Is this normal?
Discussion in 'Gen 2 Prius Fuel Economy' started by FirstFlight, Mar 3, 2011.
  1. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    So I got my car today (2005) and I love it! :) I have some questions about it.
    When I was driving back from the dealership, I was watching the energy screen. The temperature was about 28F and it was mostly highway driving between 65-75 MPH.
    During the drive, I kept noticing the yellow arrows flashing on for 500mS, then go off, then come back on in a few seconds. I wasn't able to keep the yellow arrows on consistently. There didn't seem to any sequence to it, it just seemed random. The battery never dropped below 7 bars except when I was going slow and it was always green when I was going slow. Also, the only time the battery went to 8 bars was when I braked hard and that was one time.
    I would have thought the car would have used more of the battery to assist but at the same time my MPG was over 50 (51.1 to be exact) so I'm thinking this is normal. Is it?
    Overall, 50MPG for my first time driving it was really good to see.
    51,506
    forget your preconceived notions and browse some of the newbe threads to begin to get a real understanding of the car. welcome and all the best!
  3. macmaster05
    macmaster05 Senor Member
    4,050
    730
    Yes it is normal! The key is to not think so hard about it. The Hybrid Synergy Drive (HSD) is doing more things simultaneously than our minds can comprehend, so following every variable and arrow is bound to be confusing and make little sense. But trust the HSD!
    If you're getting over 50 mpg just be happy! Congrats on the new car!
  4. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    Gotcha. I guess there isn't anyway to use the electric portion of the motor more? I guess I just thought it would utilize more of the battery on the highway than just draining it one bar. Oh well, it's way more than my Jetta got. It's a 66% savings in my gas bill each month and when I drive 140 miles each day to and from work, that's a big savings!
  5. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    Yes all normal. Think of the HV battery as a Electric spring, the engine keeps it compressed about 80%, so that if it need more power it can release the spring, but not all the way compressed in case you hit the brakes hard and it need to absorb that. The yellow arrows are 'topping up' the battery just in case you need it.
    Now Toyota can size the engine to be efficient and not worry that it only has 76 HP. If you need more HP, the spring uncompresses to give it to you. If you never need more than 76 HP, it stays compressed. (Apparently ACME went out of business, and no one sells really big springs anymore)
    If Toyota let it get down to nothing, you would REALLY only have 76 HP and your car will be a turtle. Gen II does a good job of not being a turtle.
    If you run out of gas, and then drive a mile to the station on battery, once you add gas, it will be the slowest car you ever drove. Don't ask how I know this. [​IMG] (Never run out of gas)
    Now the paradox, the battery allows Toyota to sell a 76 HP midsized car knowing it will be fast enough for sane customers because of the battery power. But if you the customer want maximum MPG, you will minimize use of the battery and let the engine be efficient.
    Never hitting the brakes is more economical than regeneration.
    Never using the battery HP is more economical that converting gas to electricity to chemical reactions, then back to electricity and then rotation.
    But you will hit the brakes someday, and regen captures far more of that than disc brakes. You will need more power someday and about 35 more HP is waiting for that day in the battery. And on that day your MPG goes down a little. no Biggie, you needed the power.
  6. qbee42
    3,079
    You don't want to use the battery. The more you use the battery, the worse your mileage. Why? Think about it: all of the energy in the battery came from the gas engine, only you wasted some of it by converting it to electricity, changing it to chemicals in the battery, changing it back to electricity, and finally turning it back into mechanical energy with the electric motor. It's much more efficient to directly use the mechanical energy from the gas engine than to go through all of those conversions.
    The battery helps by allowing the Prius to work with a small and efficient gas engine, plus it stores some energy from regenerative braking, but it general you should be happy when the battery stays out of the equation.
  7. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    I reset my meter before I left for work this morning. The total distance is 36 miles. The temperature was 28 F. I stopped at the gas station near my house and the tires were at 33 psi. So I put them to 41 and 39.
    I got 56.4 MPG! I was only expecting 45 MPG when I bought the car and I can't wait until the summer to see if I will be able to break 60 MPG. I haven't even had the car for a full day yet but I've been reading these forums for a few months now and I think that's what helped me get the MPG's I'm getting now. This car has 120K on it and I hope to keep it for another 300K. :)
  8. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Hi FirstFlight. It uses the battery more at low speed. Try to use the battery to keep the engine off when you're traveling at low speed and when the grade is slightly downhill. However try not to let the battery deplete too much before the engine cuts back in, otherwise it uses too much gas trying to recharge the battery all the time.
    BTW. I've also got a secondhand 2005 model and I get almost exactly the same mileage as yourself. Typically 54 to 57 MPG. :D
  9. Oldwolf
    Oldwolf Prius Enthusiast
    825
    110
    NC
    2016 Prius v wagon
    This is very informative thread and timely for me since I am probably going to get a 2005 Prius soon too.
    I never conceptually viewed the battery as spring until now, but the analogy helps. Plus, until now I thought of the battery/ice as equals, but now I am beginning to see it as an assistive energy source to a very efficient engine.
    I still have a lot to learn.
