My Toyota Prius 2010 caught fire
Discussion in 'Gen 3 Prius Main Forum' started by Firnaz, Dec 12, 2015.
  1. Former Member 68813
    3,524
    983
    US
    There are plenty of examples of prius fires on the net, but i failed to find any statistics. Anyone else?
    51,032
    should we compare to all gassers, or does each model stand alone?
    who said prius couldn't burn rubber?
  3. El Dobro
    El Dobro A Member
    7,074
    3,258
  4. ChapmanF
    17,186
    Ok, I see 13 fire pictures here ... about six look to have an origin in the right front fender area, with the others either being hard to place, or definitely looking like the origin was somewhere else. The silver Gen 1 made me sad. Somebody remind me to go check my bus connections when the weather warms up.
    But I'm not sure what we learn just by stacking up pictures. Those 13 pictures show 0.00025% of Priuses sold. They look to have a few different points of fire origin. I think we would probably learn more by trying to group similar cases together and look for common elements.
    That was why I started the Gen 1 fires at ECU sense connector thread. It seems like maybe there's a feeling here that a Gen 3 fires originating near right fender thread would be worth starting, and then trying to collect technically useful information about them.
    I really wasn't kidding upthread about seeing if some Gen 3 owners could get thermal images of that area (baseline and periodically, before any trouble is suspected). Those imagers like the FLIR One are really cheap these days, and we might learn something.
    -Chap
  5. bisco
    51,032
    some posters are inflammatory and excel at hyperbole. but at least he asked for data.
    has anyone ever tried to figure out why gassers catch fire?
  6. ChapmanF
    17,186
    I don't think I understand the question. I don't think I'm on a "hybrids" team playing against a "gassers" team. There are car fires for lots of reasons involving lots of models, but any time there is a particular model that begins to seem to have similar incidents starting in similar places, I'm pretty sure people do try to figure out why. If a cause is found, it's typically something peculiar to that model, not something universal to "gassers" or "hybrids" as a category.
    I have a personal interest in the Gen 1 incidents that start near the battery ECU, because I have a Gen 1 and I like it, and I would be sad if something happened to it, so if the power of PriusChat is ever able to identify a pattern, likely cause, or likely preventive measure, I'll probably be out there with wrenches doing the preventive measure.
    If I were a Gen 3 owner I'd probably be following the right-fender discussion with some interest too, not in an alarmist way, just a will-I-learn-anything-from-this-that-I-can-employ-to-take-better-care-of-my-car way.
    -Chap
  7. wjtracy
    wjtracy Senior Member
    11,359
    3,606
    Northern VA (NoVA)
    Yes I believe earlier in the thread there are some statistics in the links...electrical/mechanical problems seem more the cause than fuel or anything
  8. bisco
    51,032
    unfortunately, we won't learn anything from pictures of cars on fire. it would be more helpful, if anyone were interested beyond morbid curiosity, to research what might already be known about the causes of these or any fires. personally, if i were concerned, i'd buy a lottery ticket.
  9. wjtracy
    11,359
    3,606
    Northern VA (NoVA)
    I believe NHSTA has data on fires but not sure if it is public...FOIA disovery do not know
  10. ChapmanF
    17,186
    You only need FOIA if the agency doesn't make something public to begin with. :) NHTSA has a website with a search. Check my ECU sense fires thread, you'll see links.
    -Chap
  11. Former Member 68813
    3,524
    983
    US
    i disagree with you on this. if you don't like the pictures, don't look at them. if you have a problem with me, put me on your ignore list. i won't mind. i don't find your posts helpful either.
  12. ChapmanF
    17,186
    Jacek, have you been able to draw any general conclusions toward a taxonomy or an understanding of causation of these incidents from the 13 photos you posted upthread? Could you elaborate?
    -Chap
  13. gmcneil05
    gmcneil05 Member
    118
    36
    Avon Park, Florida
    The first picture is from a tv show. They ran it out of oil and blew a hole in the block. And no it didn't catch on fire. That picture was just taken at the exact time it flung a rod.
    iPhone ?
  14. BZzap!
    BZzap! Senior Member
    1,607
    878
    Let's be real. There are a lot of Prius haters out there. That doesn't exclude the press and the so called automotive and consumer magazines that sensationalize. Subjective minds have been bashing the Prius for years. It bothers me when negative press photos pop up without any explanation of circumstance.
  15. Former Member 68813
    3,524
    983
    US
    it's hard to make any generalizations beyond the facts that prius fires do happen and right front corner is a common fire site.
    according to this site: http://www.waltersforensic.com/articles/fire_investigation/vol3-no1.htm
    Surprisingly, there is little published information relating to vehicle fires, and most of it deals with crash-related fires which are rare
    but they also state:
    Fuel system leaks are the most common causes of automobile fires.
    conceivably, fuel could spray from a faulty fuel rail in front of the engine causing a fire.
  16. bisco
    51,032
    i read about another fire tonight.
  17. DRACO
    DRACO Member
    362
    77
    Rancho Palos Verdes, California
    2002 Prius
    Not for nothing but when I did my recent HID upgrade I did notice the connectors were quite discolored due to heat
    I think all should take a close look at theirs and consider changing them to ceramic connectors
  18. Former Member 68813
    3,524
    983
    US
    this is certainly a possibility, but would not explain fires that happen when Prius is parked with all systems off (relatively common scenario).
  19. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Just to be clear on what people are saying: is this front-right as in US passenger side? The side with the hose that needs to be moved out of the way when the headlight bulb is changed?
  20. xliderider
    xliderider Senior Member
    8,033
    3,211
    Honolulu, HI
    Yes, and yes.
