Siemens S66
Discussion in 'Gen 2 Prius Audio and Electronics' started by tullynoon, Oct 16, 2005.
  1. tullynoon
    tullynoon New Member
    57
    Port Angeles, WA
    Has anyone loaded a phonebook into a Siemens S66? Any problems or other comments re Bluetooth?
    Thanks,
    Patrick
  2. BigDave469
    BigDave469 New Member
    Castro Valley, CA
    Well, I have the Audiovox Sprint 6600 (6601 is the same w/o Camera) from Sprint. It is the same unit as the Siemens SX66, slide out keyboard, etc... I use it in my Prius, dials out and gets calls great... but NO phonebook transfer... it just locks up when I try to do it.
    Add that to the fact that when you are moving it locks up the display so you cant dial anything and you have to hold the pad in your hand to make a new call by dialing or have the numbers manually stored in your one touch, but than, only the number displays which is hidden, so you have to have a photographic memory of your one touch. Apperantly if you want to take apart your dash and cut some wire or hook it to a switch, you can get the BT to not go away when moving, but than your "wheels" on the display stop turning! Yikes! what a mess!
    But I love having such gripes... it is a great car!
  3. tullynoon
    57
    Port Angeles, WA
    Thanks; you saved me some trouble.
    Patrick
  4. tag
    tag Senior Member
    2,526
    Chicago
