My Last Tank >700 miles
Discussion in 'Gen 2 Prius Fuel Economy' started by VABeachPrius, Jul 28, 2006.
  1. VABeachPrius
    VABeachPrius Member
    155
    Virginia Beach, VA
    Hopefully you see a picture of my consumption screen. I will add it as an attachment too incase this doesn't work.
    Thanks,
    C
    Okay, I realize what happens now.
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Amazing... Outside temp was 97 deg also. Did you have AC on?
    Dennis
  3. VABeachPrius
    VABeachPrius Member
    155
    Virginia Beach, VA
    I use the AC about 40% of the time. It depends on how humid it is here. Today it is hot as he**, but it is a dry heat so no I rode with the windows down. I have had to use it when it was 85, but very humid.
    I just think I have the right conditions for this car to perform. I am on roads with speed limits that are between 25-50 mph and I pulse and glide like a crazy fool. We take short trips in my wife's car. It takes me about 35-40 minutes to get to work instead of about 28-30 minutes by using secondary surburban roads. The car has 1200 miles on it, 42/40, full conventional oil.
    I have gladly exchanged the extra time from freeway driving for lower blood pressure and minimal traffic. I drive the speed limit and others pass. I go out of my way to avoid others so I am not a moving speed bump and I anticipate stop lights.
    All of this came together with about 200 miles on this tank. Honestly, if I could redo this tank with what I think I know now, I believe I could get a 70+ mpg tank. I have to travel for work the month of August and most of September, so if there is enough time then and temperatures have not dropped, I will shoot for it then.
    Thanks,
    Chris
  4. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    What a great performance car you have over there, rather high performance driver. :D Yea, we measure performance in mpg not mph. Right?
    My best mpg for a tank of gas was 54.8 MPG. That was with 90% highway before the new rims and tires. So I did beat EPA numbers for sure.
    Dennis
  5. VABeachPrius
    VABeachPrius Member
    155
    Virginia Beach, VA
    When I drive on the freeway I see the same numbers as you. 50-53ish mpg. My commute is only 20 miles. If I had to commute 50 miles, I would not be using secondary surburban roads.
    Keep that gas guzzler (54 mpg) out of my way. :lol: :lol: :lol:
    I'm kidding, of course.
    Thanks,
    Chris
  6. JimboK
    JimboK One owner, low mileage
    2,817
    189
    49
    Chesterfield, VA
    <div class='quotetop'>QUOTE(VABeachPrius @ Jul 28 2006, 04:03 PM) [snapback]293946[/snapback]</div>
    As a neighbor about 100 miles to your west, and who has been in your neck of the woods dozens of times, I have one question: When the he** is the heat of a coastal Virginia summer DRY?? :)
    Anyway, congratulations!
    Jim
  7. VABeachPrius
    VABeachPrius Member
    155
    Virginia Beach, VA
    Point taken. Maybe I have been here too long. It "felt" less humid today.
    Thanks,
    Chris
  8. caprinicity
    caprinicity New Member
    <_< I averaged 65.8 mpg today, with the air conditioning ON, but I think I had a tailwind...
    Bonnie in PA
