Prius MPG Test!
Discussion in 'Gen 2 Prius Fuel Economy' started by Wayne, Oct 23, 2005.
  1. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    I recently did some fuel efficiency and speedometer accuracy tests on my Prius, and wanted to share the results. I've attached a detailed explanation of my tests for anyone who might be interested, but consider this an "executive summary".
    Fuel Efficiency vs Speed: First, I wondered just how much of a hit you take in fuel efficiency the faster you drive. As with ALL cars, the faster you drive, the lower your MPG will go. However, since the Prius has significant advantages over a normal car at slower speeds, you will see a wider swing in MPG as you increase your speed. Still, at the fastest, a Prius is still more fuel efficient than a normal car, so you can speed and still save money. ;)
    All that said, I'm still a big fan of treating the speed limit as a "limit". As I did the higher side of these tests, I found myself getting caught up in the competitiveness of speed, and found myself yelling at people who got in my way. I forgot how relaxing it was to be passed, instead of working to pass others! :)
    "Very generally speaking", you will get roughly 1 MPG of change for each MPH you drive faster or slower than normal. If THAT doesn't encourage you to drive slower, nothing will. :)
    Remember to check out the attachment for my specific methodology, but here are the results in a nutshell: You get about 5 MPG better mileage by driving 65 instead of 70. You can get a whopping 13 extra MPG by driving 55! Of course if that isn't the truck speed in your state, that's too slow. You will lose at least 4 MPG by driving 75 instead of 70. And you will lose a whopping 12 MPG by driving only 10 miles per hour over at 80. Of course getting almost 40 MPG at 80 still ain't bad, but you can do so much better! :)
    My tests, my conditions (sorry about the formatting):
    MPH MPG CHANGE % CHANGE
    55 63.1 13.2 26%
    65 54.8 4.8 10%
    70 50.0 ref ref
    75 45.7 - 4.3 -9%
    80 38.1 -11.9 -24%
    Note I found almost a 17 MPG variation between 65 and 80. Wow. Go 65!!!
    Air Conditioner Hit: The A/C is electric, so there is no immediate drag on the engine. However, the energy pulled from the batteries has to be replaced, which means the car has to stop using the electric engine for part of the torque and use it instead as a generator to recharge the batteries. I found little difference in MPH on the leg out, but -4.6 MPG on the leg back. The round trip average between the two tests was between -2.4 and -2.9 MPG lower, so expect a hit of a few MPG when you use your A/C.
    Speedometer Tests: I was going to list these results in a separate thread, but I see little need. The results were good, and as expected. Accuracy varied more by what precise speed I chose to engage cruise than anything else. There were the usual variations due to hills and valleys, but generally speaking the speedometer was always within 1 digit of the actual speed, favoring the higher side, as the US mandates.
    Attached are all the specifics. You will need Excel. Tabs at the bottom of the page will lead you through the file. The chart will be the first thing up. For those who are Excel-challenged, I've also provided the chart in GIF format. Enjoy!!
  2. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    Wow -- an hour later and it gets bumped off the first page with only 35 reads! I would have thought this info was of MUCH more interest. Oh well... :(
  3. roach52osu
    roach52osu New Member
    200
    Dublin, Oh
    I thought this was very interesting, to see the real numbers.
    Although I am still waiting for my Prius but around here most of my driving will consist of about 8 miles of city and 25 miles of freeway per day with averages on the freeway of about 60 (65 mph speed limit 55 trucks and construction, all the time). I will however take some trips that take me from 65 to 70-75mph limits/driving. I wondered how these speeds would impact the mileage but it doesnt seem so bad.
    My parents just made the trip I will make from time to time of about 900 miles each way and limits from 65-75 and they averaged about 45 mpg on a brand new prius on the way down (ohio to northern florida). I am impressed with this and happy to see your results are similar to what I was hoping for. Now if I can only get my gas guzler sold soon so I am ready for my new Prius...
    Thanks for the info Wayne
  4. NuShrike
    NuShrike Active Member
    1,378
    Change your board preferences to list more articles per page. :)
    Interesting results.. I've tried the same before for myself on the way home from work (12am-ish), with not much cars around, and I've found strange results with mine where sometimes I got better MPG at > 121Km/h than at 118Km/h or lower. It may have been the terrain, but it's difficult to find a nice predictable track of freeway to run around in SoCal.
  5. altaskier
    altaskier New Member
    157
    Long Island, New York
    Thanks for taking the time to make these careful measurements!
    I would have expected fuel use to scale with the kinetic energy of air displaced, at least at the high velocity end. Therefore it's of interest to re-plot your data as fuel used as a function of velocity squared. Excluding the 55 mph data, the fit is OK...[attachmentid=693]
  6. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    Results look pretty reasonable for my car at around 80 degrees, except for some reason I get less at 55 mph. I don't see temperature listed, but the effect is big.
    My general rule is 55 in winter = mpg of 70 in summer, this from reading someones graph posted a year or so ago. Foget what temps I looked at but I think I figured summer at 80 degrees and winter at 10 or so.
    I also notice a jump up in mpg when it rains light so the air is humid but roads aren't wet enough to add drag.
  7. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Very nice data. I only get up to highway speeds occasionally, but I am driving a bit slower now. The limiting rate is making people around me crazy!
  8. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    The temperature was listed in the methodology section of the spreadsheet. It was 68-73 degrees.
  9. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Wayne, this is good information, I'm glad you took the time to do this. I actually was hoping it would show no great penalty for speed because sometimes I drive to fast, but I'm not surprised at the results. I ordered a spoiler from Brian at BT Tech and plan on doing some before and after milage tests when it gets here.
  10. tullynoon
    tullynoon New Member
    57
    Port Angeles, WA
    Cool stuff. I'm going to give it a try too at temps from 80 down to 30 degrees and compare my data. Also, thanks for the spreadsheet.
  11. tomdeimos
    995
    Lexington, MA
    Thanks.
    Your car is about 2 mpg better than mine at most speeds. Hope mine is still breaking in.
  12. lbligh
    lbligh Member
    137
    24
    Northern Virginia
    Thanks for sharing. Very interesting indeed!
  13. pennyprius
    pennyprius New Member
    34
    I see that you discussed the milage difference with a/c on and off. Were the windows opened when the a/c was not in use. I am wondering if the c/d changes the mileage with the windows open at highway speeds. I notice some buffeting with windows open at highway speeds and would imagine that it dirties the c/d which would lower the mileage.
    But does it lower it more or less than the a/c does?
  14. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    Well, I can't say I know what "c/d" is (a backwards way of saying "drag coefficient", perhaps?), but I said the windows were always up in the methodology section of the spreadsheet. I'm sure you would get reduced mileage at highway speeds with the windows open, but I have no test data on that particular subject...
    Might have been worth another run! :)
    Edit: Just got to thinking, and my test was at "Max cold", or worst-case. On days where it would be comfortable to open a window you might find light loading from the A/C, so it may be better to run the A/C. When it is hotter you may not be comfortable with the windows open... My thoughts, anyway! :)
  15. pennyprius
    34
    c/d= coefficient of drag. Woudl be interesting to know the difference windows up vs. windows down. It could make a compelling argument to use a/c and keep the windows up.
  16. geologyrox
    geologyrox New Member
    513
    what i'd love to see is something like this that goes down a bit more - i'd like to see 45 and 50. i'm blessed with a regular route with speed limits of 40 and 45mph, and would like to know what i can expect with my new prius. we who don't have them yet have to live through you!
  17. AndyTiedye
    AndyTiedye New Member
    51
    You get better mileage at 70 mph than we get at any speed.
    I have not attempted to measure as precisely as you have, but just based on what the
    instrumentation shows at various speeds, our chart would look more like this:
    MPH MPG change difference from your results
    55 45 +3 +7% -18 -30%
    65 44 +3 +5% -11 -20%
    70 42 ref ref -8 -16%
    75 40 -2 -5% -6 -15%
    80 36 -6 -15% -2 -6%
    Tires at 41/40, temps around 65. No A/C or heat.
    2005 Prius II with about 5K miles on it. Built about a month before yours.
    Gas here contains 10% ethanol.
  18. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    Where is here?
  19. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    I wonder if it's the Ethanol... The octane is 87, right?
  20. AndyTiedye
    51
    Here is California, where they make up for giving us lousy gas by charging us an extra 50 cents a gallon for it. :wacko:
    Since our summer gas is already oxygenated like everyone else's winter gas,
    what do they do to our gas in the winter? add water?
    Yes, it all claims to be 87 octane.
