Question re: 12-volt battery, please?
Discussion in 'Gen 2 Prius Main Forum' started by Julia2001, Aug 14, 2012.
  1. Julia2001
    Julia2001 Member
    290
    32
    Maine
    And it will only become a fully charged battery after I purchase a good charger and charge it up, right?
    What is it about that fact that bugs me so much after spending 200 bucks on a battery? :p
  2. usnavystgc
    3,159
    990
    Tucson, AZ
    5+years of service with the factory battery in a Prius is not only heard of, many have lasted much longer. My original GS Yuasa battery in my '01 lasted 10+years and my '06 still has the original battery in it (going strong). The life cycle of your 12V battery depends on many factors (the biggest being degree of discharge or DOD). If you don't accidentally leave the dome light or discharge it fully in some other manner, your battery (or any battery) will last beyond expectations.
    Julia,
    Don't second guess yourself on installing a new battery. Even though your new battery reads slightly less than your old one, it is a better battery and you now have peace of mind knowing you won't have battery problems this winter. Don't worry about bringing it up to a "full" charge. It is fine right where it is.
  3. hill
    8,929
    I've said it before, and I don't mind a repeat, because it's worth the repeat. Get one of these:
    Amazon.com: Pulse Tech XC100-P Xtreme Charge 12V Battery Maintenance Charger Desulfator: Automotive
    You'll easily get an extra couple years out of the cheesy OEM aux battery. After you eek the extra couple of years out of the OEM, and the aux is mortally wounded change over the the Optima Yellow Top. You'll never look back.
  4. Julia2001
    Julia2001 Member
    290
    32
    Maine
    Thank you, Sir!
    usnavystgc likes this.
  5. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    mmmmmmm cheesy battery aaaaaaaaarrrrrrgggghhhhhhh.
    You folks make me laugh!
  6. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
  7. Patrick Wong
    18,210
    6,514
    Hi Ron,
    This seems fine. If you have an Optima battery; since the Optima website recommends that up to an 10A charging current can be used, I would be inclined to select a charger that can produce that output.
    Also note that the original equipment GS Yuasa battery recommends a charging current of 4A.
  8. dorunron
    3,318
    1,105
    Houston, TX
    Thanks Patrick!
    I do appreciate your advice. Presently I am using the OEM "GS Yuasa" battery. It is at 50 to 75 % charge with readings of 12.4/12.1/14.0 when running jdenenberg's test. I haven't checked it with a multimeter yet, but rather utilizing the MFD. The unit seems to be pricy, but sometimes you get what you pay for.
    When the OEM battery goes, I will probably replace it with the yellow top, but for now I am going to simply keep it charged up. I drive about 10K @ year, but the car does sit occasionally. It is not used for daily commuting, but rather parked outside in the heat and sun. Therefore it is suffering the brutal effects on the Pri systems in more one than one way.
    Ron
  9. dorunron
    3,318
    1,105
    Houston, TX
    Thank you hill!
    I have seen this one along with another desulfate/charge unit. Do you use this one regularly? How long has it lasted? I don't mind spending my money if I get quality and something that lasts along with doing what it claims to do. If I understand correctly, there are no adjustments on this unit, fully automatic. Is that correct? When you use yours, do you connect directly to the battery or to the jump point under the hood?
    Ron
  10. Julia2001
    Julia2001 Member
    290
    32
    Maine
    Ron!
    Here's the one Patrick recommended as one that would work for me. FAR less expensive than the unit you're considering and should do the job just fine:
    Diehard 6A Automotive Battery Charger - Walmart.com
    He also suggested to use the access under the hood, in response to your other question.
    Sounds like your stock battery still has plenty of life left in it! Hook a small charger like the one above to it a couple of times a month and you may squeeze some extra life out of it from what I understand.
  11. Julia2001
    Julia2001 Member
    290
    32
    Maine
    This is interesting to me. May I respectfully ask why, please?
    From what I understand, it is best for the battery to trickle charge, correct?
    Quoting someone who lnows FAR more than i about this matter:
    "Trickle charge is best for the life of a battery. The only time 10 amp is usually needed is when you need a quicker charge time so they are fully charged for the next day. Use the two amp setting. It would be best if you had a trickle charger with an auto shut off. If you forget about the charger and leave it on for days without an auto shut off it may dry the cells."
    I am seeking clarification on this matter because I do have the Optima battery now and have not yet purchased a charger.
    Thank you.
    Julia
  12. Patrick Wong
    18,210
    6,514
    I agree that a trickle charge is better for the battery. However, many people have lots of drama and excitement in their lives and may not be able to allow so much downtime for their car.
    If your charger can produce 10A, then you can get the battery charged at a faster speed when you need to. You can use the 2A setting on the charger when you have plenty of time.
    I personally am not in favor of a low-current battery minder, unless the car is only used on weekends. For a daily driver, who wants to go to the trouble of hooking this up on a daily basis.
  13. dorunron
    3,318
    1,105
    Houston, TX
    Hi Julia,
    I did see that post. I am looking for something that has a little more to offer than the 6Amp Diehard. The unit I referenced also has switchable amperage output as well as a desulfate system. If you do some research on batteries, you will find that all batteries tend to sulfate if they are not kept fully charged, and will sulfate heavily if you allow them to discharge. The charger I am looking at will at times bring a unservicable battery back to servicable use. It all depends on how much sulfate is on the plates.
    The unit will also charge up batteries as well as maintain them with a trickle charge, therefore it falls into the category of the type of charger I am interested in. I plan to use the charger on two separate vehicles, not just the Prius. FYI, Optima makes a real nice charger for your new yellow top. Expensive price though $199 on the website.
    Hope this helps ya in your quest for knowledge and research.
    Ron
  14. usnavystgc
    3,159
    990
    Tucson, AZ
    Woowwwww! Look at Julia. Now she's giving advice. :). You'll be an expert soon Julia.
  15. Julia2001
    Julia2001 Member
    290
    32
    Maine
    Haha...I'm not giving advice! Just passing along the advice that was so generously offered to me. Big difference! :)
    Of course I'm no expert...but I do now have experience in a couple of DIY projects and hope to be able to pass along to others what I've learned here.
    I think for my next project I may try cleaning out the Hybrid battery fan/blower! Doesn't that sound like fun? :)
  16. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    The usual advice is not to bother unless you have pets or people in winter coats using the back seat a lot.
  17. hill
    8,929
    We've been using the Extreme X for about 4 years now. It has a neat set of cables that allow you to do a permanent install on the terminals of your Prius. The cables have modular connector plugs in the middle of the cables that you can disconnect / dangle out of the car, to an easy-reach place. That way you can plug it to a power source without ever having to open up access to the car/battery. It was actually PriusChat's own Darrel (EVnut) that put me onto this model - which he uses for his RAV4-ev (see his web site: evnut.com and drill into the menus). I gave it a try after seeing that he swor by it - and how well it maintained his aux battery. We got a 2nd one for our electric Duffy party boat, which runs on a quantity of 8 six-volt lead acid "Trojan" style batteries. I rotate maintenance charges between the 4 pairs of Trojan batteries using our 2nd Extreme X . I'd of normally had to replace our 6v Trojan batteries by now, had it not been for the Extreme X. So yes, I'm very satisfied w/ them. I'm sure similar products work well, but the price for this sucker, as well as its 'set-it & forget-it' operation, makes it a bargain imo.
    dorunron likes this.
  18. Julia2001
    Julia2001 Member
    290
    32
    Maine
    It has been three days since I changed my battery. Still getting 12.0 (ACC) and 12.2 (IgOn)...a little better with the multimeter. And yes I've taken it for a few drives and charged it by running it in Ready mode for five hours.
    Just wondering if the Optima battery might not be in optimal condition!
  19. Patrick Wong
    18,210
    6,514
    Well - if this bugs you then you need to fully-charge the Optima and see what happens. You can do that by either:
    1) buying a good charger and using it overnight, or
    2) leaving your car READY for a prolonged period, like overnight. (In that case, make sure your car has sufficient fuel in the tank. You do not want to run out of fuel during this process.)
  20. Julia2001
    Julia2001 Member
    290
    32
    Maine
    If I were to leave it in Ready mode overnight would I be able to lock the doors?
