Confused: Why does estimated EV miles keep dropping?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Den Hare, Oct 29, 2012.
  1. slcMPG
    slcMPG Member
    221
    65
    SLC, Utah
    It is solved. My PiP jumped up to 14.4 from 13.1 on Monday. This was mixed HV and EV, but I had a ton of regen coming down a large mountain.
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    You get 16 miles on a 2.7 kWh charge.
    That's 170 Wh/mi. For the same amount of electricity your PiP takes to travel a mile, you can light up a 170 Watts light bulb for an hour.
    Since PiP headlights use 110 Watts, you can use it for 1.55 hours (93 minutes) in exchange for your one EV mile.
  3. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Yup. On the other hand, if you had mostly uphill in EV mode yesterday, the car will report lower range on a full charge today.
  4. bisco
    51,851
    great info, thank you. can i assume then, that coming home from my commute (15 min.) cost me 1/6 of a mile and the other 2-2.5 miles lost must be due to drop in temps from 70's to 60's, and changing my halogens to led's isn't going to help much?
  5. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Yea, the energy that the headlight consume is probably a fraction of what the other elements can do.
    Rolling resistance increase (tire pressure), head wind (cold air is more dense), driving speed (A BIG one - at 55 mph, half the energy spent is pushing through air), battery chemistry due to low temp, etc.
    If I assume your round trip is 16 miles and your commute is 15 mins, you must be doing 64 mph. Perhaps your commute is 30 mins round trip so you average 32 mph?
    Then your headlights will cost you 1/3 of a mile. :) The slower you go, the more it'll cut into the range. Say, you average 1 mph. Then the headlight will use 110 Wh/mi on top of your current 170 Wh/mi.
    lensovet likes this.
  6. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    Driving with lights on is pretty much all the time during the cold season, since it's quite often gray & gloomy during the day. The advanced package has great LED lights for that, nicely shown in this photo:
    Have an idea what their power consumption would be?
    slcMPG likes this.
  7. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
  8. rockerdan
    rockerdan PiP Rocks!
    427
    83
    Wheatfield NY
    my HIDs are 35w each, but they are soooo much brighter. win win.
    I agree with charging battery just prior to driving it in winter, to pre warm it. Seems to help.
    But in the end, winter temps have dropped my EV range .6 miles too. I went from 14.2 summer to now 13.6, but I have been driving faster this month too on a new route.
    Dan
  9. John H
    John H Senior Member
    2,208
    558
    how many watts do the stereo and speakers draw?
    NPR could cost you .5 ev miles
    Aerosmith might cost 2 ev miles :)
    babybird, iplug and lensovet like this.
  10. bisco
    51,851
    my commuteis 7.5 mi each way =15 miles and 15-20 min. each way depending on traffic = 30 - 40 minutes. average speed around 28 mph. when i first noticed significantly reduced ev travel, the temp had dropped from the high 60's, low 70's. to high 50's, low 60's. the first night i had to use my headlamps on the way home from work, i didn't make it home before the charge ran out. it was the first time since april 26 when i got the car that i couldn't make the commute in ev. tonite, i drove to work in a nor'easter. needless to say, i only got about 10 miles of ev.:cool:
  11. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Yesterday, I drove about 2 hours during the nor'easter snow storm with a full charge and got 50 MPG. That seems to be the worst possible condition/scenario for PiP.
    This morning, a full charge was showing 11.6 miles (was 13.7 miles). I am sure it'll return back to usual.
  12. bisco
    51,851
    these are some tough conditions. 50 mpg? are we spoiled or what?:)
  13. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    I always thought 50mpg was awesome, but the PiP made it even worse now, I almost get depressed when I get below 70 mpg ;) I bought driving gloves JUST so I don't have to run the heaters, it's a disease ...
    SJ PiP likes this.
  14. bisco
    51,851
    agreed. what are you doing about defrosting the windscreen?
  15. Electric Charge
    545
    133
    Syracuse, NY
    I used Meguiars Glass cleaner to REALLY clean the glass (started by doing half the glass, so I could see the difference), so now I have no need for the defroster for the first 10 miles or so while I am on EV. Without the cleaner, I would be flying blind!
    Adam Leibovitch and slcMPG like this.
  16. bisco
    51,851
    wow! i'll have to try that. 'course, my singing tends to fog it up.:X3:
  17. Electric Charge
    545
    133
    Syracuse, NY
    Yea it works well. I am hoping it will last a month or so before it starts fogging up again. But you need to do a really good job cleaning for sure.
  18. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    A full charge showed 13.1 miles estimated this morning.
  19. bisco
    51,851
    and how far can you actually go? i find mine to be quite accurate. when it said 16+, i could drive 16+. now it says 13+ and i can drive 13+.
  20. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    I don't drive enough to deplete it so I don't know -- until I take longer trip.
