pH testing coolant.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by messenger, Jun 1, 2015.
  1. messenger
    messenger Junior Member
    30
    Fairfield, IA USA
    I picked up a 2009 a couple of weeks ago (76,000 miles) off of craigslist, it was listed so cheap I thought it was a scam but it turned out to only be a couple of miles from my house so all was good.
    The records showed this car was into the Toyota dealer 5 months ago for a recall inverter pump replacement so I figured the inverter coolant was newish.
    Don't know if this pH test is indicative of older coolant but here it is.
    From left to right:
    Far left side is from the Prius radiator.
    Next over is from our 1993 Camry this has Prestone extended life in it and most likely has the same mileage on it as the Prius.
    Next is the coolant from the inverter reservoir.
    And on the right is new Zerex asian coolant.
    As you can see the newer Toyota coolant and the new Zerex coolant show a pH of around 8, the Prius radiator coolant shows a pH of around 7 and the Camry around 6.5
    I was expecting to see just the opposite but the coolant seems to age to a lower pH not higher ?
    Tim
  2. Patrick Wong
    18,200
    6,500
    Yes, the coolant turns acidic as it ages, hence a lower pH reading.
  3. bisco
    51,848
    congrats on your new wheels!(y)
  4. messenger
    30
    Fairfield, IA USA
    Ahh I had it wrong I was thinking a lower number was more alkaline but just the opposite now I get it and yes time to change it along with the trans fluid.
    Thanks
    Tim
  5. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Read post #11
    Fluids | PriusChat
    Most likely the inverter coolant was NOT drained/filled. Financial disincentives to do so.
  6. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Does the coolant in the reservoir cycle in normal use ?
  7. Mendel Leisk
    41,334
    Just speculating: say the fluid level goes up/down maybe 1/4" due to temperature expansion. That's enough to keep the fluid roughly homogenized, albeit with a bit of a lag.
    I think the coolant in the reservoir circulates, albeit with some reluctance.
  8. SageBrush
    11,627
    2,533
    Southwest Colorado
    Then you think the pH differences OP found are an artefact?
    I did pH testing a few months ago with similar results to OP:
    #20
    As promised, pH testing:
    1. Coolant from Inverter Reservoir, ~ 50k miles use
    2. New Asian Zerex Coolant
    3. Ruby Red Grape-fruit Juice
    The strips are "URS-6L," made by teco diagnostics as a urine dipstick. The pH test is the second from the top and ranges from pH 5.0 on the far left to pH 8.5 on the far right. The test relies on color change of bromothymol blue and methyl red to pH. This is a variant of the 'universal indicator' method.
    Conclusions:
    1. Ruby Red Grapefruit juice is safe to drink, at least pH wise. The color change took time, so we are not reading the color of the juice. The strip appears to be working.
    2. New Asian Zerex Coolant is alkaline
    3. Used SLLC is slightly alkaline. Time to replace ? I think so.
    View attachment 71135 View attachment 71136 View attachment 71137
  9. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    and that's why you need to change it cause acid will eat up all the alloy in your cooling system. if your not gonna diy, just wait to your next service interval, no need for a special trip since its still alkaline
  10. pasadena_commut
    pasadena_commut Senior Member
    2,590
    768
    Southern California
    Bumping this thread as it is good a place to post this as a new one.
    Today I checked the pH and DC voltage to ground for the ICE coolant, inverter coolant, and brake fluid. In each case a few drops of the fluid were removed with a clean (actually sterile plastic oral) syringe and put on pH paper. For the DC voltage the positive probe was wiped clean with a dry paper towel and dipped in the reservoir about 1 cm with the negative probe placed on a clean bolt. The brake fluid cover and surrounding area were wiped clean and allowed to dry before it was opened.
    Inverter coolant: pH 8.5, 147mV
    ICE coolant: pH 8.0 or 8.25, 39 mV
    Brake fluid: pH 6 (???), <25 mV
    For the coolant the mV started lower and slowly went up. When it stopped increasing the value was called. Not sure why this happens, it could be that the fluid reacts with the probe. It didn't matter which ground point was used for the negative probe. Odd that the loop with the slightly lower pH had the lower voltage. If the voltage was resulting from corrosion I would have guessed it would have been the higher voltage.
    I think the pH value for the brake fluid was meaningless - the pH paper didn't change color, it just got wet. I think it was just what happens when oil is placed on it. The voltage in this case started at 25mV and fell steadily, the opposite of the coolant. When it got to 16 mV I gave up since it didn't seem like a good idea to leave that reservoir open for very long.
    Broke one clip removing the front tray. Another popped out and performed a delightful little dive as if off a spring board, up and then down into the space between the motor and the inverter, where it disappeared, probably never to be seen again. I don't think anything moves in that region, and I made sure it didn't ricochet to near the moving parts on the throttle body. It didn't fall out the bottom, hopefully it shakes through and out at some point.
