Did i break my gas tank float????
Discussion in 'Gen 2 Prius Fuel Economy' started by just_older99, Jun 29, 2011.
  1. just_older99
    just_older99 New Member
    24
    hamilton,ontario canada
    I was wondering if this happened to anyone before and am i looking at to replace my gas tank.
    For the past 4 months in my 2007 prius filling up gas has been the same, i usually wait until the last pip stats to blink and i fill up. Its always the same, it takes roughly 34L of gas give ot take which means that roughly 11L remain in the tank. i usually go until i get 2 or 3 clicks in the pump and stop.Well i was travelling to a tennis tournament of mine and had to fill up, the last pip just started to blink so i pulled off the highway and filled up at a local station. It click at roughly 34L like always and i was going for a click or 2 more, but for some reason this time when i began fuelling again i didnt pull the trigger all the way, gas was going in and i was talking with someone else pumping gas. It felt like 2 mins of pumping when i looked up and saw the gas was at 39L. I pulled out the nozzel and gas started to pour out. It finally stopped flowing out and was full right to the top, i put the cap back on clean the car the best i could and went to play tennis. I have now travelled 303KMS and i have all my bars on my fuel gauge. I roughly loose a bar around 150-180KMS depending on who drives the prius. So my question is either im about to break my MPG record by a landslide or did i screw up the float and need a new tank?? Any advice or suggestions is appretiated.
  2. ystasino
    ystasino Active Member
    793
    Tucson, Arizona
    Not sure if the Canadian Prius cars have a bladder to reduce CO2 emissions, which would make your tank volume fluctuate depending mostly on temperature. People here claim that is a sensitive system and that repeated overfills will lead to tank bladder replacement. There's a sensor that might get damaged, but it would give you an error code.
    If that system does not exist then I don't think there would be anything to damage.
  3. qbee42
    3,079
    You can't break the float from overfilling. You can screw up the emission controls, but if you do that it will throw a code.
    Relax, drive your car, and let it burn off the excess fuel.
  4. just_older99
    24
    well finally after 310 kms the i lost my first bar of gas. Thanks for your reply and i will do just that and drive like normal..
  5. danboy
    danboy Junior Member
    56
    brooklyn ny
  6. uart
    uart Senior Member
    4,220
    1,209
    Australia
