2006 low mpg. Any suggestions?
Discussion in 'Gen 2 Prius Fuel Economy' started by Matt P, Jun 11, 2019.
  1. Matt P
    Matt P New Member
    Upland ca
    Having this problem with my 06 just calculated 34mpg at the pump not sure why. Tested the 12v and its good at 12.8
    Any ideas??
  2. Prodigyplace
    12,548
    11,772
    Central Virginia
    How many miles on it?
    Sometimes as the traction battery gets near the end of its life, mileage goes down as the engine works harder to maintain a charge.
  3. bisco
    51,896
    what were you getting previously?
    any other changes? driving route, weather, tires and pressure, oil change and level, etc.?
  4. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
  5. a_gray_prius
    2,927
    783
    IL
    I had a bad wheel bearing take my mileage from ~41 to ~38.
    maleko likes this.
