Greetings, I am in the process of installing the GNET_RGB_TOYLEX, have the Savv VAC-RV2000 installed, and am running the video, power and ground up to the GNET_RGB_TOYLEX that is mounted on top of the DVD Nav unit, My QUESTION is where can I find a feed/wire to tap into for the REVERSE lights close to under the drivers seat? Do you have to tap into the Backup lights in the rear, and run that wire up there too? I'm sure someone has found a place up front by the driver seat to tap into???? Please advise and BIG thanks! -Dave GNET_RGB_TOYLEX -> http://www.gnetcanada.com/navvideo-models-..._rgb_toylex.asp Savv VAC-RV2000 -> http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=15458
I answered my own question I found this photo that labels the wires in the NAV unit and Reverse is label and works just fine. I just taped into it. I'll post the pic in case any one else needs to know where to find the a Reverse up front on the NAV unit when installing a Backup Camera.
I got it all hooked up and it is working great! I uploaded some pics in the posting below http://priuschat.com/index.php?showtopic=1...ndpost&p=209738 rather not dupe the pics on here! Thanks!
