EVSE purchase & installation in 2017
Discussion in 'Prime Plug-in Charging' started by john1701a, May 28, 2017.
  1. john1701a
    john1701a Prius Guru
    12,794
    5,276
    57
    Yes. The data is priceless too. I really like being able to check status on the fly.
    Each is on its own 40-amp line, with individual sub-meters. That's very convenient for monthly usage tracking. Our electricity provider breaks down the bill nicely.
    Now having the hardware in place to deliver twice the charging-rate later on is really nice. Of course, the $1,000 rebate check made the decision to invest a no-brainer.
  2. Okopipi
    Okopipi New Member
    Raleigh, NC
    Update - I just had my JuiceBox 40 installed yesterday. Love it!!! @DavidA my JuiceBox J1772 isn't at all difficult to get into the charging port. Of course it could be that one unit you have, though you mentioned that even your second unit is a little tough to get seated. This doesn't seem to me, to be normal.
    john1701a likes this.
  3. DavidA
    2,341
    1,818
    Chicago western burbs
    Fun using the faster method, ain't it? My JB40 is still a little difficult to push in. Might be that it is just wearing, or that the weather is getting cooler. I haven't tried the suggested silicone spray yet, though I might, as I have some of that from the 90's (doesn't ever go bad). The blue handle on the OEM 120v still fits in waaaay easier, but at 5.5 hrs vs. 2:05, I'll keep using the JB.
  4. john1701a
    12,794
    5,276
    57
    Mark57 likes this.
  5. Mark57
    2,945
    2,738
    OK
    Great job. Nice logical layout.
  6. Prodigyplace
    12,395
    11,676
    Central Virginia
    jerrymildred likes this.
  7. john1701a
    12,794
    5,276
    57
    Looks like PriusChat caches outside images now, rather than pulling refreshed images. That's a really nice enhancement, but I wasn't aware of the change... which means my previous post won't reflect the 3 new photos I added. So, here's an upload of thE document updates:
    John's Stuff - Toyota Prius Prime - Home Charging
    Strange. It doesn't show the update on the regular forum page (even after clearing browser cache), yet I can see the difference in edit mode while typing this. Oh well. At least the webpage hosting has the refresh for 11/19/2017.
    #67 john1701a, Nov 19, 2017
    Tideland Prius and Prodigyplace like this.
  8. knightofdight
    knightofdight New Member
    Tennessee
    So let me get this straight... If I were to buy the JuiceBox 40P, I would need to hire an electrician to add in a 240V 50A circuit to my garage before I could use it, correct?
    In my area that will run me about $350 including labor... so altogether it will be about $1k to do this upgrade. Is the decreased charge time worth that investment?
  9. john1701a
    12,794
    5,276
    57
    50-amp is well beyond the current Prime capacity. 40-amp is the standard for most. You could pull heavier gauge later, if wanted.
    For us, we got a $500 per charger rebate a setup for Time-Of-Use discounting.
    The fast charging and pre-warming via cord is really nice.
  10. knightofdight
    Tennessee
    I don't know much about electricity, so please pardon my ignorance.
    1) If the Juicebox charger itself is 40A, would I not need a breaker that is more? That is why I thought of 50A.
    2) How do you go about getting a rebate? Do you need to have them add a separate meter?
  11. hill
    8,622
    if by 40 amp, you're referring to the breaker, then yeah, it'd mean the evse's max capable delivery would be 30 amps ie; 7.2kW's .... ~double the Prime's 3.6kW's capable of receiving.
  12. john1701a
    12,794
    5,276
    57
    32 amps is the max... 20% buffer.
    The JuiceBox max can be set to whatever you want.
    Each service-provider has their own incentive program.
  13. hill
    8,622
    yes - that seems to be a capability of many evse's. It's always worth pulling oversized wiring as a way to futureproof for the growing capabilities of plugin's. We just picked up an EVSE capable of delivering 19.2kWs ... new, for $300!! Running full power, that'd require a minimum of #4 wire. Fortunately, the charger built into our plugin - (capable of receiving almost 17.3kW's) is manually adjustable - so we can throttle its charge rate down as low as 5amps, in 1amp increments. We'll never need to charge faster than 45/50 amps, so that only requires a 60amp breaker & 6 gauge wire. Economy thinking AND Future proofing. Pic's coming once install is complete.
  14. john1701a
    12,794
    5,276
    57
    Our bigger consideration was having capacity to recharge 2 vehicles at the same time. 40-amp lines will cover overnight charging. You can completely replenish a 60 kWh battery-pack in that time.
  15. CraigM
    CraigM Active Member
    208
    208
    Portland, Oregon
    EVSE discounts / rebates / credits depend on where you live. For instance, three years ago I received an Oregon state tax credit for my installation. In other locations the rebate might be from a local electric utility. I seem to remember several years ago some area in California offered multiple deals that could be added together!
  16. hill
    8,622
    So true. we installed our Aerovironment EVSE in 2010. They told us it was the 1st one in orange county. We didn't even have our plug-in yet, not for another 4 months! SoCal Edison was paying for ½ the install & equipment cost. Knowing about incentives, of course Aerovironment jacked their prices up Sky High. Back then, they were the only game in town, so they had us by the shorts so-to-speak.
    Reading the instructions on this unit I'm installing right now, I see it can be daisy-chained together with 3 other high-power EVSE's. Wired into a 100 amp breaker, the most power any one EVSE could deliver would be 25kW, presuming 4 cars were charging simultaneously .... or 2 cars could receive 50kW.
    I'm not regularly wiring such heavy duty stuff. I must say - looking at this number 2 wire, virtually the same size as my pinky finger, it's sort of blows me away.
    #76 hill, Feb 9, 2018
  17. hill
    8,622
    Above EDIT;
    oops ... went stupid when I did my math yesterday. Long day. Maximum 4 cars would be 4.5KW one car 19.2kW & so forth. Sorry.
  18. DavidA
    2,341
    1,818
    Well.... Apparently, the discontinued 2017 EVSE installation credits for a 30% tax rebate... IS BACK! Electrek had the article yesterday, and I'll link it here.
    Bought an EVSE and hired an electrician to install some or part of it in 2017 and thought you were S.O.L. for the rebate that ended at the end of 2016? Wait for a revision of form 8911 and get your receipts in order. Filed already without 8911? Talk to your accountant.
    Mark57 likes this.
  19. markabele
    5,084
    1,782
    Nebraska
    So stupid they did it retroactively.
  20. john1701a
    12,794
    5,276
    57
    Don't be so quick to dismiss.
    Retroactive is how you encourage early-adopters to share what they learned.
    That gesture of acknowledgement is very powerful.
    #80 john1701a, Feb 12, 2018
