Help / Sirius 06 Package #8 / Delaer claims that the XM and Sirius Tuners are now same??
Discussion in 'Gen 2 Prius Audio and Electronics' started by DonC, Jul 31, 2006.
  1. DonC
    DonC New Member
    I am supposed to pick up new 06 Prius on Thursday. Dealer claims the car has XM installed. I have Sirius in my current car, not interested in XM. I emailed Sales guy with the part number of the Sirius Solara kit and the static fix link, he claims he spoke to Toyota folks and they claim that the XM kit sattelite unit will work for either depending on who you activate it with?
    As a current sattelite person, this makes no sense to me..
    Am I missing something or is my dealer salesperson (very good guy) being mislead by Toyota?
    Thanks,
    Don
  2. AlphaTeam
    AlphaTeam Member
    643
    Earth
    I'm almost positive he is mistaken. Different electronics, just different man.
    If that was true we could all use whatever we wanted and change. You buy specific hardware.
    I have Sirius, the unit says "SIRIUS" right on it. Not the same.
  3. wesj49
    wesj49 Junior Member
    72
    CA Central Coast
    <div class='quotetop'>QUOTE(AlphaTeam @ Jul 31 2006, 04:41 PM) [snapback]295396[/snapback]</div>
    Yes, they are different electronics but those electronics are rarely inside the head unit but rather in the external tuner unit that the dealer is going to install along with the antenna.
  4. BobZ
    BobZ New Member
    323
    Long Island, NY
    <div class='quotetop'>QUOTE(DonC @ Jul 31 2006, 07:32 PM) [snapback]295391[/snapback]</div>
    I just put XM in my 06 this week. I installed surius for a friend the week before. NO, nada, NYET the tuners are not the same. Tuner comes in one box. Wiring and brackets and antenna (fit kit) comes in the other. the OEM Sirius tuner (toyota part # PTS31-00052) using fit kit part# PTS31-00051.
    For XM tuner is 86180-0W030 fit kit PT546-47060
  5. DonC
    DonC New Member
    <div class='quotetop'>QUOTE(BobZ @ Jul 31 2006, 08:44 PM) [snapback]295422[/snapback]</div>
    Thanks to you all for responding. I wanted to make sure I wasn't missing something on delivery day. No more FM tuners hopefully for me..
    Don
  6. randreed
    randreed Same as it ever was . . .
    605
    West Milford, NJ
    No - different receivers, different content, different companies, different "birds" (satellites). If you have satellite TV take a look at your music options!
    - Sirius is on the same birds as the Dish Network
    - XM is on the same birds as Direct TV
    Many people have this misconception about satellite radio (and TV). These companies are competing against each other AND the local free radio stations.
  7. nasafella
    nasafella New Member
    <div class='quotetop'>QUOTE(Rand Reed @ Jul 31 2006, 08:11 PM) [snapback]295499[/snapback]</div>
    Well, not exactly (about the satellites).
    Satellite radio has to be received by cars with very small and very moving antennas. Frequently among buildings and such, so the satellite needs to be as high overhead as possible.
    Direct Broadcast Television uses fixed antenna on your house, with a dish to increase the gain. The satellites can be low to the horizon and the dish moved to accomodate.
    So, very different satellites.
    TV (DirectTV and Dish) have satellites in circular equtorial Geosynchronous Earth Orbit, meaning they orbit the earth at the same rate the earth is turning beneath them, so from the ground they appear at a fixed locatoin in the sky. Direct TV has three (actually maybe five counting spares) birds at assigned slots along the equatorial plane. Don't know about Dish.
    Satellite radio birds are in highly inclined and highly elliptical orbits (molynia if I remember right). These orbits appear as exagerated figure eights from the ground. The purpose is to have them above the receiver as long as possible during each orbit. There's a constellation of several satellites for each service.
    The satelite radio you get on TV is received by DirecTV or Dish (probably via direct microwave link from XM/Sirius) and then rebroadcast on their GEO sattelites.
    Not that you asked......
  8. bad monkey
    bad monkey New Member
    Not to confuse things, but the parent company of DirecTv, Hughes, bought Dish a few years back. The Anti-Trust Commission ruled that cable companies compete with satellite for the same service, so it does not violate Trust Acts by having one company own 95% of all satellite service. Is VOOM!, Mark Cubin's HD only service still up?
    And to stay on topic...
    Is the "OEM Sirius tuner (toyota part # PTS31-00052) using fit kit part# PTS31-00051" mentioned earlier the correct parts for an 06 prius looking for Sirius?
  9. Dan-Wolfe
    Dan-Wolfe Member
    166
    31
    North Canton, Stark, Ohio, USA
    <div class='quotetop'>QUOTE(NASA guy @ Aug 1 2006, 03:20 AM) [snapback]295583[/snapback]</div>
    Actually, XM's three satellites, named Rock, Roll and the first of the new series, Rhythm, are in fact geosynchronous -- NOT inclined orbit satellites as are Sirius's. As a footnote, the new ground spare either is or will be named "Blues." So you have the first generation XM sats as Rock and Roll, and the second generation as Rhythm and Blues. :) So they do not share sat space with DirecTV.
  10. nasafella
    <div class='quotetop'>QUOTE(Dan-Wolfe @ Aug 1 2006, 06:53 PM) [snapback]296023[/snapback]</div>
    Ah, well according to google you're correct. Thanks for the info. The Sirius constellation was used as an example in Astrodynamics class, and I ASSUMED that XM was the same. Well there you go.
  11. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
    <div class='quotetop'>QUOTE(bad monkey @ Aug 1 2006, 08:50 AM) [snapback]295686[/snapback]</div>
    You're confusing things by posting this completely bogus information. Absolutely, 100% WRONG WRONG WRONG.
    Charlie Ergen founded Echostar with Jim DeFranco (the guy you see sitting next to him during the "Charlie Chats") and he is still the majority shareholder of Echostar. He owns ALL 238 million class A shares of the company and over 90% of the voting rights. Dish Network is a brand of Echostar.
    In fact, Rupert Murdoch is just now talking about acquiring Dish - what you claim already exists today. Murdoch's News Corp bought GM's 34% share of Hughes Electronics (not Hughes), and therefore DirecTV back in 2003.
  12. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    I would imagine the end of the harness plugging into the sat receiver would be the same, so the receivers could be swapped between the cars. You would then also keep your subscription.
