Update the navigation firmware?
Discussion in 'Gen 2 Prius Audio and Electronics' started by Delta Flyer II, Feb 9, 2015.
  1. Delta Flyer II
    Delta Flyer II Active Member
    547
    248
    69
    Just picked up a 2007 Prius 5, is there a way to update the navigation software in this vehicle?
  2. Yakoma
    Yakoma Active Member
    470
    125
    sss
    Unless you need real-time traffic, I'd say skip it and use the maps on your smartphone instead. If you don't have a smartphone, use the $169 to buy one. 2nd option: get a real good Garmin with lifetime maps and real-time traffic instead.
  3. sorka
    sorka Active Member
    1,030
    199
    Merced, CA
    2019 Prius
    Or you could buy last years update on ebay(actual DVD, not a copy) for half that price or one that's 2 years old for even less.
  4. nitteo
    nitteo Junior Member
    29
    Weston FL
    just use the app waze.
  5. tegenwind
    tegenwind Junior Member
    Netherlands
    I understood that for the cheap ebay version to work, you first need to take out the dome fuse. Then wait 5 minutes. And then put it back, and start the car.
    I wonder if doing that is going to mess up all sorts of other stuff, like the smart key for instance. Anyone?
