Fuel Economy Survey- Am I Hopeless?
Discussion in 'Gen 2 Prius Fuel Economy' started by sarah dunetz, Feb 8, 2013.
  1. sarah dunetz
    sarah dunetz Junior Member
    32
    I'm driving a previously used 2007 Prius, and getting approx 29MPG.
    My thoughts are basically that I am SOL, and due to where I live, how much I drive, and the hills, I pretty much can't be expected to get better than I do. Am I correct?
    I'm not at all technical minded, so please keep that in mind when replying.
    - What fuel economy are you getting and how are you determining fuel economy? (trip computer or manual calculations)
    I reset the average every time I fill up. It says 29mpg average. I know I can get more accurate by doing this by hand, but even if it is slightly inaccurate, I'm not getting anywhere near optimal results. I normally get just over 300 miles a tank.
    - What fuel economy are you expecting and why?
    I don't really have any expectations, and honestly, I am happy with my 29 (I am a former Taurus driver!), but if I can bet better fuel economy, I should at least try. I think 40 might be attainable.
    - What are the approximate outside air temps?
    I live in San Francisco, it pretty much always ranges from 50-65F
    - How long are your trips?
    Almost exclusively under 7 miles each way, often times shorter. I did go on a 600 mile road trip, though, recently, and I still only got around 29mpg.
    - How much of it is city vs. highway? Roughly what's the average speed in overall and and of each segment? Is there a lot of stop and go driving?
    It is almost exclusively city driving, and, in most cases, there is a stop sign every block or two. I try for the synchronized lights, but to get to those, I have to go through 20 stop signs at 25mph. Oh city living!
    - What region/state are you in? (if you haven't set your location in your profile)
    San Francisco, CA.
    - What's the terrain like of your drives? (e.g. flat, gentle hills, steep hills, etc.)
    It is either totally flat, or massive hills. Not much in between.
    - Is your oil overfilled? (i.e. above the full mark on the dipstick)
    Nope.
    How old is your 12v battery? What is the voltage reading of your 12v battery after sitting over night? (Method Here)
    I don't know.
    Have you had your alignment checked? Any pulling or abnormal tire wear?
    Yes, I have been checked, and no, my tire wear is normal.
    - Are you using the factory tires and wheels? If not, please indicate tire make, model and size (e.g. Goodyear Assurance Fuel Max 185/65R15).
    I'm using factory tires and wheels.
    - What are your tire pressures?
    I'm not sure, but I did have my mechanic fill them a little fuller than recommended. He said it would help my mileage, but it hasn't seemed to.
    - Make, model, year, engine and transmission of previous car? (e.g. 08 Honda Civic Si 2.0L 4 cylinder, manual transmission) What did you actually get on the same trips/commute? (Please give us actual numbers, not EPA ratings.)
    2004 Ford Taurus, I think it was 4 cylinder, automatic. I averaged 12mpg, so I'm pretty thrilled at my measly 29 :)
    - How are you trying to drive (e.g. trying to stay in electric only?) and how hard are you braking?
    I brake gradually, but don't drive any differently than I did in my Taurus. Because of all the stop signs, I don't feel like I really have options about how I accelerate/decelerate. I do tend to drive around 70mph on the very occasional highway drives.
    - Are you "warming up" the ICE (internal combustion engine) by letting it idle after powering on?
    no.
    - Are you driving using D or B mode?
    D.
    - HVAC settings? Are you using the heater, AC, auto mode, etc.? If using auto, what temp is it set to?
    I keep the A/C off, but I'm always freezing, so I keep the blower on around 76, and on the lowest setting.
    - If reporting a mileage drop, did anything significant change on your car (e.g. accident, hit a curb or big pothole throwing off alignment, oil change/other maintenance/repairs, changed tires or wheels, etc.) or your commute?
    51,765
    it's probably your 12v battery, have it checked, or just replace it if you can't determine how old it is. if it's the original, you're due for a new one at that age anyway. i think you can get 40 mpg in those conditions.
    sarah dunetz likes this.
  3. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    If you were only driving 1 - 2 miles, then I'd say that's about right. But 7 miles and 29 mpg? Long highway trip and 29 mpg? There is something wrong. You'd have to drive with one foot on the gas and the other on the brake, with all the windows down and all the accessories on....with a parachute to get that type of MPG's.
    If you haven't already, you might want to schedule a visit to Luscious Garage and have them take a look. I would be concerned about this type of mileage. Sorry, not trying to scare you, but what you are seeing isn't acceptable and points to something with the car.
    Luscious Garage | Hybrid Specialists
    Lazy link added.
    JMD and sarah dunetz like this.
  4. sarah dunetz
    32
    Thanks Cody,
    Luscious has looked at it, but for the water pump (which is insanely loud) and not bc of the mileage. Though while they were looking at the water pump, they did fill my tires a bit. I can bring it back in. What do you think a more reasonable mileage would be?
  5. alekska
    alekska Active Member
    435
    138
    Atl
    Try changing the 12v battery. Also, having heat on 78 keeps the engine running all the time on your short trips, and it does not have time to warm up. Blocking the upper grille should help the engine warm up little faster. Also, Try to have your tires at least at 38 psi.
    Another possibility is that there is something wrong with brakes and they drag a little all the time. Mechanic can check.
    - Alex
  6. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    I think you should expect about 10mpg better than you are getting, tell the people at Luscious about your mileage, they will probably suggest a new 12v battery, good luck.
  7. sarah dunetz
    32
    Thanks everyone. Sounds like its a new 12v bat for me!
  8. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Thanks for answering the questionnaire! (y)
    Yeah, being in SF does NOT help w/mileage. Yeah, all the stops signs, traffic, hills and possible idling doesn't help, not to mention your short drives.
    Before throwing money at a 12 volt, please run the test at Weird stuff happening? MPGs dropping? Test The Battery | PriusChat after the car has sat MANY hours or overnight. Please tell us the 3 values (not just 1). Don't go changing the battery first until you tell us the values...
    If you have HIDs, you can avoid unnecessary cycles on the lights by toggling between off and parking light positions.
    Weird stuff can start happening w/a low or bad 12 volt. Don't waste $ on having a dealer "test" the 12 volt (07 Prius Dead - Any Guesses? | PriusChat). If you're on you're original 12 volt, it's likely near or at end of life now.
    Yep on all of the above.
    Please see the better heater management tips at Why mileage gets worse in winter | PriusChat. I would NOT leave the heat in auto or at 76 all the time. I would ONLY turn the fan on (w/heat) either the engine's warm enough or when it must run anyway. If the engine's cold, then just turn the heat up and the fan off.
    I personally block my upper grille in the winter (including now) even in the South Bay.
    I think the OP can hope for 35-40 mpg or so given Most fuel-efficient cars and the details of their city test on the last page of http://www.consumersunion.org/Oct_CR_Fuel_Economy.pdf.
    But, 29 mpg on a 600 mile roadtrip, assuming it was mostly highway is VERY bad and abnormal. When I've driven between San Jose and the LA area, where I'd do 72-78 mph and I've got the hills at the Grapenvine, I can still average over 40 mpg even though 2 of my tires aren't LRR.
  9. ursle
    ursle Gas miser
    1,049
    192
    NH
    Let the mileage accumulate for 5 or 6 tankfuls, it'll give a more accurate indication of overall mileage, takes a tank or two just to get out of the 40's some times.
    Clean your cabin air filter
    Check the ice filter, 40lbs of air in the tires, go to an auto parts store and have them put a gizmo in your obd2 port to read any codes, might turn up something interesting.
    Yes get a new 12v and a battery charger, every two months charge the sucker(12v) just to top it off.
  10. sarah dunetz
    32
    Ok, so silly question, but how do I block my upper grille? Is that inside the car or in the engine? Also, how do I turn the heat up and keep the fan off?
  11. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    Changing the cabin air filter won't help w/mileage.
    Yeah, the 12 volt may not be getting sufficiently charged w/such short drives. I ended up ordering an Optimate 4 (as I posted at battery tender/maintainer suggestions | PriusChat). It charges slowly enough that there's no danger of charging too quickly.
    I've used black pipe insulation that I bought at Home Depot. I just stuff the the upper grille from the outside. There are many variations. If the pipe insulation is too large, one can zip tie it.
    There are a bunch of old grille blocking threads here.
    When I lived in WA state where it was much colder and stayed cold in winter, I blocked the upper and part of the lower grille. I had to zip tie the pipe insulation around the slats (better word for this?) of the lower grille.
    As for turning the heat up and fan off, just turn the temp up, to say HI and then press OFF for the fan speed. You'll still get a bit of heat and more when you're moving due to ram air coming in. Again, once the ICE (internal combustion engine) is warm enough, it won't need to run to provide cabin heat. Unfortunately, the only well to tell how warm/cold it is is via a tool that plugs into your OBD2 port like a ScanGaugeII : Linear Logic - Home of the ScanGauge or Bluetooth OBD2 dongle and an appropriate app (if available) for a smartphone (e.g. Torque for Android).
  12. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Sarah, you're not hopeless. There's always something that can be done. Blocking the grill means buying some pipe insulation and sealing up the front grill from the outside. It is very cheap, very easy, and very reversible. Here's all you need to know: First Morning with a Blocked Grill | PriusChat
    Soft tires have more drag than hard tires. You may want to go up to max sidewall pressure. That's the number stamped on the sidewall. It is probably either 44psi or 51 psi. There is no right or wrong number. It depends on how you like the car to perform.
    Have you tried engaging then releasing the parking brake? It's free & worth a shot.
    I do agree with the others. Something is wrong, we just have to help you find it and fix it.
    Are the tires on the car Goodyear Integrity or something else? You mention that you bought the car used. How do you know the previous owner didn't swap out the tires?
    Please go to Toyota Owners Official Website: Service Coupons, Owners Manuals, Service Scheduling and More to register the VIN. You can find the car's dealer service history. Let us know if you find anything other than oil changes.
  13. sarah dunetz
    32
    I got a car fax when I bought the car, because I bought it through a dealer. I only saw oil changes, so I assumed the tires were what came with the car. That could be incorrect, I suppose. I will check the tires when I get home from work.
    Because I live in SF, where there are hills a-plenty, I use the parking break almost daily, so I don't think it is partially stuck or anything.
  14. sarah dunetz
    32
    Ok, experts, ran the 12v bat test. My results seem normal? What do you think? 12.1, 11.8, 14.0 (I assume you all know what those correspond to, let me know if thats not the case)
    Edited to add: I forgot to check my tires, but I'm too cold to go back outside. Wish I could turn the heat in my house on like I do in my car :)
  15. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    Was this after the car sat MANY hours or overnight since last being in READY mode? If not, wait until tomorrow morning.
    As for tires, you need to check their cold pressure, after the car hasn't been driven for many hours or overnight.
  16. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    I'm no expert but from what I've read in these forums, the voltage amounts are low. It appears your 12V battery is suspect. Also, try keeping track of your mileage and gallons per fill-up. Are you really using 10+ gallons every 300 miles?
  17. sarah dunetz
    32
    Yup, havent driven my car in 24 hours.
  18. sarah dunetz
    32
    To be fair, I don't wait till the tank is totally empty to fill up. I normally do it when the ping goes from 2 to 1. Normally by then, the trip ODO is around 300.
  19. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    I'd say your 12 volt is borderline marginal, not terrible yet. There was one guy here who had trouble starting his Prius and found that via a volt-meter it was down to 3.1 volts! Now, that's BAD!
    I've seen people here post voltage vs. state of charge charts here but the problem is, the car always has a parasitic load on the battery and putting it in ACC mode for even the 1st reading puts on even more load.
    The SoC charts assume no load on the battery. And, from what I've found, the voltage test via the MFD reads a bit lower for me than putting a volt-meter on the battery terminals in the back (probably due to the ACC load). And, I have no idea exactly how much error is in the MFD's value.
  20. sarah dunetz
    32
    Given that I am just a few tenths of a volt off from what the directions said were normal, do you recommend replacing now or waiting? And, given that I'm off by so little, do you think this is actually what is causing my mileage issues? Or are we now headed in a different direction for investigating?
