Master, engine, VSC and engine lights all came up at the same time
Discussion in 'Gen 2 Prius Technical Discussion' started by riceroni4, Mar 11, 2014.
  1. riceroni4
    riceroni4 New Member
    24
    Perry, Florida
    I just purchased this 2006 Prius from a private owner a few weeks ago and driving home the master warning light, check engine light, VSC and i think its the brake system looks like (O) and the screen shows the red car with ! Once the lights came on I got to 50 MPH it would sound like the engine reving and would not let off until I pull my car over and put in park. I have brought it to an auto scanner trouble code reader on 2 seperate occasions and no codes have come up. The moniter shows that the battery only gets up to 12.4V while it is on. Can it be the 12V battery going dead? The closest dealership is almost 2 hours away and repair shops in the area do not repair hybrids. I really would like to know is it the problem before I order this item.
  2. JC91006
    JC91006 Senior Member
    16,933
    8,643
    What item did you w want to order? Check to make sure your car is not low on oil in the engine
    SM-N900P ?
  3. riceroni4
    24
    Perry, Florida
    I want to replace the 12 volt battery if that is what is needed. I have checked all the fluids and oil seems to be at the right levels and color. The car also feels like it jumps while in park.
  4. JC91006
    16,933
    8,643
    12.4 volts while it's on is a big problem. Someone else will come answer your question about battery and give you some suggestions. Many knowledgeable battery people on here
    The car jumps in Park? When the ice engine starts during mornings?
    SM-N900P ?
  5. riceroni4
    24
    Perry, Florida
    I am not to familiar with how these cars work yet but to an auto illiterate is sounds like the car is stuck in a high gear when driving and wont switch and battery on the display is not charging then in park sends slight jolts moving the car slightly. This started today
  6. JC91006
    16,933
    8,643
    The car only has 1 gear, you won't feel it switch. It's not like a regular transmission.
    Battery not charging on mfd display could be a problem. That's the main hybrid battery state of charge indicator.
    The car jolts in Park because the ice engine is constantly turning on to charge the hybrid battery, you are saying it's not charging properly.
    If the hybrid battery is the original one, it may be failing. How many miles on your car? I would still make sure your 12v battery isn't giving tout all these weird symptoms
    SM-N900P ?
  7. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    The recommended hybrid specialist who is a independent operator is a four hour drive from you.
    Other than those folks, if you local mechanic can't do the work for you, your only choice is the dealer or DIY.
    The indy I am referring to is the following.
    FLORIDA
    Mellor’s Automotive Inc.
    1410 W. Newhaven Ave.
    West Melborne, FL 32904
    (321) 956-1997
    Contact: Joshua J. Mellor
    [email protected]
    These folks are about 3 and a half hours from you. They are indy also and work on Hybrids.
    Auto Repair Shop Largo, FL | Auto Repair Shop 33771 | Karl & Son's Auto Repair Inc
    The Prius does move around a little bit in Park when the engine starts, so that much is normal.
    The lights and the sounds you describe almost sound like the traction battery is failing. Do you hear a fan running in the back? There is a vent on the rear seat on the passenger side. Do you hear a lot of noise coming from that vent when you are driving the car?
    You mentioned no codes. Can you say where you took your Prius to have the codes pulled?
    I would not change the 12 volt battery unless I knew for certain that it is failing. That battery is NOT cheap. Most people get shocked when they learn the cost of the battery, especially for the size of said battery.
    How many miles on your Prius?
  8. Patrick Wong
    18,210
    6,517
    1. Make the Prius READY and open the hood. Look at the inverter coolant reservoir, located between the engine and inverter. Do you see fluid turbulence in the reservoir? If not, the inverter coolant pump has failed.
    2. Given the presence of the warning lights that you described, at minimum the engine ECU and skid control ECU have logged DTC. You'll need to visit your local Toyota dealer to have the codes read, since the generic scanner that you used is not capable of reading the codes.
    3. "Battery only gets up to 12.4V when it is on": What does "on" mean? Is the Prius READY, or is it IG-ON where the dashboard is full of warning lights, or is it ACC-ON where only the MFD lights up and the stereo can be played?
  9. riceroni4
    24
    Perry, Florida
    Yes the fan in the back run constantly I took it to O'rielly's and they brought the code diagnostic tool out and tried 2 separate times to make sure there were no codes showing up and nothing came up. They seen the lights and refered me to the dealership to get a tune up and the sensors updated which I am afraid to drive this car over an hour to get to tallahassee.
  10. riceroni4
    24
    Perry, Florida
    The 12.4 volts is when the IG-on and 11.4 when in ready and the inverter pump shows signs that it is working normal and the reservoir shows the bubble that I have been told is what is normal. I have recently been told to do a coolant bleed
  11. dorunron
    3,318
    1,105
    Houston, TX
    Ok, do what Patrick suggested about checking the turbulence in the inverter coolant reservoir.
    Also, it would be wise to visit a dealer that has the correct device whereas the codes can be read.
    I would also make note of what Patrick said in #2 and 3 above.
    So far it sounds like a hybrid failure. The question is what part of it though. Look at the coolant reservoir and report back. NOTE: The Prius MUST be in "Ready" model when the fluid is flowing.
    If the fluid is flowing, it normally looks like the level of the fluid in the rear of the bottle is higher than the front, plus if you remove the cap on top you would see the liquid moving inside the bottle.
    What we need to know now is if you see the fluid moving when the Prius is in "Ready" mode.
    The bottle looks like what is pictured below. You will find it under the hood.
  12. Patrick Wong
    18,210
    6,517
    OK, if you are certain that the voltage is only 11.4V when READY, this shows you that the DC/DC converter in the inverter is not working. Often, this is because the 100A DC/DC fusible link has blown. The voltage when READY should be ~13.8V.
    Usually the reason that the DC/DC fusible link blew is if someone screwed up a jumpstart, by incorrectly hooking up the jumpstart battery to the Prius. However if this problem only started recently and you did not jumpstart the car just prior to the problem, then the inverter may have just decided to fail for some other reason.
    I suggest you verify the voltage measurements that you just reported, and if they are correct then you will need to arrange to have the car towed to your local Toyota dealer for service. You cannot drive the car any distance in this condition.
  13. dorunron
    3,318
    1,105
    Houston, TX
    OMG, I missed that completely. I do see she posted while I was typing up my reply. 11.4 volts don't sound good at all. All the more reason for the OP to visit the dealer to check things out.
    Still don't know how many miles on this car, but being a 06 model probably out of warranty by now.
  14. riceroni4
    24
    Perry, Florida
    When in ready mode I waited a few minutes from the time I put the car in that position and checked inside the reservoir and there were subtle bubbles in there. The voltage in diagnostic on the screen showed a voltage of 12.4 when in ready mode and did not move from ready to IG-on
  15. riceroni4
    24
    Perry, Florida
    there are 172,000 miles on this car
  16. Patrick Wong
    18,210
    6,517
    12.4V is not good enough, when READY. And actually, your 12V battery is in pretty good condition to produce that much voltage under a very heavy load (since, with failure of the DC/DC converter, the battery has to keep all electrical systems running when READY.)
    Therefore, there is no change to my recommendation that you need to arrange a tow to your local Toyota dealer.
    dorunron likes this.
  17. dorunron
    3,318
    1,105
    Houston, TX
    Inverter not working properly. Should read 13.8 to 14.2 in Ready Mode.
    The question why is it not working correctly. A detailed diagnosis by a dealer should pinpoint the problem area. The inverter is NOT cheap.
    Like Patrick said, I would not drive the car in this condition, I would have it towed in and repaired properly. Sorry to give you information such as this.
    FWIW, a new inverter from Toyota is roughly 4ooo dollars. If Toyota tells you need that, I would try to find a used one and have that installed. Even buying direct online with a discount you are still looking at 3000.
    HYBRID COMPONENTS / HYBRID COMPONENTS / HYBRID COMPONENTS / INVERTER ASSY
    INVERTER ASSY Prius
    MSRP Core ? Online Price
    $4,007.92 $0.00 $3,005.94
    View Part Diagram -- Item #4
    2006 Toyota Prius Parts - AutoNation Toyota Gulf Freeway Parts
  18. riceroni4
    24
    Perry, Florida
    Thank you all for your help. I most def will have to get it checked out by the dealership. I do hope that it is nothing real serious and will most likely get a used inverter if it does need it since I bought the car through private party and have no warranty.
  19. HOWFAST
    HOWFAST Junior Member
    24
    Hawaii
    Could it possibly be the 12V battery in the back? If the battery is bad and the inverter is working properly it still could do this right? I know with a good alternator in a car it will not show proper readings if you try to measure it through the bad battery.
    Gus//
  20. Patrick Wong
    18,210
    6,517
    The 12V battery is not the problem here. If it were, the voltage at IG-ON would be substantially lower than the OP's measurement of 12.4V.
    The voltage when READY should always be greater than the voltage at IG-ON if the DC/DC converter is working.
  21. Mr.Electric
    Mr.Electric Member
    287
    106
    San Francisco
    You could buy an advanced code reader and get the codes we need to diagnose without using the dealer.
