XM modulator or satelite ready radio
Discussion in 'Gen 2 Prius Audio and Electronics' started by kente777, Dec 3, 2005.
  1. kente777
    kente777 New Member
    194
    NW Florida
    Should I install an XM satelite-ready radio or should I just go with a modulator? Is there a difference in sound quality?
    Ken
  2. frankie_delaware
    frankie_delaware Junior Member
    51
    Southern California
    I have the XM Roady, the earlier model with the the external modulator, and considering I only paid $50 for it at the time, and I can easily move it from car to car, I am very happy with it.
    It's important to note that XM audio isn't CD quality. I believe the bit rate is 48kbs, and the high frequencies are noticeably flat. So, even with a satellite-ready radio and a high-tech sound system it won't sound like your CDs. That said, though, the sound would be a little better using a direct audio connection (like the '06 aux input) or a satellite-ready radio than the modulator.
    The effectiveness of the modulator depends on the sensitivity of your radio, the strength of the local stations, and the orientation of the car FM antenna compared to the modulator. Most of the time mine works OK, but occasionally I notice some dropout and static, especially in my manual shift car when I move towards and away from the modulator as I shift.
    The location of the satellite antenna is another consideration. I have no problems putting the antenna inside the car on the dash, but I live in an area with few hills or tall trees. A satellite-ready radio installation will have an external satellite antenna, which might be better for your terrain. Of course, you can put the Roady antenna on the outside of the car, too, but that is more trouble than just popping it onto the dash.
    Hope this helps...
  3. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    Well, if you've got the money, how about one that is integrated with your Prius's radio, the MFD, and the steering wheel controls?
    www.priusxm.com
    www.metrotpn.com
    It's the Toyota factory XM radio for the Solara, but it can be installed in a Prius. I hope to have one by the end of the month. The cheapest I've found is at www.metrotpn.com, which is the parts website for the Metro Toyota dealership in Cleveland. They provide a PDF with installation instructions.
  4. benighted
    benighted New Member
    530
    Westport, WA
    I bought the coastaltech kit and the sound quality of XM is no better than FM without some of the static.
  5. 925PriusGuy
    925PriusGuy Winter Gray & Blizzard Pearl Pri
    148
    Northern California- SF East Bay
    I have the XM kit from www.metrotpn.com with the antenna hidden in the rear spoiler. I agree that the sound quality is not up to a CD..but the JBL system isn't exactly concert quality either. I've tried the FM modulators without much luck,
    I'd install the Totota XM kit if you have the time and $...
    The best thing about XM to me is the variety.....not the sound quality and I was going for an intergrated discreet setup so I chose the factory kit...also if portability is an issue, obviously the Toyota kit won't be a good fit for yor needs.
    Good luck, either way :)
  6. IndyDoug
    IndyDoug New Member
    120
    Indianapolis, IN
    If I order a factory Toyota Sirius or XM receiver from my local Toyota dealer will they also do the install? Life would be so much easier if this was the case.
  7. benighted
    530
    Westport, WA
    Any dealer will install it for a hefty fee. Look around your local stereo shops (like Car Toys) and see how much they will install it for, probably about half of what the dealership will charge you.
  8. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    How did you get the antenna in the spolier? Did you use the antenna that came with the unit? Any cutting or drilling involved? How's the reception?
  9. 925PriusGuy
    148
    Sorry All,
    I've been away from the board for a day or so... Nate (naterprius) created an excellent guide for installing an XM antenna into the rear spoiler...here's the link to his post last year:
    XM Antenna spoiler install
    It was quite easy, once you get over using a dremel on your Prius...the spoiler is plastic and is easy to work with. The reception is fine and you need to purchase a smaller XM antenna to install in the spoiler.
    Let me know if there are any questions. Thanks to Nate for the guide...I just followed his lead on this mod.
  10. Twiddles
    Twiddles New Member
    47
    Downstate NY
    Really? I have the Pioneer xm2go airwave portable radio and take it in the car and use the wireless built-in fm modulator. It works great, just as good as the cassette adaptor and never any static.
  11. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
    I've got the integrated Sirius tuner in my Prius, and the sound quality through it is light years ahead of that using an FM modulator or cassette adapter. I've got a Sirius Sportster too and have made the comparison against the integrated unit. The sound quality through the FM modulator is so bad that I would rather just not listen to it.
