The Hybrid Convertible Project Prius v
Discussion in 'Prius v Technical Discussion' started by Bill the Engineer, Aug 8, 2014.
Thread Status:
Not open for further replies.
  1. Bill the Engineer
    1,048
    2,278
    467
    At the beach in Delaware...
    A bit of a moot point since the engine has been an inert hunk of iron for about 15 years... but when new it had a 250 hp (190 kW) 326-V8.
    Prius v (lowercaes v) Hybrid system net power: 134 hp (100kW) which is about half. That doesn't bother me at all. I'm not looking for a tire burner. The heaviest parts of the Firebird (the original engine, transmission, rear axle , suspension and sub-frame) will no longer be under the car.
    SAAB 93b Wheelbase = 2,489 mm (98.0 in)
    Prius C Wheelbase = 2,550 mm (100.4 in)
    SAAB 93b Width = 1,581 mm (62.2 in)
    Prius C Width = 1,690 mm (66.7 in)
    Quite possible if you wouldn't mind fender flares like a rally car!
    Bill the Engineer
  2. Robert Holt
    Robert Holt Senior Member
    1,313
    888
    ^^^^ At the thought of fender flares on my old SAAB with a Prius drive train (and disk brakes!), I am drooling!
    God I wish I was an engineer!
  3. Beachnut
    Beachnut Member
    185
    43
    Ditto the above for me(y) Glad to hear you have a background of knowledge and hopefully you can overcome all the roadblocks.
    On our 69 Skylark, the seams just below the rear windshield, at each upper corner of the 1/4 panel, (see the photo below, it is the white area's that are lead), seem to be a weak / flex point on the body. Those 1/4 panel seams were originally lead filled, and they were cracked from flexing, before we began towing a trailer, or restoration. When we restored the Skylark, I had it bead blasted down to bare metal, the lead was obvious on those seams. The body shop told me they did not do lead anymore, so I am sure it got bondo of some sort. We have a hair line crack forming on the drivers side on that seam now, so do pay particular attention to that seam on your car, not having a usual frame might make it even more vulnerable to cracking. Of coarse,, we did not help matters as we sold that smaller tent trailer, and bought a BIG ONE, so towing it around with a welded on hitch, may have potentially contributed to more of that body flex.
    Good Luck and keep us updated.
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    Aaa...
    I don't think you need waste time explaining "why" you want to do the project or justifying the vision to those that think it unwise.
    As Nike says....Just Do It.
    As for myself? If you succeed? I'll say I never doubted you.
    If you fail, I'll say I always thought it was impossible.
  5. Bill the Engineer
    1,048
    2,278
    467
    Lunch Time project at work coming along. I have sent 3D CAD files off to be quoted at a 3D Printer Rapid Prototyping shop.
    Bill the Engineer
    NR427 likes this.
  6. bisco
    51,032
    :cool:love it.
  7. Beachnut
    Beachnut Member
    185
    43
    I must have missed something. What does "HSD" stand for? Looks good!
  8. Midesaka
    Midesaka Junior Member
    Southern MS
    I think this is an adaptation of the Prius v's Hybrid Synergy Drive badge that is more in line with the aesthetics of the Firebird.
    sfv41901 likes this.
  9. xliderider
    xliderider Senior Member
    8,033
    3,211
    Honolulu, HI
    Post #2 shows that the OP is trying to match the font style used for the Firebird's 326 engine displacement badge. ;)
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    What they said
    orenji likes this.
  11. Bill the Engineer
    1,048
    2,278
    467
    Progress has been very slow as I continue to drill-out bolt heads to get the old suspension and sub-frames off. Once there is something photogenic to report I'll post a better update.
    Bill the Engineer
  12. bisco
    51,032
    thanks for checking in, sounds boring!:p
    Robert Holt likes this.
  13. miscrms
    miscrms Plug Envious Member
    2,076
    523
    Phoenix, AZ
    Awesome project, can't wait to see more :)
  14. Pridoogv5
    Pridoogv5 New Member
    Belmont, ca
    Wow, I can't decide if this is a cool idea or just a really dumb idea. Ultimately, all that counts is that it is the OPs idea and his to complete and live with. If it were me, I would stick with a coupe as a vert just seems like asking for trouble. Did you ever consider just doing an electric/propane/nat gas conversion? Best of luck!
  15. Beachnut
    Beachnut Member
    185
    43
    Drilling out bolts, wow, no fun! Rust can be so much ---Fun! Take care, and watch those fingers and eyes!!
  16. nsfbr
    nsfbr Member
    112
    30
    Northern Virginia
    2013 Prius v wagon
    For some of us, there is no boring part of your project. Take pictures, post them. You won't regret it and we get to ooh and aahh. Win-win!
  17. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    We all like car porn
  18. Bill the Engineer
    1,048
    2,278
    467
    Well, here's the update, car porn or not.
    Surprised this afternoon while removing the old rear suspension. The right rear leaf spring (monoleaf) was broken at the shackle. Good thing I took the car off of the road when I did!
    Bill the Engineer
  19. Beachnut
    Beachnut Member
    185
    43
    Nice photos! You must have broken it with all that old V8 muscle power to the right rear wheel!!
    What do you have the body suspended by, ropes up to the ceiling rafters?:eek: It looks like it is just floating in that photo.
  20. Bill the Engineer
    1,048
    2,278
    467
    There are two jack stands holding the body forward of the rear axle at a reinforced area. They are obscured in the photo by other things due to the angle of the camera. The anti-grav units aren't installed yet. ;)
    Bill the Engineer
Thread Status:
