Pa. Emission testing for the prius?
Discussion in 'Gen 2 Prius Fuel Economy' started by edgrzy, Dec 14, 2004.
  1. edgrzy
    edgrzy Junior Member
    Wallingford, Pa.
    Does the state of Pennsylvania require emisson testing on the 2005 Prius?
  2. pino
    pino Junior Member
  3. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Good luck, anything more than a basic tail sniffer - i.e. Dyno, will require dealer testing as a mini-scanner is required to disable the traction control for the dyno run.
  4. smile
    smile Junior Member
    Pittsburgh
    2013 Prius v wagon
    Thanks so much folks. I looked at the website but I'm not sure if "more than a basic tail sniffer" is needed or not. Here is the link:
    PA DEP I/M - Emission Test Definitions
    I'll probably take it to a dealer.
  5. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    If you are in Pittsburgh or Allegheny County, according to the website link above the 2013 Prius V Wagon will require the OBD test. That is a common test that most states are running today. As long as your car doesn't have the check engine light ON, more than likely you will have no problems passing the test. Things that will create a problem in that inspection also include lights not working, wiper blades needing replacement, severely broken windshields, horn not working correctly, brakes not stopping properly and tires that are worn down to the wear bars or worn down on one side. The usual stuff.
    The 2005 Prius should fall under the same description in the previous paragraph that the OP was asking about.
    They pretty much cut out the tail pipe sniffer in most states a while back. It is generally used on older cars and trucks that are not computer controlled. IE: Pre 1980. Since fuel injection came into play along with the electronic ignition and the OBD plugs, more and more of the state inspections revolve around the onboard system working correctly or incorrectly. (check engine light on or off). The test will also see if the OBD system is working properly and that no codes are present or pending. If you were to clear codes right before a OBD inspection, the car could fail the test since one of the requirements of the test is that all of the OBD system being checked is reporting normal. A recently cleared system will not show anything for a designated amount of cycles. Think buying a used car and then a couple of days later dash lights up. Simple trick, clear codes then sell car to sucker. Happens from time to time in the used car industry.
    Hope this helps you and that you were concerned about what test for your Prius listed in your avatar.
    On-board diagnostics - Wikipedia, the free encyclopedia
    FWIW, this thread is almost ten years old but the information does apply to todays standards.
    smile likes this.
