Glide, yes. Pulse? What's that?
Discussion in 'Gen 2 Prius Fuel Economy' started by harper42, Aug 18, 2006.
  1. harper42
    harper42 Member
    226
    I thought I understood the pulse and glide technique, getting the screen to the No Arrows state. But I was reading about the Japanese gal who gets 115 mpg, and it says she Pulses up to 60 something, then glides down to 30 something. My question: How do you PULSE up to a certain speed????
  2. M. Oiseau
    M. Oiseau 6sigma this
    270
    Tulsa, OK
    Pulse refers to accelerating with the ICE (internal combustion engine) at a throttle setting yielding no arrows to or from the electrical system.
  3. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    Pulsing can actually be more challenging than gliding (if you're trying to do it right). Basically, the idea is to get the ICE operating at higher revolutions, because it's more effecient there. So you quickly accelerate (don't floor it, thats too high) up to a certain speed, then glide back down... the sweet spot of pulsing is when you have arrows only from the ice to the wheels and the ice to the motor to the wheels, and nothing going to or coming from the battery.
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Remember, too, her "60" is in KMH, not MPH, likewise the 30.
  5. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    My personal awakening was I think Evan's document which showed a picture of a pulse achieving something like 16MPG. Up to that point, I tried really really hard to keep the real-time MPG up as high as possible. As you can imagine, I was often frustrated. Now I just try to make sure the ICE is propelling the wheels and topping off the battery at the same time.
  6. harper42
    harper42 Member
    226
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Aug 18 2006, 02:07 PM) [snapback]305551[/snapback]</div>
    NOw I"m confused. One post says arrows from IEC to wheels and back, none to or from battery. Another post says to have IEC power wheels and battery. I just drove into town and it's really difficult to reach that point with no arrows to or from battery. Any tips on how to do that?
  7. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    It doesn't really matter. Again, the whole "deadband" myth is just
    that -- whether the battery charges or not during a pulse is ENTIRELY
    dependent upon its current state of charge, always seeking 60%, and
    where you happen to have it at any given time is not something you
    have a lot of control over. The torque and power curves of this
    engine are very forgiving, so exactly how hard you pulse, as long
    as you're running under load but not reaming it hard, just doesn't
    matter a whole lot. Your best bet is to install a tachometer, and
    then you can pulse somewhere in the neighborhood of 1800 RPM [for
    the lower speed ranges] which will put you right in the sweet spot.
    If you can hear your engine and judge that RPM by earball, go for it.
    Otherwise there isn't a whole lot on the MFD that's useful, except
    perhaps the instantaneous but what's "optimal" there slides all
    over the place depending on wheel speeds.
    Suggest you get over to http://www.cleanmpg.com/ and read Wayne
    Gerdes' excellent "pulse and glide" article, with pictures and all.
    _H*
  8. theorist
    theorist Member
    365
    Lexington, MA
    <div class='quotetop'>QUOTE(hobbit @ Aug 18 2006, 08:11 PM) [snapback]305634[/snapback]</div>
    The engine map for our engine that I just saw in a presentation linked by ken1784 indicates that the engine is most efficient around 2300 RPM. Is 1800 RPM more efficient due to the PSD at low speeds? Is it to extend the pulse cycles a bit due to losses with engine start-up and shut-down? I haven't verified the accuracy of the engine map.
  9. TonyPSchaefer
    14,816
    2,500
    66
    Tomorrow I'm driving up and back from the Milwaukee Hybrid Group meeting with the injured but ever-teaching Wayne Gerdes as my passenger. I'm sure that by this time tomorrow I'll be a professional. So perhaps I should hold off on this, but I've already started so I'll finish. :D
    I've always been working under the assumption that "Pulsing" was when the ICE is powering the wheels and charging the battery whereas "Gliding" is when nothing is powering anything.
    The one on the left is Glide, in the middle is Pulse, and on the right is Oolong, a rabbit with a pancake on his head.
  10. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Aug 18 2006, 09:42 PM) [snapback]305756[/snapback]</div>
    And Oolong's ears are flattened, clearly a Pancake Spatial Deformer (PSD).
  11. hobbit
    4,089
    469
    Bahstahn
    At higher speeds, 2300 rpm is about where I see a vacuum decrease
    that I attribute to different valve timing. I call that the high
    end of the "sweet spot". At lower speeds this tends to happen less.
    I did try to do an A/B/A/B highway test of 2200 vs. 2400 rpm, i.e.
    just either side of that transition, and the 2400 tests came in
    2-3 mpg under the 2200 ones but it wasn't a huge delta. Still,
    higher RPM in general seems to chew more fuel -- the hypermilers
    all advocate low RPM, the Miller paper referenced above refers to
    "negative split" aka "heretical mode" as "forced engine lugging to
    optimize fuel economy" ... and my own observations so far seem to
    support all this too. So while the engine may have its *theoretical*
    peak efficiency on a dyno at higher RPM, it may be that when the
    rubber meets the road several parameters change that shifts that
    down. For example, where that vacuum rise falls off at the top
    varies pretty significantly with vehicle speed, so something in the
    ECUs are taking that into account and modifying the strategy.
    _H*
  12. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    Efficiency peak doesn't mean that is where engine should be run. Running very efficiently at high power is a waste if the HP you need is less. So running slower and with less power and less efficiency will use less fuel.
    The greater the rpm the greater the losses. The efficiency increase is wasted if you don't need the even greater power increase.
    At higher rpm the losses in the gears are also increased.
    Therefore lowest rpm should always be better economy, as long as the torque is adequate, which the HSD takes care of.
    My back up generator works the same way. It is a Yamaha, and the engine rpm varies with the load so it is always running as slow as possible. Makes it far more efficient than a fixed rpm generator always running at it's max efficiency rpm.
    Running at extra rpms is kind of like driving a car with a big engine. Say you had a choice of car engines:
    1 has 3000 HP and is 90% efficient.
    The other has 100 HP and is 30% efficient
    Which would you pick to cruise along at 40 mph in order to burn the least fuel?
  13. tmgrl3
    tmgrl3 Member
    315
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Aug 19 2006, 12:42 AM) [snapback]305756[/snapback]</div>
    I think I've got the P&G down....
    But...
    Dang...no matter what I do, I can't get a pix of Oolong on my MFD....
    Does Wayne have any Oolong articles????
    I loved the bit you wrote about SOC in relation to P&G in another post, Tony!!
    Thanks....I'm printing out the link by WG to read....
    terri
  14. theorist
    theorist Member
    365
    Lexington, MA
    <div class='quotetop'>QUOTE(tomdeimos @ Aug 19 2006, 10:16 AM) [snapback]305820[/snapback]</div>
    I thought we were talking about pulse and glide in this thread.
    Hypothetically, is it better to produce 20 bhp at 30% efficiency 30% of the time (0 bhp 70% of the time), or is it better to produce 5 bhp at 15% efficiency all of the time? I'm sure the numbers are off, but I thought this is the idea of pulse and glide versus cruising at a constant speed.
  15. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    <div class='quotetop'>QUOTE(hobbit @ Aug 18 2006, 10:31 PM) [snapback]305768[/snapback]</div>
    Listen to Hobbit, he is good he is kind. He is analog. He may be picking up subtle differences, that we in the digital world can not see. At the very lest look at what he is saying.
  16. tomdeimos
    995
    Lexington, MA
    <div class='quotetop'>QUOTE(theorist @ Aug 19 2006, 09:40 PM) [snapback]306033[/snapback]</div>
    I was responding to Hobbit's comments implying surprise that lower rpm was better for max mpg when max efficiency is at higher rpm.
    True in steady cruising or the pulse of pulse and glide. But with pulse and glide you have to weigh the benefits of more pulse to get longer gliding time. So there is an ideal balance somewhere. It is hard to figure where though and most of these discussions neglect much of the problem by ignoring the drive train losses. We really need a simulator for this.
  17. theorist
    theorist Member
    365
    Lexington, MA
    Thank you again, Hobbit.
    <div class='quotetop'>QUOTE(tomdeimos @ Aug 19 2006, 10:12 PM) [snapback]306047[/snapback]</div>
    Thank you. I guessed the difference might be due to the PSD. I suppose the rest of the drivetrain would play a role as well. The engine map may have excluded the exhaust system as well.
    <div class='quotetop'>QUOTE(hdrygas @ Aug 19 2006, 10:01 PM) [snapback]306039[/snapback]</div>
    I actually cling eagerly to what Hobbit says. I asked about the RPM difference because I wanted to learn more from him. I also worry that a relatively wide open throttle might cost longevity a bit even if it helps fuel efficiency a bit.
  18. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    <div class='quotetop'>QUOTE(tomdeimos @ Aug 19 2006, 09:16 AM) [snapback]305820[/snapback]</div>
    I think this needs to be repeated - efficiency and economy are two different things. Efficiency is getting the most power per unit of fuel, economy is getting the most distance per unit of fuel. Car manufacturers have been improving engine efficiency impressively for decades, but have put it into extra power for more performance, not better economy.
    Since a gas engine has the highest efficiency under about 80% of max load (if I recall correctly, might be different for Atkinson engine), it will be accelerating the car at that level, unless it's a weak engine for the size of the car. Since the Prius has the battery to help with acceleration, the engine is comparatively weak, but not that weak. You can't accelerate a car forever, so either you go with lower RPMs, or periodically you glide (coast if necessary). It would be interesting to run a suite of tests on a simulator to see what has the best economy. It seems rather well established that pulse and glide is better than continuous low RPM, but the question here seems to be how strong should the pulse be and is engine efficiency the only variable that needs to be considered. I was hoping there was a definitive answer to that. Now it looks like I have to do my own seat-of-the-pants testing until smarter, more diligent people than I have the spreadsheets filled out and analyzed. :(
