Rearview Camera - License Plate Type
Discussion in 'Gen 2 Prius Audio and Electronics' started by BMcGraw, Jan 24, 2006.
  1. BMcGraw
    BMcGraw Member
    230
    Southern California
    Has anyone successfully installed a license plate rearview camera? I've run into some issues... :(
  2. hawkjm73
    hawkjm73 New Member
    258
    Phoenix, Arizona
    Oooo, you can't just leave us hanging with that! :lol:
    I didn't do a license plate cam, but I did put mine in the knokout just beside the plate. It is possible the issues you are having are something I saw, too.
  3. Roger3125
    Roger3125 New Member
    199
    Orange County, So Calif
    Pkg 3 comes with a rear view camera. Can I assume then that you are talking about a Prius without Pkg 3?
    Quit frankly I don't see a great value in the rear view camera other than to take a last scan of the area before you go into reverse. By that time something could come into view..besides we rely on our rearview and side mirrors, don't we?
  4. hawkjm73
    hawkjm73 New Member
    258
    Phoenix, Arizona
    Mine is an '05. Up until '06, no Prius model in the US had a rear view camera from the factory. Anyone who wants one on the earlier models has to locate and install the parts themselves.
    I actually find the camera very helpfull. Yes, primary data is gathered from the mirrors, but it is very reasuring to have that one extra check. Also, my prius has extra tint, so at night the mirrors don't show me as much as I'd like. Backing out of a garage in the dark, my r/v mirror is basicaly useless, due to the lighting change from garage to outside. The camera can see very well under these conditions and lets me know if there is anything out there.
    Above anything else, though, the camera is one more great geek toy in my very geeky car. B)
  5. BMcGraw
    BMcGraw Member
    230
    Southern California
    I purchased one that looks the same as the one offered by Coastal EJoke (see http://www.coastaletech.com/rear_view_camera.htm) but the camera location was too high to fit beneath the hatch "handle" trim. After cutting/grinding away the top of the plate frame so that it fits, I cannot access the "button" to open the hatch.
    Of course it can't be returned now... <_<
    My original question should have been, "Has anyone installed CE's version"?
  6. hawkjm73
    hawkjm73 New Member
    258
    Phoenix, Arizona
    Well, barring shelling out the money to buy Coastal's, I would suggest trying to invert the frame so the camera is below the plate. That will only work if you can turn the camera 180 in the frame along its viewing axis. It also assumes the camera can be re-aimed to acount for the lower position. If it is just like coastal's, there should be two plugs in the lower part that can be moved to the camera's side so the screw hole are in the right spot.
    Alternitively, that camera looks to be very close in size to the Eclipse camera that matches up with the JDM OEM. You may be able to remove the camera from the frame and mount it in the stock knockout. You would need to devise a way to secure it to the hatch under the trim. It looks like it has its own mount that is secured to the plate frame. You may be able to directly bolt , glue, or tape that to the metal of the hatch. I used 3-m tape on the base of mine. It has staid very secure like that. If you drill, pull the trim on the inside of the hatch first to comfirm clearance.
  7. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Where did you get it and who makes it? I am working towards getting a camera and you have put fear in me. I was thinking about getting a license plate camera. How did or do you intend to run the wires? Do you have pictures?
  8. ceric
    ceric New Member
    1,114
    Fremont, CA
    According to coastaletech...
    >>> We have reviewed several options with careful consideration to quality, ease of installation, and price. A camera integrated into the license plate frame was found to incorporate all of these requirements and is an attractive addition to your Prius. The unit we are offering is complete with cables for installation. It is very solidly constructed of chrome plated metal and attached with special security bolts. <<<
    It sounds like they have tested it and it is the BEST choice among ALL. Apparently, according to you, there is a big problem in installation. I am glad I did not buy it. Can you show a picture of your current installation? Maybe we can also chip in to crank out some ideas. :D
  9. BMcGraw
    BMcGraw Member
    230
    Southern California
    Check it out @ http://www.simplycheap.com/mito20-lp100.html
    Here are the specs and purchase info:
    Mito 20-LP100 License frame Camera Chrome Frame (plastic)
    Manufacturer: MITO
    Model: 20LP100
    Part Number: 20-LP100
    UPC:
    Ultra wide - angle CCD color camera
    Designed for vehicles in which its license plate location is centered and above the level of the rear bumper.
    1/3" CCD Sensor
    Pixels: 512(H) x 492 (V) 330TVL
    Video Output: 1.0 V P-P Composite (75 Ohm lead)
    Measurement: 12.5(w) x 7 (H) x 1.8" (D)
    Power Source: DC 12V 180mA
    $199 + shipping
  10. BMcGraw
    BMcGraw Member
    230
    Southern California
    See previous post. It's NOT from Coastal. No pictures - yet. I'm going to attempt to install it Thursday and should have pix after that - if successful. :p
  11. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Well it does and it does not. Check this out
    -CAM - 30° ultra wide angle CCD color camera. Designed for vehicles which license plate location is centered and above the level of the rear bumper. Reverse imaging means objects on the right of the vehicle appear on the right when looking at the monitor. In chrome or matte black. 1/3" CCD sensor / Pixels: NTSC 512x492, 330TVL / Video Output: 1.0 V P-P Composite (75 Ohm load) / Dim: 12.5" (W) x 7" (H) x 1.8" (D) / Power: DC 12V 180mA / Lux: 1.0 Rated Check it out on http://www.sigmaautomotive.com/autodax/backupcamera.php under iCam . Look at the CostalETech page the connector is different http://www.coastaletech.com/License%20Plate%20Camera.JPG . I don't think they are the same. Could it be this one : FrameCAM - FrameCAM installs seamlessly into any vehicle using the existing license plate mounting holes, giving it true original equipment functionality. It features a water-proof Sony 1/3" color Super HAD CCD camera, protected by a rugged aluminum housing. The 2.9mm lens provides a panoramic view, and the camera angle is adjustable for optimum viewing on any vehicle. It works day & night, thanks to an automatic low-light feature that provides excellent picture quality down to 1 lux. FrameCAM was designed to withstand the wear-and-tear of bad weather and real-life driving conditions over the long haul. Designed & manufactured in the USA. Signa Automotive does not show the connector but this one come in Chrome and Black and looks like the Costal E Tech camera. I will ask both about it. The prices are the similar.
  12. rwithop
    rwithop New Member
    121
    SF Bay Area, CA
    I bought one from japandirect. It's not the license plate version, its the actual one they use on the Lexus and Toyota Limited Edition packages. Goes right next to the license plate lights and hides pretty well. Lot of work but looks cleaner.
    If anyone wants one, let me know.
    Ryan
  13. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Could you provide a picture?
  14. ceric
    ceric New Member
    1,114
    Fremont, CA
  15. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Sure, post the info, esp. ordering info and price--how's it compare to Sigma's price for the OEM camera?
  16. rwithop
    rwithop New Member
    121
    SF Bay Area, CA
    It's a TOYOTA (ECLIPSE OEM) 08634-00120 backup camera. I bought it from JapanDirect.com for $250 + $25 shipping +$12 credit card fees, but I guess you can have mine for $199 plus shipping. Otherwise email [email protected] for an estimate.
    It installs in the little pocket just to the left of your license plate light. Fits exactly, as this is the model used on the Japanese Prius, (see the pic of "frenchie's" installation below.)
    You will need a video input to your MFD as it does not just plug in to US models. I have one of those too if you need it.
    :) Ryan
  17. rwithop
    rwithop New Member
    121
    SF Bay Area, CA
    Sorry I don't have any specs written here. It's all in japanese.
    Basically, its a 9V color camera. Chop off the connector and attach an standard yellow NTSC video female connector.
  18. BMcGraw
    BMcGraw Member
    230
    Southern California
    I hope you meant "12V" or there's a problem... I understand the language barrier but hopefully the European Prii aren't a 9V system.
    Apparently you're giving it away? One more time.... how much are you asking?
  19. rwithop
    rwithop New Member
    121
    SF Bay Area, CA
    No. 9V. You just add a tiny voltage regulator, which I bought for a couple bucks which I will provide.
    Not free. It cost me $289. I think $199 plus reasonable shipping is fair.
    Keep in mind...there is some assembly. You have to be comfortable taking your car apart to wire the cable through and you have to cut the plug off to put your own connector on. It's easy but not plug and play.
    I have the docs at home that show the installation, if you need it.
  20. frenchie
    frenchie Member
    150
    48
    France, not far from PARIS
    Hello,
    I helped a friend to install last saturday a cam in a prius 2005 (the 4th in europe).
    this time, we used a cam eclipse bec105g.
    this cam has a bigger angle of vision .
    it is exactly the same as what you get with the toy OEM, only missing part is the rubber gromett.
    difference between bec105g & bec105 is:
    with the bec105g you get a power supply (6 v). I bought it through a friend in japan, total cost was around 250 usd.
    you can compare the result here , goto to the bottom of the topic and you will see 2 big pictures :
    http://prius-touring-club.com/phpBB2/viewtopic.php?t=29
    the color of the blueish picture is (happily) not the real one, in fact , the colors are similars for 2 cams.
    we had no real troubles during installation, but after, we spent 2 hours to debug a bad image.
    the problem was coming from the powersupply of the mobile phone generating a lot of interferences on the screen...
