  1. SwamppThingg
    SwamppThingg Active Member
    235
    443
    Mount Prospect, IL
    Due to unforseen circumstances I may have to get rid of my Prius.
    In a sick twist if fate: this arrived after months of waiting for it in the mail.
    Guess it'll have a place of honor on the dash of whatever may come next.
    I'll likely have some stuff for sale.
    I don't have much... but have no use for what I do have. So let me know if you're interested in anything.
    #11621 SwamppThingg, May 6, 2016
  2. MPGRaja
    MPGRaja Senior Member
    469
    1,680
    Corona
  3. granTORRESmo
    granTORRESmo Senior Member
    237
    648
    Norcal
  4. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    Very nice install job! You kept it simple!
    Get the best 6x9's you can for the fronts and you'll really notice the improved bass. I went with JVC, but of course there are many brands.
    Dylan Doxey and MPGRaja like this.
  5. granTORRESmo
    237
    648
    Norcal
    I see lots of that #secretstuff on Instagram. Looking crazy good(y)(y)
  6. Burna J
    1,069
    3,338
    53
    Long Beach, CA.
    bonchang, PriiPrii, sfv41901 and 3 others like this.
  7. CoolPrius
    CoolPrius Active Member
    218
    290
    86
    Virginia
    2018 Prius c
  8. andino
    andino Senior Member
    746
    551
    San Jose, CA
    Had a lot of reading to get done today so I shot my third brake light with some smoke spray between readings. Need to let the clear cure for a bit then I'll hit wetsand/compound and spray more clear to get it smooth. Next up my tails in red but I need to set aside time to do them. Maybe debadge the rear but I'll need head back to socal to shoot in my parent's garage where air compressor and stuff are so I can fill and paint the holes.
  9. HelloHybrid
    HelloHybrid Senior Member
    482
    1,483
    Was thinking of pulling the trigger on the $99 eBay lip and came across this. Curious if it'll fit and how it'll look.
    bonchang and Johnsk93 like this.
  10. andino
    746
    551
    San Jose, CA
    There's a flat (with single fin) panel under the bumper to keep the airflow smooth. Not sure how that would fit on with the diffuser we have since its a wedge shape.
  11. CoolPrius
    218
    290
    86
    Virginia
    2018 Prius c
    Accordlayingkit and RollinBad like this.
  12. Gaspeed
    Gaspeed Senior Member
    286
    1,624
    San Diego CA
    Trying to wash my car like a professional... Keyword "trying" (n)
  13. saulbassfan
    saulbassfan Senior Member
    979
    3,108
    Southern California
    Gaspeed likes this.
  14. andino
    746
    551
    San Jose, CA
    Nice! What conditioner are you using? @Gaspeed
  15. Gaspeed
    286
    1,624
    San Diego CA
    Yes, it's my Foam cannon. It's the first time I'm using it on the Prius and it works well. I'm really satisfied with it. I should have bought this a long time ago!
    Accordlayingkit likes this.
  16. Gaspeed
    286
    1,624
    San Diego CA
    I'm just using Chemical Guys GlossWorkz which is my favorite shampoo. My car is coated with CQuartz UK that protects my paint. The beading is crazy when I wash the car and is super easy to dry. I just recently bought a cheap pressure washer and foam cannon and I'm pretty amazed with the amount of suds I get with my cheap nice person setup. Should have bought this a long time ago!
  17. FinToy
    FinToy Active Member
    145
    141
    Finland
    Next time try to avoid direct sunlight. It makes the foam dry too quickly and may cause problems when trying to wash it off. I guess you already knew it, right (y)
  18. Gaspeed
    286
    1,624
    San Diego CA
    This is not a problem for me. I used Chemical Guys GlossWorkz which utilizes pH-balance cleaning technology.
    "GlossWorkz is gentle enough to wash your vehicle in direct sunlight without streaks or spots. The pH-balanced paintwork cleanser rinses clean to always ensure a smooth finish that is free of dirt, debris and contamination."
    I even let the foam dwell for 7 minutes under direct sunlight and it rinsed off clean with no streaks or spots. GlossWorkz is an awesome product.
    m3pare, FinToy and Accordlayingkit like this.
  19. saulbassfan
    979
    3,108
    Southern California
    Looking online for Toyotafest coverage
    Seeing some videos and images surface. #serectstuffrevealed
    [​IMG] [​IMG] [​IMG] [​IMG]
  20. Friend of Bill W.
    109
    164
    Elkhart, IN
    In the past few days I've upgraded to LED interior and front parking lights, license plate lights, just ordered hids will install soon. And these little TRD center caps stickers. 1462930960915.jpg 1462930968286.jpg 1462930984486.jpg 1462931001877.jpg 1462931011747.jpg 1462931023816.jpg 1462931040106.jpg
    aportades, orenji, MPGRaja and 11 others like this.
