DDM Tuning HID question
Discussion in 'Gen 3 Prius Accessories and Modifications' started by CdotK, Nov 6, 2013.
  1. CdotK
    CdotK Member
    376
    46
    fog lights are low enough that the glare shouldn't be too bad.. and it cant be as bad as these lifted trucks with the drop in HIDs that absolutely blind people!!! :mad:
  2. CdotK
    CdotK Member
    376
    46
    Would anyone have a recommendation between the 35w or the 55w? i think i am going to go with the 55w for the extra output since im going with 6000K...
  3. xliderider
    xliderider Senior Member
    8,128
    3,266
    Honolulu, HI
    Negative, that's a common misconception. Reality is the fog lights spray light all over the place, even when adjusted all the way down in their lowest setting.
    See the pic that Mo posted here in post 7, where the low beam cutoff is the sharp white light and the HID in the fog lights are the yellow light that is lighting up the entire wall yellow. Very bad glare.
    Fog Lights HID upgrade? | PriusChat
    If you want HIDs in your fog lights, please retrofit some projector lights into the oem shrouds. I did, link in my signature below. I have a few pics in my thread that clearly show the difference in glare between above and below a proper cutoff, and that's with 55w halogen bulbs.
  4. Slick26
    Slick26 Junior Member
    40
    Twin Cities, MN
    I'm new to the Prius, as of last week, and I just bought the DDM 35W 5K set.
    Anyway, I'm really curious if anyone has an idea what the squares are on top of the headlights, right above the cutoff. Mine, of course, does this as well.
    I've never seen anything like this. If it weren't for those squares, the factory Prius projectors have a really decent cutoff.
    Any ideas?
  5. Slick26
    40
    Twin Cities, MN
    Wrong.
  6. Slick26
    40
    Twin Cities, MN
    IMHO 55W is overkill. I've done it before on past vehicles, but it's really too much. Especially if you live in civilization with the rest of us.
    If you live in the mountains or out in the sticks then by all means have at it. But in the cities and suburbs you're going to make the commute miserable for everyone in front of you.
    35W is perfectly fine. Just don't go over 6oooK, then you lose effectiveness, and it really just looks silly.
  7. xliderider
    8,128
    3,266
    Honolulu, HI
    Yes, they're commonly referred to as "squirrel finders". :D
    The squares of light are from little cutouts in the cutoff shield that allow some light to illuminate above the cutoff. The idea is it will illuminate overhead road signs which would otherwise remain unlit if a solid cutoff shield were used.
    Another PriusChat member has retrofitted HID projectors in his headlights and has remarked that road signs are difficult to see. This is because those projector's cutoff shields don't have the "squirrel finders".
    SCH-I535
    Slick26 likes this.
  8. Slick26
    40
    Twin Cities, MN
    I was actually joking with a friend about them being illumination for street signs... I had no idea I was right! LOL
    Thanks for the response.
    I think they look stupid, but obviously they serve a purpose. Hopefully they won't blind anyone with the HIDs installed.
  9. CdotK
    CdotK Member
    376
    46
    Good info ... Thanks!
  10. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    "Why 35W HID Systems?
    OEM factory equipped HID systems i.e. Mercedes Benz, Audi, Lexus, BMW etc all use 35W HID systems because of their reliability and long life span. Higher wattage aftermarket HID systems i.e. 55W, 100W systems are not recommended as they increase the operating temperature of the HID system, affect bulb color temperature, and in general have a shorter lifespan. Higher wattage kits are not that much brighter than 35W systems. a 4300K 35W HID system, is the same brightness of a 6000K 55W HID system. This is because the increased wattage of the 55W systemoperates the 6000K bulb at a higher temperature, changing the color of the bulb and essentially, creating a whiter color more similar to that of a 4300K bulb. "
    Not to mention the fact that a relay is needed with 55w, and not generally with 35w.
    from - XenonSupply: Frequently Asked Questions
  11. CdotK
    CdotK Member
    376
    46
    i have been running the 55w/6000k kit now for week without the harness and they are just fine.
    They are bright and light the road real nice! If they last for less time, im ok with that.. they were only $45 bucks. Not a big deal!
    If they go out or i get a fix-it ticket, ill probably end up buying the 35w 6000K set up as i think the 55w is a little too bright and i know its a matter of time before i get a fix-it ticket.
  12. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    FWIW, a 55W 6000K will have almost the same output as a 35W 4300K setup.
    The higher wattage on the ballast washes the color too, so you generally step down a color when going 55W, 6000K becomes 5000K, etc...
  13. vthreee
    vthreee Member
    48
    25
    i went with 55W 8000k, and did not have any issues. didn't see those grounding shadows either.
  14. mediahound
    903
    155
    Ground shadows are just due to the ground wire orientation on the bulb. You can get cheap $12 HID bulbs on eBay that produce. no ground shadows. You can also modify any bulb so that it will not have them fairly easily.
  15. xliderider
    8,128
    3,266
    Honolulu, HI
    Says the guy who said modifying an H9 bulb to fit in an H11 mount was a major PITA. Or something to that effect. :ROFLMAO:
    SCH-I535
    CdotK likes this.
  16. mediahound
    903
    155
    This one is way easier. You are only cutting plastic in one place, not metal and then another area of plastic like that mod.
  17. burstaneurysm
    469
    144
    Chicago, IL
    55W will kick that down to 6000K, which is definitely usable.
    Also the dude who wants the brightest halogen light bulbs and didn't want to go anywhere near HID, but now want's the not-brightest HID kit. Haha. :D
  18. mediahound
    903
    155
    Don't go by wattage alone. A premium 35w kit (think Morimoto, Xenon Supply, KLight) can be just as bright as a low end 55w.
  19. burstaneurysm
    469
    144
    Chicago, IL
    I meant the color temp. Doesn't matter who makes it, a 6000K kit will not put out the same lumens as a 4300K.
  20. CdotK
    CdotK Member
    376
    46
    4300k D2S Philips = 3200lm (lumens)
    4300k D2R Philips = 2800lm (lumens)
    4300k D2S Philips = 2400lm (lumens) actually 5800k
    4300k D2R Philips = 2000lm (lumens) actually 5800k
    4800k D4S/R (brand) = 3800 (lumens) ** brightest in the market
    5800k D4S/R (brand) = 3300 (lumens)
    7000k D2S other = 1790lm (lumens) *(other bulb brand)
    7000k D2R other = 1390lm (lumens) *(other bulb brand)
    8000k D2S other = 1180lm (lumens) *(other bulb brand)
    8000k D2R other = 780lm (lumens) *(other bulb brand)
    In this example 4800K has the best lumens output.
    I have seen many threads that also say the difference between 4300K and 6000K is only a couple hundred. So over all its a win/win as the HID is producing a much higher lumens output then a stock/aftermarket halogen.
    If you want White output.. stay between 4300-5000K.. if you want some Blue go with 6000K... There is no right or wrong if you get what you want.
    I can tell everyone that my 55w 6000K DDM Tuning kit is WAY brighter (and more blue) than my brothers stock HID kit on his Nissan 350 ... so for me i am happy that the output (lumens) is much better than the stock Nissan HIDs
