What's the newest DVD nav update for a 2005?
Discussion in 'Gen 2 Prius Audio and Electronics' started by EkS, Feb 22, 2011.
  1. dipper
    dipper Senior Member
    1,242
    252
    Are these files still available anthonylokrn?
  2. homenet
    homenet New Member
    ca
    I have a 2005 Prius with original Nav disk.
    I used Emperex Dual DVD writer on XP. I used Windata DVD+R DL disks.
    First I copied the content of the org nav disk on my hard disk. Then I used Imgburn to create iso file. Then I sued Imgburn to make the copy. I did not use any other options in Imgburn such as Book type etc. I simply loaded the iso and hit the burn command to burn the disk.
    It worked the first time.
  3. anthonylokrn
    anthonylokrn Member
    119
    Sorry I don't check back very often. Files are still online...
  4. dipper
    1,242
    252
    Are you sure? The rar files are like 10k size instead of the 700mb. This is even after paying the month fee for the site.
    Regardless, I bought the new v11.1 2 weeks ago.
    Hope someone can benefit from what I found was wrong.
  5. anthonylokrn
    anthonylokrn Member
    119
    Yes...
    I just double checked all of the files and they are 700MB EXCEPT for the very last file for each version which will vary.
    Try using a different browser and/or download manager. I recommend JDownloader.
  6. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
  7. cooljw
    cooljw Member
    183
    46
    Yep, my experience too with regard to the Gen5 NAV being unable to read burned discs. I myself made many coasters before I got to the point where I believe this is absolutely true. Very frustrating that it only seems to affect the Gen5 NAV in the Prius. Other Toyota and Lexus vehicles with Gen5 NAV seem to read burned discs just fine.
    Also, if you load a burned disc the NAV may update some firmware that gets rid of the nag "Agree" screen at the beginning. However, that is all it will do and the maps on the burned disc will not work.
    There was some discussion somewhere about swapping out the DVD drive in the Prius with a drive that can read burned discs. Anyone try this and get it to work?
  8. mycotopian
    mycotopian New Member
    Are there issues with reading discs between the different generations?
  9. homenet
    homenet New Member
    ca
    I followed the instructions for burning a dvd for my Prius 2005 for 10.1 upgrade. The DVD burned ok and was able to install in my system. It read OK and my nav system recognized it and I can see the updated maps.
    Only issue I see is that when I try to setup a destination and click the Address button on the screen, nothing happens. it does not give me the next screen to enter the address.
    I can go to the map and manually route and works.
    Any idea or help in this regard?
    Thanks.
  10. anthonylokrn
    anthonylokrn Member
    119
    Toyota/Lexus Navigation v10.1 for Gen6 North America uploaded!
  11. vijianand
    vijianand New Member
    Johns Creek, GA
    Hey Guys,
    I have Prius 2010. Is there any update available?
    Regards,
    Anand
  12. Donut014
    Donut014 New Member
    Ontario
    hey ANTHONYLOKRN , can you please re post TOYOTA/LEXUS NAVIGATION V10.1 FOR GENERATION 4 , on rapidshare? your filesonic files have been removed, thank you soo much, you can email me at doan.an.chau@ gmail.com for faster replies =], ive been searching around and yours seems to be like the only one that works:)
  13. BoostedTimmy
    BoostedTimmy Junior Member
    34
    Charlotte
    I'm about to try a back up of a GEN5 11.1 disk that supposedly will work in my 2005. If it works I'll help you find it as well. :)
  14. BoostedTimmy
    34
    Charlotte
    Okay Gen5 v11.1 works in my 2005 Prius with just a couple of quirks. The screen is blank if you try to look at coverage area and the "data version" is blank, but 11.1 shows up in the maps version and my parents address which previously did not come up shows up great.
    If you wanted to find this disc to make a back up of your purchased one I would recommend searching for "lexusnavgen5usa2k11" in your favorite search engine :) It should be 7-8gb.
  15. Donut014
    Donut014 New Member
    Ontario
    hey thanks ill try that out =]
  16. Donut014
    Donut014 New Member
    Ontario
    hey can you repost the links again possibly on rapidshare please? because filesonic doesnt allow sharing anymore, only the person that uploaded is allowed to access those links now, can you post the gen4 v10.1 please =) ,
    thank you so much! , if you can email me directly that would be great,
    [email protected] :)
  17. guod
    guod New Member
    24
    Los Angeles
    so can we put the new looking GUI with the black and blue high res graphics on the OLD 2004 nav system? i changed my head unit and do not use the maps or anything like that, but I would like to have nice graphics for climate and things like that
  18. Pandalover
    Pandalover Junior Member
    82
    UK
    Anyone got western Europe?
  19. johnhnhn
    johnhnhn Junior Member
    17
    Albuquerque
    I got a DVD from them.
    TOYLEXNAVDVD.COM
    It is a pirated copy and it does not work. They list no phone number or address on their web site or on any of their receipts. They do not respond to Emails. I paid USPS tracking to deliver it back to the address on their shipping box. And, I am in the process of disputing the charge on my credit card.
