA
    The amp is in the trunk, something tells me the rcas are on the driver side but im not sure how can I check?
    I feel like I should just try to fix this thing myself since the people at the shop dont seem to have tried to reground the amp? Although I would need to read up on how to do it. I would really like to take care of the real problem of the whine and take off the sound filters...
  14. F8L
    19,011
    4,083
    Grass Valley, CA.
    The sill plates on the driver's side pop off extremely easily. That is how I would run the RCAs so I would check there first. Well I should say I would run them through the sill plate channel, but not on the driver's side. :)
  15. don_chuwish
    821
    189
    Southern Oregon
    Follow the ground wire from the amp, should be bolted down somewhere within 18". Same with the RCAs, they'll have to go from the amp towards the front of the car either L or R of the traction battery, you'll see which way they went soon enough.
    From there it's a matter of pulling trim and pulling back a little carpet along the edges of the door sills. Getting to the back of the HU is a pain tho, I must admit. So see if ground can be improved first. Use some sandpaper to rough the contact surface. I also used a star washer between the ground cable ring terminal and the car's sheet metal. The star washer has some teeth that bite into both a little. You can see my gray/black ground wire here:
    - D
  16. direstraits71
    direstraits71 Member
    367
    65
    Central Coast California
    Another source of whining noise can be through the +12V line into the amp. Usually an inductive filter on this line will clear this up. You may want to try that if there's not one installed already between the battery connection and the power input to your amplifier. You'd want the inductor installed as close to the amplfier as possible.
  17. McKeeius
    McKeeius New Member
    56
    Redwood City, CA
    Ok so here are a few photos to give you an idea of whats going on in there then maybe you guys can tell what you think.
    Here is the amp which sits on a board above the tools and the wires feed directly under it.
    Now you are looking at it as if you were under the amp and looking forward towards the seats. Here it looks as if the ground wire? black with pink tip is attached to a bracket?
    Now you are seeing the wire from the side.
    It looks like the RCA's (blue?) run to the driver side left, and there thick red wire runs to the right.
    Sorry Im so noob with this, I need to learn this stuff so I can troubleshoot these things.
    Here is a link to the album I am using in case that is easier because I seem to also be noob at linking photos
    http://picasaweb.google.com/ejmckee/CarPhotos?feat=directlink
  18. F8L
    19,011
    4,083
    Grass Valley, CA.
    Yeah, looks like they ran the RCAs on the driver's side. I would look into swapping sides and putting them on the passenger side. Maybe running so close to the high voltage hybrid cable is causing your noise. I caanot guarantee that but I have zero noise, not even a slight hiss between tracks and I ran mine on the passenger side.
    Thankfully the sill plates come off easy so the only hassle is removing the head unit to get access to the wires. :(
  19. don_chuwish
    821
    189
    Southern Oregon
    Agreed. I'm also not too crazy about including the traction battery case in the grounding point. Can't say for sure it's a problem but I wouldn't have done it (and didn't!). Otherwise, the amp looks nice and tidy in there, very slick.
    - D
  20. F8L
    19,011
    4,083
    Grass Valley, CA.
    Aye. I used the factory 12v battery grounding point for one of my amps. Forgot where I grounded the other. :)
