2005 JBL sound- distorted bass in front
Discussion in 'Gen 2 Prius Audio and Electronics' started by LKasdorf, Nov 18, 2018.
  1. LKasdorf
    LKasdorf Junior Member
    77
    24
    Waterford, VA USA
    Yesterday I picked up a 2005 with what the seller called the "touring package". I he called it that because it has navigation and the JBL cd/cassette sound system. It doesn't seem to have the pink/red strut stripes, so I don't know...
    Anyway, today I tried playing some music and noticed that there was no bass. I saw that the bass control was all the way down, and it was faded all the way to the front. When I bring the bass control up at all, there is a lot of distortion on bass notes. If I fade to the back, the bass gets better. It seems that some prev owner blew out the drivers in the front doors.
    So- what is a cheap source for good replacement drivers for these?
    Also, is there supposed to be a subwoofer in the 2005 JBL sound system? If so, where?
  2. James1964
    James1964 Member
    177
    83
    Vashon Island, WA
    No subwoofer in ours. Those old JBLs can disintegrate. I've seen replacement JBL speakers available which would probably be the easiest swap job but if they're old then it's risky. I'm considering taking it to an install place and seeing what they offer. There are smaller, powered subs that PC members have installed successfully. Only way to vastly improve, update is install a new head unit, speakers, and what not.
  3. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    What you'd want to get in aftermarket replacements if you go down this route is as high of a sensitivity as possible. The front JBL speakers are weirdly 2 ohms (most everything aftermarket is 4 ohms), which means you'll get half as much power to the front speakers for the same input if you install aftermarket 4 ohm speakers.
    Here's the best reference on the internet about the 2nd gen Prius JBL system: Prius JBL Audio system response, specs, and photos
    If you might replace other parts of the stereo in the future, I would just save and replace everything at once (headunit and all speakers). There's no subwoofer in the system. Also when installing aftermarket speakers, you'll almost certainly need to make your own brackets for them. Most do it using 3/8" plywood or similar.
    James1964 likes this.
  4. Kevin_Denver
    581
    425
    Denver, CO
    What my rear speaker install looked like:
