2006 Prius data analysis
Discussion in 'Gen 2 Prius Fuel Economy' started by TheForce, May 24, 2008.
  1. Flying White Dutchman
    4,376
    314
    i do a upper grill block even now in the higher outside temp. and my ice is warmed up in just a few min.
    so i dont see the need to do that .. just on and off.
    or maybe 2 resistors connected by 2 relays. one for high and one for low.
  2. TheForce
    3,461
    537
    Wheelersburg, Ohio
    April's data is now posted.
  3. TheForce
    3,461
    537
    Wheelersburg, Ohio
    May's data is now posted.
  4. TheForce
    3,461
    537
    Wheelersburg, Ohio
    June's data is now posted.
  5. TheForce
    3,461
    537
    Wheelersburg, Ohio
    July's data is now posted.
    August will be my last logged month.
  6. TheForce
    3,461
    537
    Wheelersburg, Ohio
    August data is now posted.
    I will no longer be capturing data unless I feel like capturing data on specific situations.
    I will still be updating my fuel log when I fill the tank up.
  7. Flying White Dutchman
    4,376
    314
    thx for logging...
  8. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Fill up log is updated 2009-12-04
  9. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Fill up log is updated 2010-02-06
  10. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Fill up log is updated 2010-07-19
  11. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Fill up log is updated 2010-07-12
  12. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Fill up log is updated 2010-12-23
    I'm no longer providing an XLS version of the fill up log. Sorry.
  13. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Fill up log is updated 2011-03-21
    I have 50,534.5 miles on my Prius now. :D 28,665 of those miles were the regular Prius and 21,869.5 miles is with the Hymotion battery.
    So far I have not had any major issues. The only problem I currently see is with my last oil change. The oil report said I had high fuel dilution in the oil. My guess is that it was caused by running extended EV mode without letting the engine get to proper operating temperature. You can read about it here. http://priuschat.com/forums/prius-p...ic-vehicle-use-high-fuel-dilution-in-oil.html
    By the end of this year or the beginning of next year I will have a 50/50 view on how the regular Prius compares to one with the Hymotion battery installed.
  14. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Fill up log is updated 2011-05-21
  15. Spcalan1
    Spcalan1 New Member
    104
    Flowery Branch, GA
    How did you collect this data - like RPM?
    Do you have a scanner?
  16. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Fill up log is updated 2011-07-07.
    My Hymotion battery died on this tank. :( Its still under warranty so it will get replaced. :)
  17. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Fill up log is updated 2011-07-25.
  18. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Fill up log is updated 2011-08-02.
  19. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Fill up log is updated 2012-01-14.
    One more tank and I'll have 50% hybrid and 50% plug in hybrid miles on the car. :D Look for a 50/50 comparison review in the next few months.
