110 VAC inverter installation
Discussion in 'Gen 3 Prius Technical Discussion' started by bwilson4web, Jul 14, 2012.
  1. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    Maine
    It already does. The whole reason I put the inverter in my Prius is to able to leave the car running, and power my house when the electricity is down (which, for me, is often, and for extended time periods, (sometimes up to a week at a time)).
  2. bwilson4web
    16,195
    I agree and in theory, we could be looking at a peak power of 18 kW and sustained power at any level in between.
  3. Corwyn
    2,171
    659
    Maine
    Yes, modified sine-wave. 1500 watts. 83% efficiency. No power outages since I got it in December (which is worth the price in itself). Mine has LED read-outs.
  4. bwilson4web
    16,195
    So I re-read the manual for the PWRI150012S:
    Column 1
    0 [th]CP[th]SP[th]Eff[th]THD[th]NL[th]cable[tr][td]1500W[td]3000W[td]>85%[td]<3%[td]1.0A[td]4AWG
    Source: http://www.aimscorp.net/documents/PWRI150012S.pdf
    Going over the limits:
    • Low input voltage - 9.8-10.2V - after auto shut down the red FAULT light illuminates. My VOM has a minimum and maximum voltage hold function so this should be easy enough to measure.
    • Low output voltage, 106Vac - after auto shutdown, the red FAULT light illuminate. I measured with my Kill A Watt P4400, a true RMS voltage reader, 110 VAC at the end of two extension cords with no load. I also measured 110 VAC on a single, contractor cord with no load when testing with the resistance, space heater. If we find 110Vac at the inverter output plugs then this unit may be set for too low of an output voltage. I bought it last year and hadn't installed it until this weekend.
    • Red FAULT lights on any of these conditions: low or high input 12V voltage, overload, or excessive temperature.
    • There is no "OFF" position battery load identified. Given the small size of the ON/OFF switch, it probably operates some internal circuitry and I don't know what sort of load this looks like. When I turned off the unit with the circuit breaker, the lights dimmed slowly suggesting there is a 'big nice person cap' on the 12V side.
    After confirming the output AC voltage is low, I'll contact the vendor about getting it trimmed up.
    They also recommend a 2" air gap around the unit so I'll mount it higher.
  5. joedirte
    joedirte Member
    281
    58
    ohio
    2003 Prius
    I
    bwilson4web likes this.
  6. lolder
    lolder New Member
    Toyota sold in Japan and elsewhere starting in 2001 a hybrid minivan called the Estima or Previa that had an optional 1.5 kw inverter so the engineering has already been done. This hybrid has never been sold in the US.
  7. chaslee
    chaslee Junior Member
    Glen Burnie, MD
    I have a Xantrex ProSine 1000 inverter in my 2005 Prius that runs my 5,000 BTU air conditioner just fine. I got it at Home Depot, an LG as I recall, and installed it in our Aliner camper. We used it on Field Day to keep the camper pre-cooled Saturday morning while we ate breakfast at a cafe with the group. When we set the camper up in the field it was nice and cool. For the rest of Field Day we ran the EU2000i.
    Charles
  8. bwilson4web
    16,195
    Ok, we have some metrics:
    Column 1
    0 [th]Out W[th]In W[th]Bat V[th]Inv A[th]Gal/Hr[tr][td]0W[td]21W[td]14.28V[td]1.45A[td]0.068[tr][td]486W[td]491W[td]13.73V[td]35.73A[td]0.178[tr][td]773W[td]925W[td]13.15V[td]69.50A[td]0.192[tr][td]1221W[td]1493W[td]12.65V[td]118.0A[td]breaker tripped[td]
    At a 1.2kW load, the voltage decreased as the 12V battery discharged over a 2-3 minute interval. As the 12V voltage decreased, the current increased and circuit breaker tripped. The 0W, 486W, and 773W power levels were sustained for a one hour interval.
    I was also able to measure the circuit breaker and two Anderson connector resistance and losses:
    Column 1
    0 [th]Out W[th]R_cb[th]R_a+[th]R_a-[th]W_cb[th]W_a+[th]W_a-[th][tr][td]486W[td]0.00168[td]0.00056[td]0.00128[td]2.14[td]0.71[td]1.64[tr][td]773W[td]0.00158[td]0.00067[td]0.00117[td]7.64[td]3.24[td]5.67[tr][td]1221W[td]0.00178[td]0.00475[td]0.00117[td]24.78[td]66.08[td]16.30
    The voltages were measured relative to the car body ground: B+, circuit breaker+, inverter+, and inverter-. Then the inverter current was measured.
    The data suggests my swagging the Anderson B+ terminals failed and they should be soldered. However, I'm really not happy with their relative resistance. I will look at a direct wire and eliminate the Anderson connector. However, the circuit breaker worked as expected given the size of the inverter.
    If an inverter has a smaller maximum load rating, say 1.2kW, ~120A, the inverter itself limits the current draw by shutting down. This is what happens with our NHW11, 2003 Prius installation. But our ZVW30, 2010 Prius, has a more powerful inverter with a greater surge, 3kW. However, the circuit breaker and Anderson connectors are showing non-linear resistance which decreases the surge capacity.
    Because the circuit breaker tripped under load, they often lose capacity. The internal arc oxidizes part of the contacts leading to greater internal resistance, heat and an earlier trip. I won't know until I retest if the 773W can still be sustained.
    This data suggests the earlier surge was induced by the wiring, probably the Anderson connector. This suggests a surge design when you know the average load and source are close:
    • circuit breaker protected, source - as we have now
    • directly connected, surge battery - this only has to provide enough energy to handle startup load. An alternate approach might be a bank of ultracaps but the price/performance of each approach needs to be carefully weighed.
    It is raining this morning so I'll have to wait until this evening to retest to see if the circuit breaker is still serviceable at 773W. I also need to model surge architectures including different battery chemistries. For example, an 11 cell, NiMH, surge battery, would nicely solve the problem:
    • 14.63V - do not exceed charge, 1.33V/cell
    • 13.20V - nominal charge voltage, 1.2V/cell
    • 11.00V - discharged, 1V/cell
  9. bwilson4web
    16,195
    Some had asked about the voltage drop from the engine compartment inverter to the rear battery:
    • Off
      • Rear: 12.41 V
      • Front (jumper post): 12.37 V
    • Ready, inverter off
      • Rear: 14.43V -> 14.50V -> 14.52V
      • Front: 14.54V -> 14.55V -> 14.55V
    • Ready, 750W inverter load
      • Rear: 13.44V -> 13.42V
      • Front: 14.51V -> 14.51V
    The 1V drop for ~65A means 65W are lost from the front to the rear. For improved efficiency, a front-mounted, inverter will avoid losing 65W/872W ~=7.5%. However, there is an increased risk that if the battery tries to provide more than the 140A rated fusible link at the battery, it could blow. Looking at the DC-DC converter to the DC distribution, fuse box, there is a 125A fusible link. This is an ultimate limit for sustained draw if the inverter doesn't reduce voltage as it is loaded.
    Engineering is often making the least bad of multiple choices. The front post would not work for me:
    • 125A fusible link DC-DC converter - lose this link and you've got a 12V operated Prius
    • 140A battery fusible link - lose this link from a reverse surge and once the car stops, it has to be jumped each time
    So I'm thinking of a simpler and more robust approach:
    • 120A DC circuit breaker replacing the 140A fusible link - the purpose is to stop any current draw approaching the 125A fusible link limit from the DC-to-DC converter
    • battery-to-inverter cabling - direct connection to both the B+ and Gnd posts, shortest possible 4 gauge cable
    • upgrading the 12V battery - there are sealed, lead-acid batteries with high cranking and deep discharge capability that can provide the motor surge capability
    This approach protects the car from any surge demand, including the DC-to-DC converter. There will be a power loss from the inverter to the battery/inverter system but in the 7-8% range.
    joedirte and dave77 like this.
  10. joedirte
    joedirte Member
    281
    58
    ohio
    2003 Prius
    I
    Interesting 10-17 mohms from factory wiring. I'm also assuming much of that is from the connectors which may be hard to improve much. Contact resistance seems to be over half of the loss. I agree you probably need 4 awg to handle 120A, but it would be in parallel to existing cable and much of it is open to free air so you might be able to get away with less.
    (of course this assumption is that 65A was going down the cabling, but it could have also been charging the AGM battery, and be larger current)
  11. bwilson4web
    16,195
    It looks like 4 awg will handle the steady state load. The surge should be less than a second so I don't see a need to upgrade, yet. Once I take out the Anderson connectors, we should be good to go. But I have one open question:
    Anyone have the Toyota 12V battery specs?
    In particular I'm looking for the equivalent of CCA and any other technical specifications.
    I had replaced the 12V battery on our 2003 with an Odyssey 925, 28Ahr, even though I knew the Toyota 12V was listed as 36Ahr. I've had no problems, completely satisfied. But I'm building my wife's car out to handle startup loads. So for now, I'm assuming 1kW from the inverter and 500W from the battery. My options are:
    Column 1
    0 [th]model[th]500W min[th]2.5kW min[tr][td]PC925[td]20 min[td]2 min[tr][td]ER30[td]30 min[td]2 min[tr][td]ER40[td]45 min[td]5 min
    So I have an idea of how long I can sustain 1.5kW and the 400 ms 2.5kW is also within reason.
    What I don't have are any metrics for the existing Toyota, 12V battery.
    Now one approach, wire it up and test. If I meet my requirements, starting and sustained running of the air conditioner, no problem. We already know a 1.2kW load can only be sustained for less than a minute so I suspect the Toyota battery is inferior for my purposes to the PC925. But I'd like to check the specs to be sure.
    Thanks,
  12. joedirte
    joedirte Member
    281
    58
    ohio
    2003 Prius
    I
    The default batteries have warnings about charging above 3.5A or 4.2A rate. (see yellow sticker)
    I assume this would lead to venting and damaging the battery as they are lower current and not the standard CCA type batteries. You should replace with one of these low ESR audio batteries that are rated for over 900 CCA and similar 30 to 50 Ah.
    I would hazard to say getting more than 50watts and the battery won't last long if it is even capable.
    Considering the voltage drop I'm measuring on one of these with under an amp draw, I think the battery just can't put out that kind of current to get to 100W without the voltage dropping off.. I guess it is kind of like a high ESR.
    I suppose what you can do is hook up the inverter to the battery and after a full charge, (or a battery charger and start it at the same 12.6V or whatever) plot the voltage after 1 min at 10A load, 20A, 30A load and you will see the ESR and what the battery can handle. I would just replace with low ESR one as the GS / Panasonic seem to be just in there for handling 10 years of constant charging with very little load other than constant under 50mA draw.
    [EDIT]
    (not sure the different rating, maybe a japanese thing. makes sense the model number is the Ah rating)
    http://gyb.gs-yuasa.com/product/carbattery/general.html
    if you look under HJ.. I think in Japan they only rate the charging current and Ah rating.
    NHW20 - HJ-S46B24R 36Ah (238mm 128mm 202mm 227mm) 13.0kg 4.2A Toyota Hybrid
    NHW11 - HJ-S34B20L 28Ah, 3.5A max charging current
    GS Battery | Specialist Japanese Range Specifications
    NHW20 -- 46Ah, 310CCA, 60 min reserve capacity
    NHW11 -- 25Ah, 272CCA, 40 min reserve
    https://www.batterymasters.co.uk/ProductDocs/CARYUAF46RPW654-TECH.pdf
    HJ-S46B24R -- 46 Ah, 310 CCA, 60 min reserve, 3 A charging
    HJ-S34B20L -- 35Ah, 272 CCA, 40 mins reserve, 2 A charging
  13. joedirte
    joedirte Member
    281
    58
    ohio
    2003 Prius
    I
    I looked up the specs of the Odyssey 925MJ and this seems close if the reserve capacity means 35A for 40 mins and the CCA scale with the Odyssey specs. I guess it depends how short the battery only time is and if the voltage drops so low the ECU throws a code while trying to get to READY.
  14. bwilson4web
    16,195
    I called EnerSys customer support and after looking at the options, I'm going to try for a PC1200:
    • 540A - CCA
    • 42Ahr - capacity
    • 7.87 x 6.66 x 6.80 - dimensions
    • 38.2 lbs - weight
    • 4.5 mOhm - internal resistance
    I've built a slightly oversized cardboard box sized for the PC1200 and will test fit it in the morning. I may need one of their mounting hardware kits but the results will be good:
    • 458W, 45 minutes - with the Prius providing 1kW easily 1.5kW for over half an hour
    • 1,992W, 5 minutes - with Prius 1kW, 3kW
    • 3,580W, 2 minutes - without Prius 1kW, enough to handle the surge alone
    I'll still have to mount the circuit breaker but when done, we should have the full 3kW surge as well as sustained 1.5kW long enough to trim loads down to the what the Prius can sustain. I've also figured out how I'll handle mounting the inverter.
    I'm going to trace the 12V battery cover and make a plywood base exactly the same size. The inverter will be mounted above the platform and two/three holes drilled for alignment posts. That way I can move the inverter platform to the engine compartment _IF_ I decide to reduce the power loss from the inverter to the battery.
    A 90/100A circuit breaker will protect the 125A fusible link to the DC-to-DC converter. I'll lose the battery energy buffer but gain 10%, constant power load, 80-100W.
  15. joedirte
    joedirte Member
    281
    58
    ohio
    2003 Prius
    I
    Bob, one concern I have is you are assuming 500W can come from the battery and 1000W from the DC-DC. I do worry it is slightly more complicated situation.. Such as all the current will come from the DC-DC until it either reaches a limit of the voltage at the 12V battery terminals if below the SOC cell voltage which then will start to draw current from both places.
    I might model this with an ideal voltage source of 14.5V and some resistance that fits what you measured, (so 12V at 60A or whatever it is)..
    Here are some links for lead-acid modelling. (LTspice is free)
    http://www.telepower.com.au/INT94c.PDF
    http://www.ni-cd.net/accusphp/forum/docjoints/ID2051_Modelisation_decharge_batteries_Pspice.pdf
    Sealed Lead Acid Battery Applications - Transwiki
    I'll concede it is overkill and hands on measurements are sufficient in this case. And some current shunts for 200A seem to be over $10 if you wanted to individually monitor battery current and DC-DC current.. Might be worth an ammeter probe for your multimeter or a $40 clamp on ammeter.
  16. NiHaoMike
    NiHaoMike Member
    98
    I once thought that motors need sine waves to operate properly, but that's apparently not really the case. The motor coils act as inductors and shape the waveform. What might be problematic is if the cable connecting the motor to the inverter is long due to standing waves, but a little inductive filtering at the inverter solves that. Electronic equipment generally operates fine on square waves since pretty much all of them first convert the incoming AC to DC before doing anything else, but some might not like the EMI.
    Indeed, the Prius inverter puts out square waves when the speed is high enough.
    VH boost
    What you need is "V/Hz control" since starting an induction motor at full frequency and voltage draws a lot of current. V/Hz control works by reducing both the voltage and frequency such that the V/Hz ratio remains constant. Unfortunately, consumer grade inverters are unlikely to have it since the average consumer would have no idea what that feature is and why they would want it. You could possibly get a Japanese market (100V/50Hz) inverter to get the effect. If you're willing to open your inverter, there might be trimmers to adjust the voltage and frequency.
  17. bwilson4web
    16,195
    When I put a 1.2kW load, I could see the input voltage decay as the Toyota 12V battery drained. It ran for about 30-45 seconds before the 120A circuit breaker tripped.
    I have a clamp-on, DC amp meter so I'm good for measurements. <grins>
    The PC1200 may not fit. But if it does, it'll provide near 2x the capacity of the existing 12V battery.
  18. bwilson4web
    16,195
    I have a modified sine wave inverter in the 2003 Prius and I found the 750W gas heater motor did run warmer but it ran. The real problem was the voltage drop over the length of the extension cords. The sharp dV/t transitions make the extension cord look a little like a capacitor and the voltage drop lead to higher currents.
    That is on my list. <grins>
  19. NiHaoMike
    NiHaoMike Member
    98
    Put 2mH or so inductors in series with each side of the output as close to the inverter as possible. And tweak the frequency down a little.
  20. bwilson4web
    16,195
    Thanks,
    I have some ferrite cores that I could run twin conductors through to make a relatively, low resistance, inductor. But I've been concerned that it might induce higher, reflected dV/t back to the power electronics. Once I get my wife's inverter installed to my satisfaction, I'll be more interested in reworking the original installation. It worked four days and six hour when tornadoes gutted the TVA transmission lines.
    DadofHedgehog likes this.
