Another mpg vs. Pip problem
Discussion in 'Gen 2 Prius Fuel Economy' started by GasSippr, May 19, 2011.
  1. GasSippr
    GasSippr Junior Member
    56
    Cincinnati
    I've had my 2007 Prius for about 3 weeks now. I've noticed that while my computer is saying I'm getting 50 or so MPG my pips are disappearing at around 30 miles on my odometer. I've read on this forum that the fuel gauge can be inaccurate but THIS inaccurate??! Anyone having a similar experience? Any help greatly appreciated!
    Thanks.
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    I'm not sure what the "problem" is. Are you saying you've lost 1 pip after 30 miles or each pip goes away every 30 miles? How is that a "problem"? I've had the considerable variance on how long it takes for the 1st pip to go away, esp. if I refill/top off while it still indicates "full" or is nearly "full".
    We call it the "guess gauge" here. Examples of what I would consider a problem are, if you run it down to 1 pip and can't put in much gas (say 5 gallons) or you somehow run out of gas with it indicating some value above empty.
    Perhaps http://priuschat.com/forums/other-cars/94001-gas-gauge-says-full-but-thats-not-quite-true-npr.html would give you a little more perspective.
    It is possible the inclinometer might need to be reset (http://priuschat.com/forums/gen-ii-prius-main-forum/8123-gas-tank.html#post1073746). However, I'm not convinced yet that there's any problem or that you should muck w/that yet.
  3. brick
    brick Active Member
    1,083
    79
    Upstate NY
    Yup, pretty much all of us. How much fuel the gas tank holds depends on outside temperature. When it's warm the internal bladder is more flexible so you can squeeze more in, and the opposite is true when it's cold out. I have seen the first pip go as soon as 10 miles after a fillup or as long as 160mi during the peak of summer.
    One of the many things I use my scangauge for is as a better gas gauge. It can read the level directly from the tank from 0 to 100% in 2.5% increments. It isn't a perfect solution, either, since that raw readout is not corrected for inclination. But I prefer it to the silly pips.
  4. bisco
    51,961
    'my pips are disappearing at around 30 miles' sounds like a different issue to me. i would run it by the dealer and see what they think. in the meantime, fill up more frequently so you don't run out of gas. that can be a real humbug.
  5. PriusSport
    PriusSport senior member
    1,498
    88
    SE PA
    Just go by the electronic mileage and fill up every time the tank gets down to half full.
  6. brick
    brick Active Member
    1,083
    79
    Upstate NY
    Yeah, that's a good point. This is where the scangauge would be useful to see what the actual sensor is reading. If the pips are way off of what the sensor says (like 3 pips left but the float is reading 65%) then it might well be that the inclinometer needs to be recalibrated.
  7. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    The OP needs to clarify what the issue is (if any). I'm not clear if he saying that his 1st pip goes after 30 miles or if they ALL disappear after 30 miles.
  8. macmaster05
    macmaster05 Senor Member
    4,050
    730
    This is what mine is usually like
    1st pip gone @ 90 miles
    2nd pip gone @ 120 miles
    3rd pip gone @ 150 miles
    4th pip gone @ 180 miles
    5th pip gone @ 220 miles
    6th pip gone @ 260 miles
    7th pip gone @ 310 miles
    8th pip gone @ 360 miles
    9th pip gone @ 410 miles
    flashing @ 440 miles
    Richard Pérez, danboy and GasSippr like this.
  9. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Here's what mine looks like (approximately). Note there's no bladder and the distance is in km.
    1st pip drops @ 245 km
    2nd @ 330 km
    3rd @ 415 km
    4th @ 500 km
    5th @ 585 km
    6th @ 670 km
    7th @ 755 km
    8th @ 840 km
    9th @ 930 km
    Flashing @ 980 km
    Refill approx 42 Liters
  10. GasSippr
    56
    Cincinnati
    Ok so the only "problem" is if i'm not truly getting the 50 mpg that my computer tells me. I think that getting 30 mpg is a problem.
  11. GasSippr
    56
    Cincinnati
    Each pip disappears after 30. I've had five pips disappear after 30 miles for each one.
  12. bisco
    51,961
    so fifth pip = 150 miles driven?
  13. GasSippr
    56
    Cincinnati
    So i'm going to try and fill the tank and then keep track of how many miles I get with my odometer. The next time that I fill it up thereafter I will divide the number of miles by the number of gallons put in to get my "true" MPG. If the pips are still screwy I may look at having the recalibrating done on the inclinometer. Thanks everyone for the replies!
  14. GasSippr
    56
    Cincinnati
    That's right.
  15. bisco
    51,961
    i think you're getting it. but try to understand, the pips don't have anything to do with your mileage. it's the tank bladder, the outside temperature, the fuel pump you're using and your particular cars idiosynchrosies that are affecting your pips. ignore them and concentrate on your manual math calculations as you mention above.
  16. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    How are you determining that you're getting "30 mpg"?
    Yes. You need to do that. You also need to average about the values over many tanks (may as well do it for the MFD values as well). You will frequently find considerable variance between the two for a specific tank but will find that when you average them, they're very close.
    Example: MFD could read 45 mpg yet your manual tank calculation might show only 40 mpg. Then, on the next tank, it could be the reverse.
    Exactly!
  17. macmaster05
    4,050
    730
    ^A whole post from Andrew without one hyperlink. Haha! :thumb:
    Yeah whatever they said.
  18. GasSippr
    56
    Cincinnati
    So I've calculated my TRUE MPG and getting about 52 MPG!! I'm thrilled!
    The gas gauge truly is a "guess gauge" as this time around I got 120 miles for the first pip, then 40, 70, 30, etc.... I went a total of 365 miles and still had 3 pips left. I put in about 7 gallons of gas so 365/7 = 52.14.
    So, I will no longer trust the pips, but rely on the trip odometer before filling up at probably 400 or so miles as others have suggested.
  19. bisco
    51,961
    well done.
  20. brick
    brick Active Member
    1,083
    79
    Upstate NY
    Just don't rely on the odometer when it starts to turn cold again. Our fuel tanks are less flexible in cold weather, and hold less fuel as a result. You should still fill up when the gauge reads low.
