mpg when stopped
Discussion in 'Gen 2 Prius Fuel Economy' started by m177, Jun 5, 2013.
  1. m177
    m177 Junior Member
    I understand that the EPA may not consider stops at traffic lights, but when cars are stopped with their engines running, gas is still being used. I suppose this may be one of the reasons why we get worse gas mileage numbers than what they claimed to get. Or is the amount of gas being consumed extremely small and not worth adding that factor in? If you were to calculate your gas mileage with each fill-up, that is taken into consideration, ymmv of course.
    But with a Prius, or other hybrids, the gas engine is oftentimes off and not using fuel when stopped. Again, when calculating mileage with each fill-up this gas consumption is part of that calculation.
    I know that you can't really calculate mpg for a car that is not in motion, but there must be a clear advantage of having a hybrid when stopped at lights, etc.
    Does the multi-display somehow take this in consideration when calculating the average gas mileage? Is that why it seems to be a little 'optimistic' compared to owners' calculations?
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  3. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    The multi-display is tracking fuel consumed vs. distance traveled, as do most on-board computers. In my BMW while idling at the light I can see the mpg reading drop accordingly. Elapsed time doesn't play into it so no, that wouldn't explain the discrepancy.
    The car company is fully motivated to rig it that way. If it's pessimistic there will be no end of customers bringing their cars in for "poor mileage" without doing the calculations.
  4. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    The mpg reading you get is really a "miles travelled" per "gallons of gas burned". If you travel 0 miles when stopped and burn any amount of gas (idling) you get 0mpg. If you are in the Prius and creeping along in the parking lot, even if you only go 0.1miles, you have burned 0 gas or infinite mpg. On the Prius this gets you 99.9mpg in MPG displays and 0l/100km in metric-lands.
    The Prius engine really only gets mpg in the high 30's. When your traction battery is almost failed and the average "tanks" to 38mpg or something, that is because you are running the gas engine all the time. The ability to shut it off at lights, and when coasting, going downhill, or times of low power demand make the miles per gallon higher because you get "normal" MPGs from the engine averaged with the Prius' infinity reading which it pegs at 99.9.
  5. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Moved to the gen II forums from the Prius v forums.
  6. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    The EPA highway test spends 0% of the time at idle, the EPA city test spends about 5% of the time at idle. (The European test spends 20% of the time at idle)
  7. TheEnglishman
    TheEnglishman Member
    180
    57
    Southeastern United States
    If you are going zero MPH, then whatever amount of fuel you're burning, you're still getting zero MPG.
    :whistle:
    kenoarto likes this.
  8. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    FWIW, if you are not moving and the ICE is burning fuel, you are actually getting a "negative" MPG rather than zero as every drop of fuel burned is calculated in the equation.
    Ron
  9. TheEnglishman
    180
    57
    You can't really get an instantaneous negative miles per gallon, because you can't travel "negative miles." But I get where you're coming from. The Prius is wasting fuel when the gasoline engine is on at a stop and it can lower your average MPG.
  10. dorunron
    3,318
    1,105
    Houston, TX
    It is a fact that if you are not moving and the ICE is burning fuel, your overall MPG will drop which is in reality "negative" MPG. The display will show 0 (zero), however it is not designed to show a negative amount. The only way you could be getting a TRUE zero MPG is to be "not moving AND not burning fuel at the same time". IMO, it is a flaw in the design of the readout's for the Prius but the engineers probably decided that most would not be that critical. However mathematicians can be very critical at times, my self included. But at least the system does adjust the overall readout as the MPG fluctuates through the various driving cycles and routines of daily driving.
    Ron
