My search-fu might be weak and the info may already be out there... I'm planning an install of an AVIC X130BT and I'm wondering if I can tap the feed for my existing reverse camera to supply the image to the AVIC as well. Is the signal part of the data bus, or is it just a composite signal I can tap?
I really should have created a more generic thread title to cover all my questions and I cant' see an option to edit the title, sorry about that. I wanted some of you folks that have already gone through this to double-check my list and let me know if I'm missing anything needed to install... 2008 with 9 speaker JBL I'm intending to order: Metra TYTO-01 JBL Amplifier Interface Harness Scosche 010TA2103B 2004-up Toyota Prius Double Din with Pocket Metra Electronics 71-8113 TURBOWire Repair Wire Harness Metra 70-8113 Radio Wiring Harness for Toyota Amp Integration 20 Pin Axxess Metra ASWC-1 Universal Steering Wheel Control Interface with New Micro B Connector (Black) Does that about cover things?
