Fuel consumption while driving at 80mph?
Discussion in 'Gen 2 Prius Fuel Economy' started by bartolo5, May 24, 2006.
  1. bartolo5
    bartolo5 New Member
    Hi guys,
    I'm thinking of getting a Prius 2006, mainly because it will allow me to use the carpool lane here in the San Francisco Bay Area. I'm also interested, obviously, in fuel consumption but I was wondering how realistic those 50mpg that I see around are under normal driving conditions.
    I usually drive highway miles between 60-80 mph, any idea of what kind of mileage I should expect at let's say 60, 70 and 80 mph?
    Thanks in advance
  2. Wildkow
    Wildkow New Member
    5,270
    37
    36
    <div class='quotetop'>QUOTE(bartolo5 @ May 23 2006, 09:22 PM) [snapback]260145[/snapback]</div>
    I live in the San Joaquin Valley so it's pretty much flat here and using the CC I get . . .
    60 mph - 48-50 mpg
    70 mph - 43-45 mpg
    80 mph 38-42 mpg only one time est.
    Spring weather above 60 degree F. steady speed with CC down I5 or CA 99. YMMV. The car is a GAS! Get one!
    Wildkow
    I live in the San Joaquin Valley so it's pretty much flat here and usnig the CC I get . . .
    60 mph - 48-50 mpg
    70 mph - 43-45 mpg
    Wildkow
    p.s. http://priuschat.com/index.php?showtopic=19900
  3. Vincent
    Vincent Don't Wait Until Tomorrow
    641
    31
    South Florida
    47-48MPG for my mostly flat mostly 68MPH highway commute on cc.
    I can get stuck in stop/go/slow traffic for around 5 miles; then my MPG can jump to 51-52MPG. I just raised my tire pressure to 38/36 over the weekend and I hit 54.7 MPG yesterday with traffic.
  4. Kirkman
    Kirkman New Member
    My Prius does better gas mileage in warmer temperature. I have 3000 miles on it and I'm currently getting 51mpg locally and 53mpg highway.
  5. MikeSF
    MikeSF Member
    416
    San Francisco
    I commute from San Francisco to Contra Costa 4 days a week, Now I don't hit 80, but 60-65 speeds are not out of the ordinary, and most of my drive is reverse commute direction so I dont hit much in the way of traffic, I'm pushing 50-53MPG on that drive.
  6. berylrb
    berylrb Member
    308
    san francisco?
    Hey Bartolo, welcome to the boards!
    I live in the heart of SF, behind Twin Peaks on Mount Davidson so it is an understatement that living in the bay area "Your Miles May Vary" YMMV, LOL ... sounds like you're a freeway commuter you should do fine, what kills us are the 2-5 mile trips on hills.
    We have been steadily weaning ourselves off of commuting back to Sacramento for business, personal and family, and the car is used more now for Safeway trips than work due to MUNI.
    I've only had two long 80mph roundtrips this year (going 3 miles on the CA-280 to Daly city doesn't count right?)
    SF - Elk Grove (suburb of Sacramento) I-80 May 8th at 75-80 mph 50.97 mpg, temp in EG 85F, SF 57
    SF - Lathrop (Stockton) CA-580 to the I-5 Feb., this route has two passes, full cruise control is full throttle, 1 75-80 mph, 41.0 mpg Lathrop 60 F, SF 50
    I'm quite sure I spend most of my time at 77 mph fast enough to stay in lane two and not impede traffic, and slow enough to be passed constantly in lane 1, you know what I mean? August 2004 we did a 65-70 mph trip to San Diego, I was curious what would happened if I slowed down, LOL, still 50 mpg but it was the I-5 almost all cruise control, no new techniques and the standard tire pressure and vacatino luggage, YMMV. :p
    I have been using some of the techniques mentioned here for higher mileage, mainly trying to use up the battery with uphill bursts and increasing tire pressure, but I'm still on that tank, I'll report later, so far it looks like I've gained about 2-3 mpg. I've had to relax a little, one can spend more time shooting for 50 mph than watching the road :lol:
    b
  7. Kirkman
    Kirkman New Member
    The fun in driving a prius locally, is using the pulse and glide method. Looking ahead and seeing a red light, release the gas and let the generator charge the battery as the car glides to a stop. I find myself glancing at the energy screen all the time.
  8. MikeSF
    MikeSF Member
    416
    San Francisco
    yeah Portola distrcit for me, I'm lucky with my freeway driving because its a coast down hill to get to the freeway (Unfortunately the ICE turning on to warm up doesn't help), back I got to go back up the hill, so leaving SF is not the issue if I want to drive to anywhere within the city though that means multiple hills (Exception being the embarcadaro, I drove there and was amazed at the flatness).
  9. busyrosy
    busyrosy New Member
    113
    Bay Area, CA
    Once you get a prius, you'll probably change the way you drive. The consumption screen is addictive.. it's like a freakin game that you're trying to master.
    I took a road trip from the bay area to las vegas and I only had 2.5 days so I drove fast (80-100 mph) and I had the AC on full. I even kept the AC on while I took stops for meals to keep my puppy cool. My avg was about 40 ish mpg.
  10. Maytrix
    Maytrix Member
    742
    Marlborough, Mass
    <div class='quotetop'>QUOTE(busyrosy @ May 24 2006, 09:06 PM) [snapback]260651[/snapback]</div>
    I agree, although I think it also depends on someone's mindset as well. I was getting the Prius solely to increase my fuel economy. So, having all that info and wanting to get the best fuel efficiency I could, I changed my driving and drive between 60-70mph. That's a huge change from the 80-90 I used to drive.
    My lifetime mileage is 46mpg. I've had the car since last Sept 1st and have 20k miles. So the majority have been in colder weather so far, I have a feeling my lifetime stats will rise over the next few months.
    Driving 70-80 (which I have done, just not frequent) really does drop the mileage, but I was still able to maintain above 40 on average.
  11. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    "I can get stuck in stop/go/slow traffic for around 5 miles; then my MPG can jump to 51-52MPG."
    And that's the beauty of this car!! When has anyone looked forward to traffic jams...or in my fine city...road construction. Warmer temps have finally arrived here, but the slow and go road contruction season has my current tank at 56 MPG...last THREE tanks were 50+ MPG.
    For the record, at highway speeds in the wide open spaces of the midwest, going 65-75 MPH, the MPGs vary with wind (lots of it sometimes) and temps. Usually a 48 MPG ave. with lows of 38 MPG(cold, VERY windy) to 52 MPG (calm, warm, perfect conditions). These would be 4-7 hour trips.
    This car rocks. :D
    Cheers,
    Curt.
  12. electricity_guzzler
    electricity_guzzler New Member
    70
    when you drive 70-80 mph, just make sure you are behind another car at least, or a truck preferably. the drafting effect makes a significant difference. see my drafting = 3mpg increase thread. (actually more like 7mpg increase).
  13. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    I tried to do an objective test last year. The test was here in Eastern Oregon where there isn't as much traffic, temperature 63 to 65 degrees F, no wind, using the CC. I made 8 passes (4 in each direction) over the same 8 mile stretch of freeway at 70 MPH. The terrain is rolling hills and the elevation is 400 to 500 feet.
    The 8 runs were fairly consistent and averaged out to 48.8 MPG using the consumption display's figures. I used the original Integrity tires inflated to 42 psi front and rear.
    I now have new tires in a larger size (205/60R-15) and plan to do the test again after I get a few miles on them.
  14. electricity_guzzler
    70
    <div class='quotetop'>QUOTE(tumbleweed @ May 31 2006, 09:13 PM) [snapback]263737[/snapback]</div>
    you'd have to wait until fall to do the test. i doubt the temp is going to go back to 63-65 for the rest of spring/summer.
  15. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i often do 80 and sometimes hit 100. i've never seen below 40mpg. right now it's 42.
  16. fshagan
    fshagan Senior Member
    1,766
    Noneofyourbusiness, CA
    I average 47.5 MPG with half of my driving on the freeway at various speeds up to 75 (I try to keep it within 10 MPH of the speed limit to avoid tickets). At times I'm doing 80-85, but most of the commute I'm around the 75 MPH figure.
  17. brasche
    brasche Member
    156
    Orlando, FL
    I average 42 mpg at 80 mph without A/C. Results from a 2000 mile trip from FL to IL and back.
  18. 200Volts
    200Volts Member
    439
    46
    Northern CA
    I bought my 04 in Salt Lake and drove 80-85mph for 800 miles to get home to Stockton, CA at 41 mpg average. (Man was I swearing at that EPA rating on the sticker....lol).
    After 85k miles I still average 41-43mpg at 80mph.
  19. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    I don't think you can average 40 MPG at 80 mph for the entire tank. I'd have to see it to believe it.
  20. joeh4
    joeh4 New Member
    30
