2006 CEL question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by zytra, May 12, 2016.
  1. JC91006
    JC91006 Senior Member
    16,669
    8,516
    You're not really 100% sure the quality of the modules you are buying. Buying another module won't necessarily guarantee you anything better than the ones you have now. They are used modules from another pack.
    Since you have what seems to be good modules, why give them to another person to sell back to someone else? Now that you've taken it apart once, the 2nd time (whenever that will be), will even be easier. And with the HA charger, you can balance the pack every few months with relative ease.
    If you don't mind, don't turn in the good block mate from block 3. I'll pay you the $15 for it. I'll get it from you, close to your work location
  2. zytra
    zytra Junior Member
    78
    california
    I'll do what you say and only replace the two modules in block 3 and keep my modules 21/22.
    is it really important to also replace 24 which checked out okay, using the same reasoning that you had about the quality of the modules I bought, for all we know my module 24 could be better than the 2 that I bought.
  3. JC91006
    16,669
    8,516
    What's the serial number on the 2 you bought? The 4th digit will tell you the year the pack was produced. Your modules were from 2006, which should have a serial number 4th digit of "h"
  4. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    Still odd that you had two weak blocks even though one was definitely bad because of one module with
    a dead cell in it.
    I guess you'll find out when it's back in the car and you've put some miles/hours on it to see
    if the DTCs stay away or not.
  5. zytra
    zytra Junior Member
    78
    california
    1 Original module: 072H9A10148E
    One off the ones I bought: 092GCA02312E
  6. JC91006
    16,669
    8,516
    The "g" is from a 2005 module. So theoretically, your original 2006 modules will be stronger than the ones you bought. But that's not always the case.
    I recently bought 2 "H" modules for my 2005 "G" pack. The "H" modules I bought were much stronger than my original pack.
  7. zytra
    zytra Junior Member
    78
    california
    Putting it back together. I decided to just replaced the one bad module. As you guys said I'll probably have to redo this sometimes anyway.
    Let's see!
  8. zytra
    zytra Junior Member
    78
    california
    Finished putting the bars back and black cover and about to close the enclosure.
    As I finished I measured the voltage on the two main wires and saw it slowly going back to 0V. Started from 9V and it took maybe two minutes to reach 0V. And found that odd. It's now steady at 0V. What's the reason for that?
  9. jadziasman
    1,355
    487
    District 6
    You will not read battery voltage until you re-install the service plug - that orange handle thingy that you removed
    before you started to remove the battery from the car.
    If you did re-install the service plug, did you do it correctly - in, up, and then down to lock it?
    You will probably have 230V since you charged your modules above 8V if I recall correctly.
    Did you use a torque wrench to tighten down the 56 nuts on the modules to 48 inch-pounds? That's the main
    reason you needed a 1/4" drive torque wrench.
    Don't re-install the battery into the car until you've confirmed the torque values are correct. If you don't you might
    get arching and sparking when the battery is charging or discharging at 100 amps. One person discovered that the plastic
    carrier for a bus bar had melted on two of the modules in his battery :eek:. Don't know the outcome (or remember) with that.
    #109 jadziasman, May 19, 2016
  10. zytra
    zytra Junior Member
    78
    california
    yes 48 in.lbs on all 56 nuts.
    and now, I haven't reinstalled the orange plug and won't until the battery is back in the safely (unless you guys tell me it makes sense to test it before bringing it back in the car. One thing I know is that I won't transport the battery in the car with that orange plug installed
  11. zytra
    zytra Junior Member
    78
    california
    when I installed my charger last week end, the manual said to check the voltage between the 2 main wires even though the orange plug was out. the manual said that I should be reading < 1V. so I was surprised to read something higher. Difficult to install the bus bars incorrectly, not like there are ways to make mistakes.
  12. jadziasman
    1,355
    487
    District 6
    There's no danger of installing the service plug with the battery case open. Here's a photo of a helpful hobbit checking the voltage on his battery. As you can see on the right side of the photo - the service plug is installed.
    You will get the same voltage at the two orange cables inside the BCU case.
    Of course you do need to have the service plug removed to connect the two orange cables inside the battery control unit compartment but you don't need to do that if you're merely checking the voltage.
    Just don't forget to remove the service plug again before you put the battery back in the car when you reinstall the other two orange cables that are behind the rear seat that connect battery power to the car.
    #112 jadziasman, May 19, 2016
  13. zytra
    zytra Junior Member
    78
    california
    I can give it a try - and remove it afterwards like I said.
    I just don't understand why I am reading any voltage with the service plug off. makes me something is wrong.
    I did it again, it starts from 12 and slowly going to 0 (a couple minutes).
    I wait a little bit and redo it, same thing. kind of worries me
  14. jadziasman
    1,355
    487
    District 6
    That is odd. I haven't seen that on the batteries I've worked on. Always reads 0V there with the plug removed.
    Wish I could offer some guidance here - maybe ericbecky or S Keith know what's happening.
  15. zytra
    zytra Junior Member
    78
    california
    Wait that's probably normal it is floating since it's an open circuit. When I measured t last week end the 2 orange wires from the car were connected to the battery with the service plug off.
    If I put the service plug I'll read the 230 as it wont be floating anymore
  16. jadziasman
    1,355
    487
    District 6
    Better get the input of a few other people before you proceed. It isn't normal and its cause is lurking somewhere
    inside that battery.
  17. zytra
    zytra Junior Member
    78
    california
    All good with service plug on a nice and steady 216 V
  18. ericbecky
    ericbecky Hybrid Battery Hero
    4,381
    3,242
    Madison, Wisconsin
    No danger.... um I don't think most people exposed to 215v DC wouldn't say there is *no* danger.
    In fact this is where it may be the most dangerous.
    Should a child, pet, or knowledgeable coworker touch the wrong areas by accident, it would be quite bad.
    You should be on high alert when checking a battery in this manner.
    #118 ericbecky, May 19, 2016
  19. jadziasman
    1,355
    487
    District 6
    What I meant was for the skilled individual working on it. I don't have a crowd around me when doing these repairs/rebuilds.
    In fact, I yell at anyone who invades my work space to get lost when I am working with live voltage.
    And, of course you wouldn't want to leave it plugged in and unattended for the kids to play with :rolleyes:
  20. ericbecky
    4,381
    3,242
    Madison, Wisconsin
    My favorite is when I've had someone behind me take a FLASH photo while I was working on an exposed battery pack.
    Scared the %$&* out of me!
    jadziasman likes this.
