Compressor mode
Discussion in 'Gen 2 Prius Audio and Electronics' started by KMO, Nov 15, 2005.
  1. KMO
    KMO Senior Member
    1,807
    585
    Finland
    2023 Prius Prime
    Hello folks. I've just been reading the repair manuals, and was having a closer look at the dealer-customisable parameters. Has anyone gotten their dealer to change the COMPRESSOR MODE setting to MANUAL?
    I'm tempted to get them to do this, as I'm annoyed with the system enabling the A/C compressor when I press the steering wheel AUTO button, but I want to check what I'd be asking for.
    In detail, the current transitions with the AUTO button are:
    AUTO (with A/C) -> OFF -> AUTO (with A/C)
    or
    AUTO (without A/C) -> AUTO (with A/C) -> OFF -> AUTO (with A/C)
    The behaviour I'm looking for from the AUTO button is:
    or
    AUTO (without A/C) -> OFF -> AUTO (without A/C)
    Is that what the MANUAL mode gives you?
  2. KMO
    KMO Senior Member
    1,807
    585
    Finland
    2023 Prius Prime
    I'm going to bump this once. Surely someone out there must have gotten their dealer to do this? What about any of the other customisations?
    Another question - how permanent are the customisation settings? Are they lost if the 12V battery is disconnected?
  3. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    I tried to have my dealer turn on passive mode for the alarm. They obviously didn't know what they were doing, as they claimed it took 2 hours to do it.
    I hated it, but fortunately I found a dance so I could put it back to active mode.
    Before you ask, there is no such dance for what you're asking though.
  4. KMO
    KMO Senior Member
    1,807
    585
    Finland
    2023 Prius Prime
    I take it that means the settings aren't lost when the battery is disconnected?
    I only ask because it would no doubt be a hassle to get the dealer to understand what I want them to do, and there's no point if it gets lost the next time some service monkey (or I) disconnects the battery.
  5. aaf709
    3,862
    2022 Prius Prime
    I understand that some defaults, like the reverse beep, comes back on when the battery has been disconected.
  6. galaxee
    galaxee mostly benevolent
    9,810
    468
    MD
    KMO- when my husband brought home a scantool for a job he was doing over a weekend, we played around with that setting for the exact reason you want to change it.
    unfortunately, no it doesn't do what we had hoped. what it does is uses the a/c compressor to dehumidify the air that it uses to defrost the windows- or something like that.
    after changing the setting, i was immensely disappointed to find that it still turns on auto a/c when turning off the defroster with the steering wheel. :( so we changed it back.
  7. KMO
    KMO Senior Member
    1,807
    585
    Finland
    2023 Prius Prime
    Galaxee,
    Are you sure? According to my (UK/Australia) manual, there's a separate setting "COMPRS/DEF OPER" that sounds like what you're describing: "Function to turn the A/C ON automatically linking with the FRONT DEF button when the A/C is OFF".
    The "COMPRESSOR MODE" says "Function to turn the A/C ON automatically by pressing the AUTO button when the blower is ON and the A/C is OFF".
    Maybe I'll ask on Yahoo Prius_Technical_Stuff - some folks on there might have scantools they can experiment with.
  8. DanMan32
    3,799
    27
    Tampa Bay, FL
    KMO is right about there being 2 different options. At least we in the NA have the same option in our documentation.
    Galaxy, take a look at page 5-1266 (1430) and see what we are referring to.
  9. KMO
    KMO Senior Member
    1,807
    585
    Finland
    2023 Prius Prime
    FYI,
    I've had a reply from someone on Yahoo Prius_Technical_Stuff that turning COMPRESSOR MODE off does do what I want - it remembers the "A/C" state from when the climate control was last on. He describes it as effectively becoming an independent setting that the AUTO button doesn't touch.
    I'm still not clear on the battery disconnection though.
