UK engine block heater
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Clubber, Feb 16, 2013.
  1. Clubber
    Clubber Junior Member
    24
    London
    Does anyone of the UK Prius owners use an engine block heater and if so, where did you get it from?
  2. edwardob
    edwardob Member
    227
    33
    ireland
    yes i did....i'm in ireland but i got it post from
    toyota
    pentagon sheffield
    part no is tpz434-g0790-3z del to me was about 113 uk pounds
    any more info needed let me know!
  3. Clubber
    24
    London
    Wth apparently it's $60 in Canada
  4. edwardob
    edwardob Member
    227
    33
    ireland
    well this one is genuine toyota part...and 240v to suit our voltage
    works great i have it on everyday 21/2 hrs before i go work ......
  5. Clubber
    24
    London
    Ok mate, I'll take a look.
  6. Braddles.au
    Braddles.au DEFAnitely using an EBH
    295
    99
    Canberra, Australia
    As an alternative, look at the DEFA pre-warming solution from Norway.
    Here's my journey to get one and fit it myself. In the end, it was fairly easy, but as you can see I had to make a few discoveries first. There's no DEFA fitting agents in Australia... Waeco are associated with car fridges and refrigerated seat covers in Australia!
    IMHO the DEFA is much better integrated and "resolved". The water-proof fittings, the ability to add a cabin heater and battery charger make it worth the extra.
    When I was looking for an EBH last year, there was no 240 volt version of the "Canadian" EBH. I stumbled across DEFA and was sold.
    Contact Bjørn at [email protected]
    Or from Ireland
    Ireland
    JDM Products
    Unit F. Mounttown Industrial Estate
    Lower mounttown Road
    Dun Laogaire
    Co. Dublin
    Phone: 01-384200
    Fax: 01-214 5024
    More info:
  7. edwardob
    edwardob Member
    227
    33
    ireland
    nice write up on installation........but there is a 240v available and part no quoted above
    i route mine down behind number plate thru the foam ...so it is hidden and facing down looks part of car
    [the black on the grill is just grill blocker]
  8. Braddles.au
    295
    99
    Canberra, Australia
    Hi Edwardob
    So you run the cable from the EBH under the engine? Where do you earth it? I toyed with that idea, but decided that the negative terminal was the right place to connect and there was enough clearance without drive belts in the way. And since the socket will only feed in from the outside, you've got to get the routing decided. Fortunately, my long arms will reach over the back of the engine, so I could unplug the cable from the EBH and try another route.
    The DEFA technical notice provided to its installers (and provided to me by Bjørn) has the plug on the lower grill on the right (left, if viewed from the front). Not only does this interfere with lower grill blocking, it takes the cable too close to A/C tubes in the cramped space on the right (left if viewed from the front) entering the condenser for my liking.
    If the visitors to my blog from Norway, Sweden and Finland are anything to go by, the instructions "keep cable away from A/C and brake lines" aren't adequate for the DIY installer. Google "defa ebh install prius" and you'll find my blog. The responsibility weights hard.
    DEFA | Bradley's Raw Data Feed
  9. edwardob
    edwardob Member
    227
    33
    ireland
    no over the engine...well between the engine and big electric thing...kinda goes down the middle.....then pushed tru foam above radiator[little ap] and the wriggle it tru bumper foam
  10. Braddles.au
    295
    99
    Canberra, Australia
    Eek! It ends up as a nice stealth install, but I can't imagine how much skin it required.:)
    When I was on my back staring at the rear of the engine and wishing to avoid the A/C lines on the right, I couldn't find a safe route to avoid the exhaust manifold on the left. Without a bracket I wasn't sure that the cable would stay away from it.
    I considered the left (looking from the rear) is an easy path to the lower grill as there's a nice opening covered by foam with nothing else running through it. But I couldn't find a safe way from there. That's the best path for the Canadian EBH because it is near the top of the block, but not a model for the DEFA install, if you ask me.
    Are DEFA EBH common in Ireland?
  11. edwardob
    edwardob Member
    227
    33
    ireland
    skin graft from my rear end did the trick!
    ebh common in ireland??? not really ..probably because it not considered cold enough
    but i really appreciate it all year round because the engine is already warmed up..and saves about 50 cent per day fuel
    bout 10-15 euro per month1
  12. Mendel Leisk
    40,457
    There are definitely two schools of thought on Engine Block heaters. We're in a very temperate, coastal zone, but use ours year 'round. And get some puzzled looks from traditionalists.
    The part here was around $90, and installed $300~400. I suppose I could have done it myself, but got it at time of purchase, and with the big numbers flying around (and not feeling like crawling under the car and doing battle right away) thought what the heck. Don't expect it to fully warm the engine: like any block heater, it'll raise the coolant temperature about 20 degrees centigrade. Basically gives the engine a leg-up in the warm up process.
  13. Braddles.au
    295
    99
    Canberra, Australia
    Using all year round is not so silly.
    The DEFA support and download page has a number of good documents including the Technical Handbook; the first few pages of which show the difference between cold and warm starting for fuel consumption, emissions and engine wear according to their tests.
    In my experience, the DEFA EBH can take the coolant from 5°c to 45°c in 2-3 hours. This is in a garage with ambient temperature of 5°C even when it is below zero outside.
    Upon startup I will using move from the garage on EV only but will try to trigger the engine to run. As the coolant circulates it first gets colder as it hits the radiator and then quickly gets warmer, reaching 55-60°c in about 2 minutes of gentle driving. So you still need to run the engine, but you get to higher stages and therefore more efficient running sooner. And the heater works.
    On average Canberra has 60 nights per year below 0°c and 92 per year below 2°c. In fact, the last 2 nights have been 3.7 and 4.1°c and its only Autumn. Since 10°c is a cold start, there's plenty of days that I'll use the EBH and grill block.
  14. Mendel Leisk
    40,457
    <deleted> (should have looked at my contribution up the page, repeating myself) :oops:
