6.5 or 5.25" Speaker Size
Discussion in 'Gen 2 Prius Audio and Electronics' started by lex, Sep 26, 2010.
  1. lex
    lex 2005 Prius, always garaged
    119
    Fresno
    Discussion on replacement speakers here refers to the size as 6.5" yet on Crutchfield.com the Gen II Prius is listed as requiring a 5.25 set. Can anyone explain if either will work?
    Many thanks
    Lex
  2. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
  3. lex
    119
    Fresno
    Thanks, that's the infamous Sparky Guide I'd come across as well, in which the 6.5" speakers are used.
    I'm curious to know whether anyone on the forum has used the smaller 5.25" speakers??
    Thanks!
  4. gigabyte
    gigabyte Junior Member
    26
    oakland
    i wouldnt use a 5.25 speaker, it lacks the midbass that a 6.5 can deliver & is much needed in the prius.
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    +1 to what gigabyte said.
  6. F8L
    19,011
    4,083
    Grass Valley, CA.
    Although 5.25" speakers generally have better sounding vocals... I'd still get the 6.5"s or a set of 7"s. :) 7"s will fit easily using a custom wooden mounting ring.
  7. svitale75
    svitale75 Prius Addict
    39
    Hi Lex, I've used 6.5" on front for my 2009, not problems.
    I built my own wooden supports but there are several adapters out there. Check Scoche website for more.
  8. Wayne Thomas
    Wayne Thomas New Member
    2003 Prius
    Can you put some three way 8" in the doors of a 2003 Toyota prius
  9. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    I don't know about the 2003, you'd have to take the door panels off and run the windows down to see how much room you have. there are shallow mount 8"s that might fit, and with a spacer ring it's been done w/ the gen2. I had 7" woofers from parts express that fit nicely in the rear doors of my '04, but they wouldn't fit the front doors cause the window was too close. they hit pretty hard; with a kenwood ddx417 it sounded better than the JBL system in my 06.
