gen 3 hybrid battery cooling fan dust buildup
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jbpersmail, Sep 26, 2011.
  1. Mendel Leisk
    41,332
    ^ While I don't know for sure, I can't see that being necessary unless you start pulling out the battery. Just getting to it, say to check the fan, seems safe enough. And I wonder: would pulling the service plug cause some error codes or resets?
  2. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Does this fit on the inside or outside of the stock vent grille? If this is a PiP part, does it fit the standard GIII?
  3. PriusInParadise
    180
    91
    Hawaii
    The filter snaps over the outside of the stock vent grill. Refer to the last photo in post number 19.
    This part has been released for the Gen III Prius to mitigate excessive dust build up in the HV-Battery cooling fan, where the vehicle experiences very frequent ingress/egress from the back seat while the vehicle is running, such as a taxi.
    I think it would also be useful in cases where the vehicle transports pets in the back seat.
    Jonny Zero likes this.
  4. jlim888
    jlim888 Member
    78
    36
    WE0H and Jonny Zero like this.
  5. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Thanks. I just ordered it. This is about the price I would pay for something that simple.
    Have you installed it? Does it come on and off easily?
  6. Mendel Leisk
    41,332
    I pulled out the grill over the fan inlet (integrated into the seat back): you need to push down on the seat cushion and fish a ratchet wrench extension down to a single bolt. It might be 12 mm, don't remember exactly, either 10 or 12.
    Then you just wiggle and pull things off of tabs, it opens up pretty easy.
    I just cut-to-size and pushed in a piece of vacuum motor filter material, friction-fit in behind the grill. I check it periodically by just examining, through the grill. It's collected a few seeds and pieces of lint, as far as I can see.
  7. jlim888
    jlim888 Member
    78
    36
    Not yet. I ordered it today (10/11). The cheap $3.30 shipping is through U.S. postal service. I assume "Mid Atlantic" is in east coast. I'm in California, so it would take a while to get here. You're in Texas, so you might receive it before me!
  8. jlim888
    jlim888 Member
    78
    36
    I received the filter today (10/17). It looks exactly like the pictures on Post #26. Very easy to install, it simply snapped on. I will report back in a few months to see whether the filter collects any dust :sleep:
    WE0H likes this.
  9. jlim888
    jlim888 Member
    78
    36
    I found a picture for the seat cushion/grill. The seat cushion that Mendel referred to is 71540A (full part# is 71540-470xx where xx is for various color/cloth/leather) and the bolt is 90119-08C37.
    WE0H likes this.
  10. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Got mine installed yesterday. Not the prettiest thing but if it helps the battery, I will look the other way. :p
  11. WE0H
    WE0H Senior Member
    3,247
    528
    Pictures please ;)
    Mike
  12. jlim888
    jlim888 Member
    78
    36
    Mike,
    Below is my actual install. Other than it isn't gray to match my interior color, it doesn't look bad at all...:)
    BTW, I went back to MidAtlantic website... In addition to G92DH-47010, they also have G92DH-47020, G92DH-47030, etc. I'm wondering whether the last 2 digits are for different colors? If you haven't bought yours, you might want to check it first.
    HV_Bat_Filter_Installed_DoorClosed.JPG HV_Bat_Filter_Installed_DoorOpen.JPG HV_Bat_Filter_photo 2.JPG
    WE0H likes this.
  13. wbray123
    wbray123 Junior Member
    71
    Colonial Heights, VA
    It might be worth a few dollars because it appears easy to install and is not too ugly-at least it won't be if the colors match. I have the light tan interior and would not want the black. If I had a big hairy dog in the back seat I would certainly want one!
  14. Former Member 68813
    3,524
    983
    US
    Darn, I should have read this before ordering the G92DH-47010. It's black, eyesore, and little filtration if any. More like protection "against foreign particles," as the crudely translated instruction states. The
    G92DH-47020 is only $6 and G92DH-47030 is only $3. I could have ordered both for the price of G92DH-47010. But maybe they are not filters?
  15. RRxing
    RRxing Senior Member
    2,545
    1,821
    NEPA
    Image search for G92DH-47020/47030 only shows pictures of 47010, so I have no idea what those parts are (other than cheaper.)
  16. PriusInParadise
    180
    91
    Hawaii
    Per various TSB's, the HV-Battery filter applications are as follows:
    G92DH-47020 2004 - 2009 Prius (Gen II) T-SB-0153-13
    G92DH-47010 2010 - 2014+ Prius (Gen III) T-SB-0099-12
    G92DH-47040 2012 - 2014+ Prius v (Wagon) T-SB-0171-13
    G92DH-33010 2007 - 2011 Camry Hybrid T-SB-0012-14
    All the above "filters" are black.
    Sorry, don't know what G92DH-47030 is, yet.
    PriusC_Commuter and BigBear2010 like this.
  17. jlim888
    jlim888 Member
    78
    36
    Here's my filter 1 year after installation. The filter doesn't accumulate much dust at all. I seldomly carry passengers in the backseat. I don't smoke and have no pets. Maybe that's why the filter looks pretty clean :cool:
    markabele likes this.
  18. Dalamar
    Dalamar Junior Member
    2013 Prius v wagon
    Revival time,
    I bought my 2011 Prius on 2/28/15
    HORRIBLE noise from the fan, filter would have prevented this.......it was a candy wrapper....even though it'll only be me in the car, I'm still ordering a filter just to be safe
    please ignore the beer in the first pic.....as you know, it's the only way to get work done
    #58 Dalamar, Mar 9, 2015
  19. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Another reason a filter is needed for the battery air vent.
  20. Mendel Leisk
    41,332
    Previous owner likely had small kids (or bigger...) in the back seat: it would take some effort to coax a chocolate bar wrapper through the grill. I've just tucked a piece of vacuum cleaner motor filter material in behind the grill. I keep an eye on fan speed and battery temp via ScanGauge with XGauges, and with/without the filter has no noticeable impact, ie: it doesn't seem detrimental to cooling.
    Prius DIY nut and Robert Holt like this.
