Mold Smell in 2010 Prius
Discussion in 'Gen 3 Prius Main Forum' started by ChickenJ0hnny, Jun 12, 2014.
  1. ChickenJ0hnny
    ChickenJ0hnny New Member
    Overland Park, Kansas
    I have a 2010 Prius and it has developed a very strong mold smell/odor. It is strongest when the car has been sitting with the windows up. I have tried many of the tips in the forum regarding not using the recirc mode. I've clean the car inside and out, mats, carpeting, every compartment.
    • I have talked to the dealer parts counter and replaced the cabin air filter with the carbon filter and used the 2 can treatment that Toyota sells (one in the a/c drain x2 and the other in the air intake.). No joy.
    • I took it to the service department they did the same thing - again, no joy.
    • They have asked me to bring it back for, and I quote, "exploratory surgery." I asked if this the covered under the Toyota Certified Warranty. He could not confirm that it would be covered.
    Questions - has anyone had a similar experience?
    Does anyone have experience with the Toyota warranty program and this issue?
    Is there a Technical Service Bulletin (TSC) on this?
    Thanks.
  2. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Debris can build up under the cowl cover/mesh. This will rot (compost) and give you the moldy smell. To fix they must remove the wiper arms and a few other things before they can remove the cover and clean it properly, also accessing the air intake ducting. It should be about an hour labor. It could be covered by warranty, depending on how important customer satisfaction is to the dealer and to Toyota. If it was caused by leaves etc. then it would be the customers fault (parking where he/she shouldn't). It can also be caused by mice nesting in the car. That would be Toyota's fault, for not providing proper meshing to prevent them from getting in.
    Mice can also nest much further into the air system, and that will take much longer to fix.
  3. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    Both good points and it could be a plugged AC drain causing mold growth too.
    Squirting all the deodorizer in the world in won't solve the problem if the drain isn't working right.
    All of those things need to be checked out; some are easier than others.
  4. KhaPhoRa
    KhaPhoRa Member
    168
    37
    I just did some work on one and it had a strong moldy rancid water smell.. It was coming from the spare tire well and the 12v well. This was in a gen2 so perhaps it's not an issue for you, but I've seen plenty of stagnant water in both of those places.
  5. Ltlg
    Ltlg Junior Member
    North Dakota
    I use to detail vehicles and this one truck we had steam cleaned wasn't fully dry before we put the floor mats back in and a few weeks later MOLD! It was in the carpet and on the backsides of the mats. Just another option if you detailed your car lately.
  6. phoenixgreg
    phoenixgreg Senior member
    1,157
    295
    66
    Phoenix
    First of all, you need to determine if the odor is truly coming from the AC vents, especially when the system starts up after sitting in the heat. If so, here are several pictures of how to cleanse the evaporator coils and how to get at the outer air intake in case there's something stuck inside of it:
    Wiper cowl area 001.JPG Wiper cowl area 002.JPG Kool It.JPG Fan and filter box 001.JPG Fan and filter box 002.JPG Fan and filter box 003.JPG Inside evaporator coil 01.jpg Inside evaporator coil 02.jpg passenger vent tube removed.jpg Evap coil cleaning 003.JPG Evap coil cleaning 001.JPG Evap coil cleaning 002.JPG
    Some of these pictures are courtesy of The Critic who discovered how to gain access to the evaporator coils from the passenger foot well. To remove the vent tube, take a very small screwdriver and insert it carefully along the top of the vent tube edge which faces the front console and slowly press downwards until the small clip is released. Then roll the vent tube towards the firewall and it will come free exposing the heater coil and the evaporator coil. Kool It is a product that can be applied to the upper and lower coils as a foam which should kill and release any mold build up on them. I also recommend a rinsing afterwards making sure the drain tube is working.
    #6 phoenixgreg, Jun 13, 2014
  7. engerysaver
    engerysaver Real Senior Member
    426
    133
    Tyler, Texas ; USA
  8. TRUC NGUYEN
    TRUC NGUYEN Junior Member
    2014 Prius Plug-in
    try this works pretty good
  9. TRUC NGUYEN
    2014 Prius Plug-in
    Meguiar's G16402 Whole Car Air Refresher Odor Eliminator - 2.5 oz
  10. jayl
    jayl Junior Member
    61
    md
    Can you get to the coils without drilling ?
  11. phoenixgreg
    1,157
    295
    66
    Phoenix
    Yes - follow the last paragraph in italics that you quoted above. Once that white vent tube is released, you can see and access both the heater and evaporator coils. Another option is to pull back the upper left section of carpet in the passenger foot well to reveal the drain tube. You can pull apart the rubber hose piece from the plastic piece and inject Kool-IT coil cleaner directly in the base of the evaporator chamber, which can get moldy.
  12. Maj
    Maj Junior Member
    Orlando, FL
    I bought my car used and it has always had an odor when sitting for a while with the windows rolled up. Even after shampooing/cleaning/airing out, the odor persisted. A coworker commented one day that a friend sold their Prius because odor from the batteries was annoying. I then decided to sniff the battery vent grill in the back seat and noticed it is the same odor that permeates the car. Anyone else have this experience?
  13. Cinzia
    Cinzia Junior Member
    Surprise, Arizona
    I have the same problem, and the dealer has been no help at all. All he offered was a bleach clean on a brand new car, that never had a new car smell, because of this awful odor. This is my first C, I had a regular Prius before, and never had this problem. I think this is a safety issue as it is awful to get into. I'm wondering what chemicals we are breathing in.
  14. ChickenJ0hnny
  15. ChickenJ0hnny
    The issue turned out to be that the fastener for the drain tube had failed and the a/c had a slow drain into the passenger footwell and then it molded. Dealer removed carpet and cleaned repeatedly, the smell still remained. The dealer used ozone to no avail. Ultimately I used Chlorine Dioxide - it is used to remove mold and musty smell from boats. There are several products available at marine or outdoor stores. Odor free in KC!
    Mendel Leisk and retired4999 like this.
  16. phoenixgreg
    1,157
    295
    66
    Phoenix
    But if the drainage condensate could not get out thru that tube, it may have also backed up into the evaporator chamber and developed mold up inside it too. Now that the drain is fixed, you might consider performing an evap chamber sanitizing using a product like Kool-it.
  17. Cinzia
    Surprise, Arizona
    appreciate everyone's helpful replies. I'm just annoyed we even have to deal with this problem, in a new car! I still feel Toyota should be making more of an effort to resolve this, than we are. :(
  18. Lunnara
    Lunnara Junior Member
    2014 Prius Plug-in
    @Cinzia Agreed. We're experiencing this with our 2014 Prius Plug-In. We brought our car to a dealership (it's still under the initial warranty) and they said they are not covering it. Probably will contact Toyota Corporate and I suggest you do the same. It looks like it is an old problem that they still have yet to fix! See this old thread for more details and instructions:
    Taking a Stand on 2007 Prius AC Mold Problem! | PriusChat
