VAIS AIC-100i / SLI mode selection
Discussion in 'Gen 2 Prius Audio and Electronics' started by KMO, Nov 22, 2005.
  1. KMO
    KMO Senior Member
    1,889
    645
    Finland
    2023 Prius Prime
    Okay, I'm tempted. But...
    From what I've seen of the VAIS SLI documentation, the device presents itself as a MD Changer, and inserts itself into the CD button cycle, so you can switch from CD->Tape->MD->CD.
    But it VAIS' site also shows it as having a toggle so that you either get the iPod or Aux input to the SLI box on alternate selections. Isn't that mind-bogglingly annoying if you don't have anything attached to the Aux input (as I suspect most people don't)? Or can you tell it to ignore the Aux input?
    Also, does anyone know if there any issues with shipping the unit to the UK (and fitting it to a UK-spec, right-hand drive car)? Are there any non-American folk here who have fitted it?
  2. jwdberlin
    jwdberlin New Member
    Berlin, Germany
    It works in my German Prius.
    Johann
  3. mbarrows
    mbarrows Illini Bird
    210
    17
    Frankfort, Illinois
    Mine is supposedly coming today via UPS. Once I look at the instructions and install it, I'll see if I have an answer for you.
  4. naterprius
    naterprius Senior Member
    1,843
    It is a bit annoying, but the ipod control makes it worth it. Maybe there is a way to eliminate the Aux from the selection? I'll have to ask vaistech.
    Nate
  5. BobR
    BobR Member
    336
    It was a little annoying at first, but I'm very used to it now and don't find it an issue at all.
    It would be great if there was a way for the aux input to only be present if cables are connected to it.
    Using a FM Transmitter is Mind-bogglingly annoying. Having to cycle through to the iPod is a little inconvenient.
    Bob
  6. mbarrows
    210
    17
    Frankfort, Illinois
    Bob,
    Sure:
    Mike
  7. BobR
    BobR Member
    336
    It looks like the correct cable to me.
    Bob
  8. mbarrows
    210
    17
    Frankfort, Illinois
    No Bob, it isn't. It will not fit in the plug where the existing connector is. I wish I could get a picture of the plug that was pulled out but it's too far under the dash to see well or get a digital shot of. If you look in the VAIS AIC-100i installation instructions, it shows a plug that DOES fit. The existing plug on the head unit is more rectangular & flatter.
  9. BobR
    BobR Member
    336
    Unless you have an external changer or Satellite radio, there should be nothing in the connection on the radio.
    This is what it should look like:
    [attachmentid=949]
  10. mbarrows
    210
    17
    Frankfort, Illinois
    This is what my plug looks like after I pulled it out (first socket):
    No external changer; no satellite radio. The directions say it plugs into the first socket and not the second. Your picture seems to show the second socket; is this correct?
  11. naterprius
    1,843
    Yes, that is the right connector. If you don't have XM, Sirius, or an external CD changer, the port is open on the back of the stereo. Let the male version of the plug hang loose behind the dash, plug the female portion into the radio.
    FYI: Gender is determined by pins, not be pin housing.
    Nate
  12. mbarrows
    210
    17
    Frankfort, Illinois
    Nate,
    There is an open port but it's the second port and the directions indicated pulling the plug out of the first port. Which port does it connect to?
    Mike
  13. BobR
    BobR Member
    336
    You don't have to unplug anything, unless you have an external changer or sat radio.
    Just plug the cable into the open connection.
    Have you read Craig's instructions?
  14. mbarrows
    210
    17
    Frankfort, Illinois
    Bob,
    Yes, I used Craig's directions with the exception of where the VAIS directions say to unplug the first connector and install it there. Well, this is wrong! Craig's directions are correct where you don't have to unplug anything. The unit works fine and I want to thank you, Nate & Craig for the help. Ironic, PriusChat.com has the correct instructions and VAIS has incorrect ones.
    Thanks everybody & Happy Thanksgiving.
    Mike
  15. ScubaX
    ScubaX Member
    484
    Redding, CA
    I'm glad it all worked out for you. Mine is on the way back to me with the flash upgrade to 3.5.
    So not only did you get the SLI version, you got it overnight UPS. Mine is coming via ground ups and due in about a week! Oh well, I will hopefully never need anymore flash upgrades on it anyway.
  16. BobR
    BobR Member
    336
    Good to hear it is working.
    I'm interested in seeing pictures of the SLI. Could you post a photo album on line?
    Regards,
    Bob
  17. mbarrows
    210
    17
    Frankfort, Illinois
    Thanks again Bob.
    From what I can tell (and I've never actually seen a real AIC-100i) the SLI and AIC-100i are very similar. The SLI has an integrated sound grounding loop adapter in it. It also has two "dip" switches for either "CD" or "MD" mode emulation (which you have to set once installed; mine is in "CD" mode emulation as I think it displays more text - song title, etc.). There is a electronic sound level adjustment you can do on the iPod so that the volume always starts at a preselected value (1 to 31). The case appears to be an aluminum one held together by screws and can be opened. There is a service port (covered) which I believe VAIS can use for firmware upgrades. As I found out, their installation directions are incorrect as they show plugging their unit into the first head connector when really it's the second one (arrow is pointing to wrong head connector).
    Bob, PM me your e-mail address and I'll send you the album of SLI pictures.
  18. mbarrows
    210
    17
    Frankfort, Illinois
    Bob,
    Here are the pictures:
    Mike
    PS - I put the unit in the glove box.
  19. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    not sure if yours works like mine, but i do have an aux connected (2 ipods) and i switch between the two by hitting the disc button on the front of the stereo. much easier than rolling around using the steering wheel buttons.
  20. BobR
    BobR Member
    336
    This is a much better way. I can't believe I've been cycling through to get to the iPod all this time.
    I don't know why I never thought of this. Thanks for pointing it out!
    Bob
