AccentGlowLED LED cup holder lights installation
Discussion in 'Gen 4 Prius Accessories and Modifications' started by bgebert, Sep 12, 2016.
  1. bgebert
    bgebert Junior Member
    NC
    Four Touring
    OK, my wife and I installed these in our cupholders the other day and thought we would share the experience.
    Items you will need:
    1. Time - about 30 min.
    2. Two AccentGlowLED LED cup holder lights sized to 2 3/4 inches. You can learn more here.
    3. 3/16th in drill bit
    4. A fuse tap
    5. 16/18 gauge wire (3ft)
    6. zip ties
    7. clear silicone
    8. a putty knife with some duct tape covering the end of the knife
    9. vacuum cleaner
    Now to the fun part:
    Step 1. Removing the lower center console
    Open the arm-rest door to remove the plastic panel directly below the arm-rest.
    Use the putty knife to gently loosen the lower console from the plastic clips. Once you have all of the clips loosened you should lift up from the front.
    The red clip nearest the arm-rest was the most difficult to loosen
    upload_2016-9-12_12-36-17.png Once you have it removed, just rest it on the passenger seat.
    Step 2: The power source
    We purchased a fuse tap from AutoZone and substituted the tap for the tail lights 10amp fuse located in the fuse box in the driver's side footwell. The tap holds 2 fuses. The 3amp fuse is for the LEDs and the 10amp fuse is for the tail lights. The advantage of this setup is the ability to turn on the LEDs when the lights are turned on.
    Once the tap is in place, you crimp/splice 3ft of 16/18 gauge wire to the fuse tap and run it under carpet (behind the brake and gas pedal to the lower console.
    Now that the fuse tap is installed, it is time to work on the lower console
    Step 3: Drill some holes
    Keeping the rubber mat in place, use the 3/16th drill bit and drill 1 hole per cup holder (a little off center). I know my pic shows the mats removed, but you want your holes to line up (mat to cupholder)
    Step 4: Attach your LEDs
    Attach your LEDs to the mats and put the newly joined piece back into the cupholder. Make sure the wiring is gently pulled through the newly drilled holes.
    Step 5: Wiring
    The red wires from the LEDs should be spliced to the red wire that goes to the fuse tap.
    The black wires should attached to a ground. I chose to ground it to one of the many bolts found underneath the center console.
    Step 6: Cleanup
    Vacuum any debris from drilling
    Apply some silicone to the underneath of the cupholders where the holes were drilled. This will prevent any possible leakage from the cupholders.
    Step 7: Reassembly
    Carefully put the center console back together.
    Step 8: Enjoy
    Turn your car lights on and enjoy :) upload_2016-9-12_12-53-47.png upload_2016-9-12_12-53-57.png
    #1 bgebert, Sep 12, 2016
    tezza.rae, MLK43611, RCO and 6 others like this.
  2. stanigu
    stanigu Member
    58
    62
    Blackhawk, CA
    Awesome mod. How bright is this at night time?
  3. bgebert
    NC
    Four Touring
    It's rather bright. The last pic in the post shows a nighttime shot, and it is brighter than everything else in the car. It would be cool to install an inline dimmer so you could adjust it. I'll take another pic tonight to show the brightness of the LEDs compared to the dash.
  4. krmcg
    2,592
    2,392
    Whittier, CA
    My cold drinks sweat quite a bit and it's not unusual to have standing water in the cup holders. I'm not sure that drilling a drain hole and installing electronics is a particularly good idea. My Avalon has cup holder "mood lighting", but it is at the top of the cup holders. Not the bottom.
    RCO likes this.
  5. bgebert
    NC
    Four Touring
    I understand where you are coming from and I thought the same thing. That is why I filled in the holes with silicone after the wiring was fed thru. Plus AccentGlowLEDs are built to be at the bottom of a cup holder, so they can take heat (or liquid as the case may be).
    RCO, superbug74 and krmcg like this.
  6. bgebert
    NC
    Four Touring
    krmcg,
    How in the world are you getting 66.2 mpg? That is fantastic! I'm averaging 53.
  7. krmcg
    2,592
    2,392
    Whittier, CA
    Concentration. Pure concentration.
    KnightRider2016 likes this.
  8. bisco
    52,211
    those are cool, i love it. well done!(y)
  9. bgebert
    NC
    Four Touring
    stanigu,
    You asked how bright the LEDs were. Here is the night shot I promised.
    While I was taking pics, I thought I would throw in a pic this little mod (new door lights)...
  10. stanigu
    stanigu Member
    58
    62
    Blackhawk, CA
    Thanks! Looks good--It doesn't seem like the brightness would bother too much. It looks pretty blue though in comparison to the rest of the dash--does it have the "OEM" look?
    Love the pacman too!
  11. bgebert
    NC
    Four Touring
    stanigu likes this.
  12. stanigu
    stanigu Member
    58
    62
    Blackhawk, CA
    OK, I think I'm going to do it!
  13. stanigu
    stanigu Member
    58
    62
    Blackhawk, CA
    Just ordered. FYI for those purchasing this mod: coupon code "facebook5" (without quotes) gets you $5 off.
  14. bgebert
    NC
    Four Touring
    Let me know if you end up with any questions about installation, and post a pic once it is installed. BTW, which color LED did you choose?
    stanigu likes this.
  15. stanigu
    stanigu Member
    58
    62
    Blackhawk, CA
    Thanks! I went with the blue ones like you did. I was really torn between the blue and white, but I noticed that the blue from the illuminated door sill looks very similar to the blue of the cupholders, so I thought it would go well.
  16. stanigu
    stanigu Member
    58
    62
    Blackhawk, CA
    It's done!
    Thanks for the instructions and inspiration. The blue matches perfectly with the door sill lights. Neat.
    RCO likes this.
  17. bgebert
    NC
    Four Touring
    Awesome! I glad the blues match so nicely. Now, my wife wants to do the door sills :)
  18. stanigu
    stanigu Member
    58
    62
    Blackhawk, CA
    flic likes this.
  19. Philthunder
    Philthunder Member
    37
    30
    Uk
    2018 Prius PHV
    Excel
    Great write up, inspired me to put some footwell lights in the rear, just need to get the right amount of LED light, than a write up. Removed the trim, exactly as you said, great. One question why not take a feed from the power outlet. It looks like you have already taken a feed for something, why not the LED accent light as it's only a few mA extra?
  20. Veliksam
    Veliksam Member
    108
    61
    Orlando
    2014 Prius c
    Maybe the op should've tapped an illuminated button/switch, then the LED would dimm with the rest of the vehicle illuminated buttons via the dimmer switch.
    At least I think it would work that way?
    #20 Veliksam, Dec 19, 2016
    RCO likes this.
